Emergency Shift lock override
Discussion in 'Gen 2 Prius Technical Discussion' started by rkoska, Feb 5, 2007.
  1. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    <div class='quotetop'>QUOTE(ilusnforc @ Feb 14 2007, 09:42 AM) [snapback]390241[/snapback]</div>
    You've posted this before and you are just plain wrong. The HSD is not like you describe.
  2. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    <div class='quotetop'>QUOTE(Bill Merchant @ Feb 17 2007, 01:23 AM) [snapback]391936[/snapback]</div>
    I don't recall ever posting anything about the HSD or it's operation, I tried searching through all of my previous posts and couldn't find anything related...?
    Perhaps you can elaborate on how the HSD does work rather than simply telling me I'm "just plain wrong"? I may not properly understand how it works, but how will I ever know if you can't explain?
    Your comment was "just plain rude" and uncalled for.
  3. Bill Merchant
    4,096
    87
    <div class='quotetop'>QUOTE(ilusnforc @ Feb 17 2007, 01:38 AM) [snapback]391962[/snapback]</div>
    I'm sorry, I didn't mean to be rude. I may have read this before and just thought you had posted the misinformation before. The Hybrid Synergy Drive is a lot more than only one physical gear.
    I would direct you to Graham Davie's discussion of The Prius "Continuously Variable Transmission". Please click HERE, then on Understanding the Prius, then on Continuously Variable Transmission. For some actual photos of the gears, look at the PrivateNRG page. John1701a has some excellent PSD animations.
  4. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    <div class='quotetop'>QUOTE(ilusnforc @ Feb 14 2007, 12:42 PM) [snapback]390241[/snapback]</div>
    this is correct. the 2g prius is shift by wire, all the other yota/lexus hybrids are mechanically linked.
    this is not the reason for the difference. as others have stated, other hybrids also have CVTs. however, the others have a shift cable and thus, shift lock overrides.
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(hill @ Feb 16 2007, 03:21 PM) [snapback]391633[/snapback]</div>
    I have no doubt that is true. All I can report is the experience of my co-worker with his 2006 Range Rover HSE. He's had it almost 11 months no, with no issues. Currently has around 10,000 km on it. It could very well be that he has the only Rover that was actually put together correctly.
    About the only thing that has happened so far was damage to the driver side adaptive HID headlight, when we managed to pop a deer at night. That happened a couple of months ago, can't really fault the RR for that. Most deer are suicidal by nature.
    Of course, I've had issues with my Prius, like the "stall" and the dead gas gauge. With a vehicle you can go with the median, but you never know which cohort you end up with once you buy the thing.
  6. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    <div class='quotetop'>QUOTE(galaxee @ Feb 18 2007, 09:49 AM) [snapback]392355[/snapback]</div>
    Yes, that's what I was getting at...
    <div class='quotetop'>QUOTE(Bill Merchant @ Feb 18 2007, 01:25 AM) [snapback]392278[/snapback]</div>
    That was taken more literally than it was meant. Yes, I'm quite familiar with how the Prius CVT operates and I do understand that it's a planetary system comprised of several "gears".
    One definition of the word "gear" is:
    -a part, as a disk, wheel, or section of a shaft, having cut teeth of such form, size, and spacing that they mesh with teeth in another part to transmit or receive force and motion.
    What I meant was a different meaning of the same word:
    -one of several possible arrangements of such parts in a mechanism, as an automobile transmission, for affording different relations of torque and speed between the driving and the driven machinery, or for permitting the driven machinery to run in either direction: first gear; reverse gear.
    That actually defines the CVT of the Prius quite well in the singular form as the Prius CVT has several possible arrangements (variable) with only one gear (no shifting). The plural word "gears" using the same meaning for most other cars would be something like "five possible arrangements of such parts in a mechanism..." Therefore, I mentioned the Prius having only one gear because that is a definition of the word "gear". My original post in this thread was in relation to it's topic, the shift lock, not the operation of a CVT broken down into individual components. Most cars simply allow the "gear shifter" to move the cable or linkages in order to put the transmission into neutral overriding the park locks. Calling it "misinformation" would be misinforming, a better choice of word may be "misunderstood". Sorry for the confusion, hope that cleared things up.
  7. rkoska
    rkoska New Member
    16
  8. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    <div class='quotetop'>QUOTE(Dick K @ Feb 19 2007, 01:26 AM) [snapback]392697[/snapback]</div>
    I thought your towing problem -- resulting in the wheels being locked in park -- stemmed from a loose plug behind the dash so the car wouldn't power up and you therefore could not put the car in neutral. I don't imagine this would be an issue with the car in a ditch unless it had sustained heavy damage getting into said ditch.
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    "Also many diesel powered motor homes have it, The mfgs have had the forethought to have a way to put it in neutral in an emergency"
    Actually, the heavy duty Allison 6 speed transmissions used in diesel pusher coaches and motorhomes lack a parking pawl. The pushbutton dash gear selector is R-N-D, with up and down arrow buttons to manually select a gear while in motion.
    Usually, upon a serious electronic fault, the Allison is designed to go into neutral. As long as there is enough air pressure to release the parking brakes, the coach can be flat towed a very short distance at low speeds.
  10. curtissac
    curtissac New Member
    187
    <div class='quotetop'>QUOTE(Bill Merchant @ Feb 14 2007, 02:07 AM) [snapback]390060[/snapback]</div>
    I think it is very valid concern. How many times have you seen a disabled car blocking traffic on a roadway and said to yourself (or maybe even yelled out), "Push your broken POS to the side of the road!" How many other cars are imobilized by an electrical failure? None that I can think of.
    Sounds like a nice security feature, but I think it could be equally hazardous. Toyota should have provided a way manually release the car from PARK, even if was some kind of lever or something under the dash - or even under the hood.
    There are a $#!+load of Priuses on the road today. While they are highly reliable cars, they will be more prone to breakdowns as they start aging. We dould be driving the only cars that can't be pushed off the road due to something as simple as a dead 12V battery. Imagine the road rage you may be subject to. :(
  11. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    <div class='quotetop'>QUOTE(Curtis SAC @ Mar 2 2007, 02:56 PM) [snapback]399221[/snapback]</div>
    I think it would be highly unlikely that the 12V system would just drop dead as you're driving down the road because I'm quite sure the DC/DC converter trickles power to the 12V system from the HV battery which is in turn charged by regenerative braking (there is no alternator). And, if the 12V battery was completely dead and the DC/DC converter fails and the Prius dies in the middle of the road losing all electrical power, I don't think it would be possible to engage Park. I think the issue at stake here is that once the 12V battery dies (in most cases when the car sits for long periods of time or the Prius fails to "boot") the Prius is not able to be moved without dragging the front wheels. If the only problem is that the 12V battery died then maybe the tow truck driver can hook up jumper cables to the proper locations under the hood indicated in the owners manual, then place the car in "Neutral" and be able to move it. I don't have the time to re-read this entire thread again so I'm not sure of any other issues that this workaround couldn't fix, like computers dying or electrical problems etc...
  12. curtissac
    187
    <div class='quotetop'>QUOTE(Bill Merchant @ Feb 18 2007, 02:25 AM) [snapback]392278[/snapback]</div>
    I have always found it easiest to desscribe the Prius CVT as a differnetial. Similar to what you see in the back of a rear-wheel drive car but the power being combined instead of being split. The "eCVT" is like having MG1 on one axle, the ICE on the other, and the output to the wheels (via MG2) through the drive shaft.
  13. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I'm coming into this thread way late, but I can probably help
    straighten a lot of this out. First of all
    _ http://techno-fandom.org/~hobbit/pix/udh1/351park.jpg and
    _ http://techno-fandom.org/~hobbit/pix/udh1/352park.jpg
    show the 3-phase actuator for the parking pawl in the '04+. [The
    Classic has a mechanical parking linkage from the lever with, as
    has been noted, an override under a little pry-out cover under
    the steering column.] The problem with the 60:1 reduction ratio
    and the fact that you need to bang those coils fast enough to
    create a proper rotating magnetic field to turn the rotor is,
    you aren't going to do it by just jumping a few wires even if you
    find the right spots in the transmission ECU plug. [Which, I might
    add, is conveniently right in the passenger footwell.] What needs
    to happen is that someone builds a widget that provides 12V and a
    3-phase switching output that adapts right into the transmission
    ECU plug, and allows direct actuation of the parking-pawl widget.
    Alternatively, you *can* get under the car and unbolt the thing,
    but it's pretty tight up in back of the transaxle. They didn't
    want to make it easy, after all.
    If a shop wants to leave a car in neutral but powered down, the
    easy trick is to get to neutral and pull the PCON fuse or relay.
    The car bitches and moans about this, but you *can* get it powered
    off and then be able to push it around without 12V. But of course
    that's not going to conveniently happen out on the road in the
    event of a random 12V failure.
    _H*
    DashingDave likes this.
  14. DashingDave
    DashingDave Junior Member
    39
    Monterey
    "How often" is not the right question.
    The vital topic is "How Important" is it.
    My Gen 2 Prius' last key stopped working while parked in a country friend's driveway.
    The "darn" dealer wanted $450 to make a new key (2 hours) to program it.
    Because my friend's home was more than my insurance would tow - it would have cost me another $600 to have it towed to the dealer.
    So $1000 because a key quit - that made an urgent situation instantly
    because I could not push my Prius out of his GRAVEL driveway - that he needed right away.
    My "workaround" involved putting 6 foot lengths of wood down for a mechanic's dolly. Jacking up the car front to rest on the dolly, which rolled a few feet at a time using a come-along winch, to eventually get it out of his driveway - so I could solve the key problem without blocking his driveway.
    "How often" did I NEED that function?
    Only once, so far.
    Having to deal without it - was horribly expensive or back breaking work to winch it 3 feet at a time to get it 30 feet out of that driveway.
    But it could have been MUCH Worse. If it had happened up in a another place I go - which is in the wilderness - two ferry rides from a dealer . . .
    Imagine the Cost of a tow truck hauling your Prius on TWO Ferries. . .
    Not Pretty !
    #34 DashingDave, Jul 21, 2025
  15. ChapmanF
    19,037
    The thing is, cars are supposed to (I think this means "required to", but don't have time to look up the exact regulation right now) have some mechanical feature that prevents a crook from just rolling the car away.
    For years and years that was pretty much always the steering column lock (including on the 1st-generation, 2001–2003 Prius). There would be a key, and the key cylinder was on the steering column, and without the key inserted and turned you couldn't steer. And the key cylinder was attached to the steering column with anti-tamper, breakaway bolts and stuff. It was made to be hard to defeat, because it was the required anti-crook measure.
    Starting with the pushbutton-start 2nd-gen Prius in 2004, there is no steering lock. You can always turn the wheel. (Without power assist if the car is off, so it takes some grunt, but it steers.)
    Instead, the parking mechanism in the transmission was made electrically actuated. The motor that actuates it is not the simple kind you could hotwire a 12-volt battery to and make it retract. It's a type of motor with several terminals that have to be pulsed in just the right sequence to make it move, and that's done by the car's Transmission Control ECU, which will only do so if it is convinced you're there with the right key fob. And the motor is made very hard to remove: in gen 2 it's up on the side of the transmission next to the firewall. Gen 3 puts it on the front of the transmission but with anti-tamper bolt covers. It is made to be hard to defeat, because it's the anti-crook thing.
    Either way, whether you've got a steering-lock car and your key doesn't work, or a tranny-lock Prius and the fob recognition doesn't work, it'll take dollies under the front wheels to move the car around. So it's kind of 6 of one or ½-dozen of the other.
