Emerging Propaganda Trends: Faux on Clean Energy
Discussion in 'Environmental Discussion' started by SageBrush, Jun 7, 2011.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    there are some safer designs in the pipe like fusion/fission hybrid, read this Nuclear fusion-fission hybrid - Wikipedia, the free encyclopedia
    The beauty if FFH that there is:
    - alot less fuel required at site
    - does not require enriched fuel, can work on unenriched uranium or waste
    - alot less waste
    - reaction is forced; it stops as soon as you flip the switch
    IMHO the CO2 reduction will require nuclear in some form, at least short term.
  2. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Until we figure out the baseload issue, I think you're correct. though I wonder if geothermal couldn't solve that problem at a lower total cost.
  3. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    Sounds like it has merit for using spent fuel, so the US gov't or states could build some as part of overall cradle-to-grave energy strategy. I'd want to know how small one could be. I like the SNR small rxr ideas. I thought military used spent pellets for anti-missle bullets, but maybe small use.
    I take a longer term view, assuming we have the luxury.
    One fundamental conflict the Epstein article alludes to is Rio/enviros sense of urgency to make immediate short-term changes to reduce CO2. I hate to adopt the coal-fired utility GW approach (try it you'll like it), but it took long time to get into this mess, may take a long time to get out.
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    If the people who construct buildings also had to pay the lifetime energy costs, geothermal would be standard. The digging and the piping cost a bit more up front, but the payback continues for a very long time.
  5. cyclopathic
    3,292
    547
    2014 Prius c
    It may.
    Here is the costs info:
    Geothermal Technologies Program: Geothermal FAQs
    Cost of other types:
    Comparing Energy Costs of Nuclear, Coal, Gas, Wind and Solar
    looks like geothermal will be inline with nuclear/coal, just a penny or two more.
    Now the availability is an issue
  6. cyclopathic
    3,292
    547
    2014 Prius c
    It especially makes sense for urban area, apartment complexes, office buildings, shopping malls, etc
  7. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Availability of geothermal? For the big power plants producing megawatts, it's just about anywhere on the 'Ring of Fire' where tectonic plates are most active. For the garden-sized variety of geothermal using the ground for local heating and cooling, it really is anywhere and everywhere.
  8. austingreen
    austingreen Senior Member
    13,672
    4,210
    Austin, TX, USA
    I think geothermal has great potential for Heating and air conditioning. It doesn't do as well in tall buildings. Where I live is a hot place, and they estimate AC with Geothermal only uses about 1/4 of the electricity as an efficient air conditioner. New buildings are using it more and more, but it is expensive to retrofit many old buildings. It more than pays for itself since it adds value to the home or building and lowers cost. It has big gains for heating as well, but this depends more on the climate and power mix.
    I ran into some folks the other day that were trying to fund a start up for geothermal electricity that works well in cold places. They had some test facilities in alaska. Geothermal electricity is still in its infancy.
  9. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Home PV installed at $5/watt in areas that collect 2 kwh/year costs 18 cents a kwh in today's dollars for the next 30 years. This is already cost parity for retail residential, and it is without any subsidies, and I mean NO subsidies.
  10. cyclopathic
    3,292
    547
    2014 Prius c
    The reality that it isn't. You can build really cheap geo-cooling system if you use existing water supply. Problem is that if it leaks the oil will get into fresh water supply; that's why it is banned by building codes.
    Air-to-water systems has been used in places where building codes are non-existent.
  11. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    World resources of Thorium: 6 million tons (US resources 440,000 tons)
    Energy available: 3.6 Billion kWh / ton
    Total energy: 2.1 x 10^16 kWh
    World energy usage (2008): 1.3 x 10^14 kWh/ year
    is 164 years (at today's usage rates. ha!)
    at a 2.2% growth rate it should last until 2077.
  12. tripp
    4,717
    79
    Denver, CO
    How about estimated uranium?
  13. tripp
    4,717
    79
    Denver, CO
    If we ramped up nuke power to 50% of all power produced how does that number above change? We'd push out another couple of decades I suppose.
    One of the nice things about thorium is that it's waste products have much shorter halflives and one of them is an element that's used in wind turbine rotor blades (starts with a v, can't remember the name).
  14. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Vanadium?
  15. austingreen
    13,672
    4,210
    Austin, TX, USA
    Trip, 50% is a number that is much too high. Let's pretend costs are much lower than they are and look at France. They get to 80%, but this is problematically high. They trade some night and weekend power to other countries for peaking power. Since to get to this number they have some plants on rivers and lakes that must be shut down when temperatures get hot or water levels are low, only ocean access. Given access to water a peak would be closer to 40% of world power, and we see that some countries like japan and the us have even screwed this by putting them in earthquake and tsunami zones. Next you need regulation and since japan failed this what chance do you think a country like saudi arabia or moroco has to do this. No 30% is the outside high range, which means we have at least 500 years of fuel. Nuclear's problems are costs, safety, regulation, and waste, not running out of fuel. I don't think Germany, Texas, or California are going to add any more nuclear, but of course Iran wants it, and China and India are going to build more.
  16. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    My reference states that know thorium reserves "exceed 3 million (metric) tons." While this doesn't sound like much, it is almost as plentiful as lead, three times more abundant than uranium, five times more abundant than tin, and 200 times more abundant than silver. The energy locked up in thorium probably exceeds all known fossil fuels deposits. If we are going to run out of thorium by 2077, we will run out of fossil fuels even sooner.
    Tom
    - Emsley, John (2003). Nature's Building Blocks. New York: Oxford Press.
  17. Corwyn
    2,171
    659
    23
    Maine
    If you start with roughly half as much (3M vs 6M) you are going to run out proportionally sooner. I should probably note that Thorium has not been searched for as fanatically as oil; there may be significant undiscovered resources.
    The upshot is that given an exponential growth curve for energy consumption, any resource is going to run out. "essentially limitless" means less than 100 years.
  18. wjtracy
    11,367
    3,608
    Northern VA (NoVA)
  19. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    And the high 'Solar' costs must be for large photovoltaic arrays. I can't imagine that local, passive solar would be so expensive.
  20. austingreen
    13,672
    4,210
    Austin, TX, USA
    Prices vary a great deal based on location, and local regulation and subsidies, and assumptioins about fuel costs. If you are doing solar yourself it will be less, but may be more in a utility. That chart seemed far off of new plants. These at least are close to the ERCOT costs, coal, nuclear, and solar are more here, gas and wind less. In california my guess is solar would be cheaper, but everything else more expensive.
    [ame="http://en.wikipedia.org/wiki/Cost_of_electricity_by_source"]Cost of electricity by source - Wikipedia, the free encyclopedia[/ame]
    Somehow the chart didn't pop up,so check the chart in the link.
    6.6 cents for natural gas, 10.4 cents for nuclear, and 9.7 cents for wind, 21 cents for solar. This is before talking about co2 output. Wind is the least corelated to peak demand (so think higher real cost) and solar the most corelated in a warm place (so lower real cost).
