Emissions and Fuel-Cost Savings of Electric Cars
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by samlal, Apr 16, 2012.
  1. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    The goal of the subsidies is to move the price of a battery down to about $300/kwh. Assuming that that actually happens, which may take a long time, that still would still leave just the battery of a 100 mile Plug in Prius at $10K. The ability of toyota to add a $10K battery to prius and charge $25000 with no subsidies is not remotely in the realm of reason. The tech to do 100 mile EVs is here, just look at the tesla roadster and soon to be released S, they are not $25K though.
    You are correct sir, we won't see a 100 mile pip in 3 years. The batteries are just too expensive even with the subsidies, for Toyota marketing to decide to do this. The sweetspot for phevs CD range for the us market is likely in the 15-60 miles and I would expect the next generation of toyota phev to fall somewhere in that range.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I used GC's number -- he is pretty clued in to diesel fuel economy.
    Here though is a Peugeot link of its Volvo V60 hybrid diesel twin, the 3008.
    NEDC is 74.4 mpg.
    Before you start frothing, remember that EPA = ~ 83% of NEDC, and the UK gallon is 1.2 US gallons. So US EPA MPG calculates out to
    (74.4*.83)/1.2 = 51.5 MPG.
    in terms of CO2 emmisions in the NEDC, the diesel hybrid is 99 grams/km, while the Prius is rated 89 grams/km.
  3. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    You said :
    Volvo says:
    HYBRID Mode: This is the car's default mode upon start-up in which both the rear-wheel drive electric motor and the front-wheel drive 215 horsepower turbodiesel engine work together. In this mode Volvo claims the car can return 124 miles per gallon and emit less than 49 grams of CO2 per kilometer.
    What you describe is not what is generally considered hybrid mode. What Volvo describes above is hybrid mode, concurrent blended use of battery and engine vs. what you describe as depleting the battery and then running on Diesel.
    Volvo says 125 mpg in HYBRID MODE. They may have misspoken, I can only go by what they actually said and what you actually said. Perhaps you misspoke and did not mean battery depleting and then Diesel?
  4. SageBrush
    11,627
    2,533
    Southwest Colorado
    Your words, not mine. I said blended mode.
    HV mode means all motive energy originates from the petrol (diesel.) The battery acts as a flywheel.
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Don't waste your energy. He's after an argument.
  6. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    Ok I thought you were quoting a us diesel. Its ok I just wanted to see the stat.
  7. SageBrush
    11,627
    2,533
    Southwest Colorado
    The Volvo V60 plug-in is a plug-in.
    Link
  8. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I'm smelling a rat here. Two new members, both signed up in March 2012, both confrontational against a number of existing members. Both found around the same threads and both write in a similar manner.
    A couple of trolls in my eyes too.
    Perhaps there should be a 'report' option so new members that quickly get argumentative can be kicked off. I've been on this forum for years and it's usually a chilled place to be, yet lately with certain members it's become the opposite.
    Shame there's not an ignore option. :)
  9. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Well its pretty good for a 215hp awd. But remember the 40mpg there is EU standard cycle, which is much easier test.
    The Opel Ampera official equivalent fuel consumption under the EU-approved UN ECE R101 standard for plug-in hybrids is1.2 L/100 km (196.0 mpg-US; 235.4 mpg-imp) (83.3 km/l). However, a leading Opel engineer prefers saying 169 Wh/km while battery-powered, and then 20 km/l petrol-powered. 20km/l is 47mpg.
