Emissions test failed due to CEL bulb
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sbddude, Dec 4, 2018.
  1. sbddude
    sbddude Junior Member
    62
    Bay Area, California
    2013 Prius v wagon
    Today I took my 2010 in for a Smog check. It passes everything except the CEL bulb is out. I also don’t see it come on when first starting the car.
    Possibly related - I recently had the 12v battery disconnected for an hour, then drove 700 miles in one day. Only a few miles driven since then. The car otherwise drives fine.
    Any suggestions?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Try unplugging your maf sensor and starting your car. See if it lights up
    m.wynn likes this.
  3. sbddude
    62
    2013 Prius v wagon
    Unplugged MAF sensor, no CEL light. I verified the codes when unplugged with a Bluetooth OBD dongle.
  4. tankyuong
    1,555
    662
    Central MO
    That’s rare unless someone before you unplugged or destroyed it
  5. Mendel Leisk
    41,990
    Someone's got to say it, probably not but anyway: check for black electrical tape on the display?
    Bay Stater and KK6PD like this.
  6. sbddude
    62
    2013 Prius v wagon
    I ended up taking it to the dealer. It was a missing (not blown) 7.5 A "Meter" fuse. I suspect the smog shop tampered with it so it would fail and I would have to pay anyway. I don't have proof, though. I can't think of any other reason why a fuse would entirely be missing.
  7. padroo
    padroo Senior Member
    2,763
    2,252
    Our emissions test in Indiana are run by the state and there is no charge. Only two counties have emission testing and I live in one of them.
  8. Patrick Wong
    18,210
    6,514
    Do you know for a fact that the CEL light would light up when the car was IG-ON, prior to your taking the car for the emissions test?
  9. sbddude
    62
    2013 Prius v wagon
    No, it's something I didn't pay attention to.
  10. Mendel Leisk
    41,990
    Are you first owner? If not, maybe someone else removed the fuse, to try to pass a test in the past?
  11. sbddude
    62
    2013 Prius v wagon
    I've thought about that, but it passed smog 2 years ago. I've owned the car for 5 years. Maybe the smog place last time missed it?
  12. Patrick Wong
    18,210
    6,514
    Looking at the electrical wiring diagram, I found a 7.5A MET fuse which provides power to the LED that is the check engine light. This is a change from 2G where a different fuse provided power to the CEL plus many other systems.
    #12 Patrick Wong, Dec 16, 2018
