Enable rear camera display while driving forward for 2007 model?
Discussion in 'Gen 2 Prius Main Forum' started by CharlieSamuels, Aug 21, 2010.
  1. CharlieSamuels
    CharlieSamuels New Member
    New York State
    Hi. I'm a filmmaker and I want to be able to turn on the back up camera on the dash while driving forward, aim another video camera at it and record. (while I'm sitting in the passenger seat of course). Better yet - is there a way to tap into the backup cam so I can record directly from that while driving forward? Is there a 'finger dance' I can do to allow this and override the fact that it automatically shuts off while in Drive?
    Thank you and much appreciated! I have a 2007 (2nd gen Prius) I've seen the posts for the 2010 Prius but nothing for the 2nd generation. Sure, I can rig a separate camera to the back of the Prius but the Prius camera is aimed perfectly for what I'd like to do and the fisheye helps my idea as well.
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
    go to Darell's Electric Vehicle Page
    Click on "Prius Hybrid" in the frame on the left
    Click on "Mods" near the top of the page
    Click on "Anytime Camera View" about halfway down the page
  3. Neno
    Neno New Member
    Italy
    i've looking at the Darrell's page but i can't find the 2 wire (purple and gray) on the indicated harness.. I (maybe) found them on anhoter smaller connector on the left but i'd like to be sure about them being the rigth ones (colors are the same, they are just not in the position indicated by Darrell .
    Can somebody help me ?
  4. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    The reverse wire should be pink. You'll have to feed a +12V into the display but it cannot back feed into the harness or else the reverse light will turn on. An On-On switch work best. Common to display unit, Norm Close to the harness and Norm Open to +12V.
  5. CookieGuru
    CookieGuru Member
    104
    Seattle
    2013 Prius Plug-in
    Also, what's another name for "vampire clamp"? When I Google it, I only find results related to this guide.
  6. cproaudio
    2,401
    759
    CA
    I call them scotch locks back in my install days.
  7. CookieGuru
    CookieGuru Member
    104
    Seattle
    2013 Prius Plug-in
    That gives better results! Any idea what the AWG of the wire is?
  8. cproaudio
    2,401
    759
    CA
    As always, pink is 18-20awg, Blue is 14-16 awg, yellow, 12-10 awg. Honestly, I wouldn't use yellow for 12-10 awg. I'd use pink for 18 awg, blue for 18-16 awg and yellow for 14 awg. If you're going to splice 12-10 awg, you're better off, stripping the wire and do a solid connection. As for the reverse wire, I don't know about gen II but my Gen III looks to be 18 or 20 awg.
