Enable rear camera display while driving?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by moazam, Aug 8, 2009.
  1. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    You must keep your hands on the steering wheel in order for it to "steer," a safety function so people don't fall asleep while driving, etc. It won't seem like it's actively steering, but it does nudge in the correct direction and I've had to fight this "nudging" when I forget to activate the blinker while changing lanes.
    Also, it won't "steer" and will only beep if you're traveling below a set speed as specified in the manual.
  2. that.ubercool
    that.ubercool New Member
    Maryland
    Excellent. Thanks.. will give it a shot today.
  3. empcesar
    empcesar New Member
    Va
    Any progress made on this for those without the V?
  4. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    Not that I know of :(
  5. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    It's not illegal to have your rearview mirror blocked. You don't need your rearview mirror to drive legally.
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Here in CA you have to have 2 working rear view mirrors. If you have tinted rear windows, you must have 2 side mirrors. Same goes with panel vans and wagons used for commercial purposes.
  7. teeasal
    teeasal New Member
    420
    50
    ON, Canada
    YES, I did it too. Thanks a LOT!!! I also couldn't finger dance so I tried the headlights and it worked every time. How do you guys figure it out, hmm, must have insider information, eh? Are you sure this is not illegal as in stock trading?
    I'm happy like a kid figured out how to play his toy, but,
    The reverse camera's angle was way too low to see anything further than maybe 20-30 yards away. The cam was staring at the road so closely that the lane markers and turning arrows are zipping by on the screen that it made me dizzy.
    I think it's still quite useful in some rare cases where you load up the cargo area right up to the roof and block the rear windows. I don't think I'd turn on the reverse camera routinely though. Just don't feel comfortable looking at it constantly.
    Ha, I wonder how it looks at night. Would it help brighten up the scenery from the back, reduce the glare of headlights, or becomes dark and snowy and useless. Gotta try it out some nights.
  8. cproaudio
    2,401
    762
    CA
    Got it working today but the top is blocked. I also find it annoying that when it's in the white/green screen the audio is turned off.
  9. Dominic
    Dominic New Member
    Halifax, Nova-Scotia
    ok, i thought this was a neat function, but so many people saying that it was/wasn't working, so of course, i had to try it.
    First of all, i am Canadian, so my model may vary slightly from US/ROW (rest of the world). I have the fully loaded, leather, nav, sunroof package (believed equivalent to IV with NAV).
    I really wasn't feeling the finger dance, so i didn't even try that way. however, holding the INFO button and turning lights off/on once (they were in auto position to start) brought the hidden menu. no need to turn on/off forever, it worked the first time for me. once i was in that menu, the Camera settings button was not greyed out and i was able to access it no problem.
    however, as mentionned earlier, the other "Sub-menus" were actually "Bleued" (not totally grey, but not black either). i tried pressing them like any other settings, but it wouldn't work. you have to HOLD them for about 3-5 seconds and then you are allowed in those menus.
    overall, it worked fine for me. I had a look at the other menus, but didn't feel confortable playing around with anything else though.
    hope that will be helpfull for you.
    Edit: forgot to mention, the camera WILL work while driving like that, however, due to the lines at the top and reduced viewing area, i didn't really like it. but i guess if you can't see because of obstructed view, it's better than nothing!
  10. cproaudio
    2,401
    762
    CA
    Has anyone activate the reverse wire to see if the camera would come on? The top being blocked and the audio disabled is really annoying.
  11. cproaudio
    2,401
    762
    CA
    For those who are still curious, I just did the mod. Behind the stereo there's a gray 5 pin plug, The reverse signal wire is the pink wire. Feeding the stereo with +12V activates the reverse camera. To prevent backfeed to other ECUs, you should cut the wire and use a 2 position ON-ON SPDT switch. The common goes to the pink wire toward the radio, the normally closed goes to the pink wire toward the car. The normally open goes to the +12V source. This mod shouldn't take more than 15 minutes to do. The switch shouldn't cost more than $5.
  12. bisco
    52,849
    this is sweet! is there any way to add machine guns or an oil slick for the guy tailgating me?
  13. Fla Fla Flo Fly
    Fla Fla Flo Fly Junior Member
    38
    Illinois
    Definitely interested in the oil slick mod
  14. Chris2128
    Chris2128 New Member
    85
    Oklahoma
    Hey guys I messed up! I have a v ATP . I was able to get in the service menu. I was messing with "brush" settings and "memorize center and max steering" then I pressed and held display and navi restarted.
    I backed up and screen said system not ready. So I went back to service menu and "reset/clear".
    It still says "system not ready" when I back up. Park Assisit is also not working now.
    How do I fix if?
  15. Chris2128
    85
    Oklahoma
    Here are pics.
  16. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    What are your current settings for these? Might be possible to change back to default and get IPA back to within the correct parameters to work.
  17. Chris2128
    85
    Oklahoma
    I tried actually. And saw another new thing. Watch this video of a European Prius with ATP. It shows "verify mode" when backing up. Yes the yellow box skews when wheel turns ! I got to that setting and the box was skewing with the turns of the wheel but only in setting mode. I pressed display and Nav restarted and same error msg "system not available"
    I don't know what the correct settings are now.
    But do check out this video.
  18. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Chris2128: I believe that error message will go away if you try the auto park, although this will not reset the changes you made to default values. Please let us know if pushing the auto park button clears the error message. :confused:
  19. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    Your photo of the display settings is identical to settings for my V with ATP. Cancel out of the settings by holding The DISP button for about 4 or 5 seconds and push the auto park button and that screen warning will clear. Good luck!
  20. Chris2128
    85
    Oklahoma
    Ahhh thank God ! First I was feelin like :frusty: but then I managed to get it back to normal !! :clap2:
    The auto park button did not help. Instead it gave me 2 strange tones meaning something is wrong with the system.
    My instinct told me that I lost the calibration somehow.
    Later today, I messed with the "verify mode" skew feature calibrated the steering angles . That was the whole trick.
    My suggestion , no one should ever touch the service menu settings again. :nono:
    Here's my 1st ever video for my car.
