Enclosure needed
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ukr2, Aug 31, 2012.
  1. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    I want to mount an enclosure on my lawn lamp post that is near the back of my PIP.
    In the enclosure with be a duplex outlet box with a switch on the left and an outlet on the right. I'll plug my Kill-A-Watt into the outlet. Then I'll plug an appliance right-angle plug into the Kill-A-Watt and the other end for the EV cable. I want to also put the EV cable box in the enclosure with the cable out the bottom.
    So I need a 5" x 5" x 18" to 24" black plastic or baked metal enclosure with cover that I can add a lock. I'd even use a Tupperware tray with cover, if I could find one.
    Any Ideas? I've checked HomeDepot, Lowes, Electrical shops and Craft Shops.
    I need to find it soon so that it's done before the snow comes.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Amazon.com: Intermatic WP1010MC 1 Gang Vertical 3-1/8-Inch Die-Cast Outdoor Box: Home Improvement
    52,509
    an electrical supply house doesn't have a metal nema enclosure that meets your requirements?
  4. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
  5. bisco
    52,509
    nemaenclosures.com
