Energy flow while stopped
Discussion in 'Gen 4 Prius Technical Discussion' started by Kuluz4Dayz, Jun 12, 2018.
  1. Kuluz4Dayz
    Kuluz4Dayz Junior Member
    Hawai‘i
    Four Touring
    I have a 2016 Prius 4 Touring with 17.2k miles. I recently noticed when I’m in drive mode, completely stopped (foot on brake pedal), parking brake off and on an incline my energy flow screen is showing power going from the traction battery to the wheels.
    This only happens when front of car is facing up an incline, like on my 6° driveway. While on flat ground or while facing down a slope and stopped in drive mode the energy flow stops.
    Not sure why it’s doing it. Anyone else have this same issue or is it completely normal and I just didn’t notice it for two years until now? I don’t understand why electric power will be flowing while stopped.
    This occurs when air conditioning is off or on. I don’t think this is Hill Assist related since that function utilizes the friction braking system.
    Today I took the car into the dealer for my routine service and they found no error codes. Another appointment was made so they can further look into it.
    Thanks in advance for any feedback.
  2. Tideland Prius
    16,675
    Press the brake pedal harder. If you lightly (and I don't mean feather light), the car may be stopped but you're not pressing hard enough pass the threshold where the car cuts off the power from the battery to the wheels. What you're seeing can also happen on flat ground.
  3. Kuluz4Dayz
    Hawai‘i
    Four Touring
    I understand what you’re saying but even when I push it harder it still does it. And I’m pressing the break the same way I always did for the past two years. Hopefully it’s an easy sensor fix.
  4. Kuluz4Dayz
    Hawai‘i
    Four Touring
    This is me in drive with foot on brake on flat ground.
  5. Kuluz4Dayz
    Hawai‘i
    Four Touring
    This is me in drive with foot on brake in my 6° driveway. Still sending power to wheels even when I press hard on brake and it only happens when on a hill facing upward. Doesn’t do it while on flat ground or while facing down the hill.
    j12piprius likes this.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    If you put the Energy Monitor on the main display does it agree? I never use that one on the radio (unless I want to entertain passengers).
    Starship16 and Kuluz4Dayz like this.
  7. Kuluz4Dayz
    Hawai‘i
    Four Touring
    Yes the top display also shows energy flowing when stopped on a hill.
    alanclarkeau likes this.
  8. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Could be the hill hold assist feature in Gen 4. It's designed to hold the car in position when you move your foot from the brake pedal to accelerator, keeping the car from rolling backwards.
    Starship16 and alanclarkeau like this.
  9. Tideland Prius
    16,675
    Nah. That just holds the brake pads for 1.3 seconds after you release the pedal. I don't believe it uses the drivetrain.
    That is weird... Hmm...
    RCO and alanclarkeau like this.
  10. prius_deep
    prius_deep Member
    105
    38
    road
    same with gen 2; inclines up and or down, sometimes, not all the time.
  11. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    Ok here's what's going on. If you're in drive, foot is not on the brakes or on the accelerator the car will "creep" just like a regular car would with a automatic transmission... That is perfectly normal.
    If you led the Prius "idle" (for lack of better words) and allow it to roll down the road with no brakes or gas, you might get up to 3-6 MPH and you will see the animation on the energy monitor change from battery to wheels to nothing to wheels to battery.
  12. Fester
    Fester Active Member
    201
    198
    Ohio
    Using a ScanGauge my 2017 Prius 2 will report about .9 amps current drain when either stopped with brake or in park. Fairly typical for what I've seen reported.
  13. Kuluz4Dayz
    Hawai‘i
    Four Touring
    Here’s a better view of what’s going on.
  14. Tideland Prius
    16,675
    Hmm, question. What if you were in normal mode. Does it make a difference? I have a theory that is contingent on your answer.
  15. alanclarkeau
    7,045
    7,593
    That's POWER MODE with the Red background
  16. alanclarkeau
    7,045
    7,593
    The 3 Mode colours:
    RCO likes this.
  17. alanclarkeau
    7,045
    7,593
    This is mine:
    FOOT ON BRAKE, facing UPHILL in DRIVE - [but same in REV, car facing downhill].
    FOOT OFF BRAKE, facing UPHILL in DRIVE - [but same in REV, car facing downhill]
    It is the same whether in PWR, NORMAL or ECO Modes.
    Have you ever had a MALFUNCTION with the Brake Light Switch? [I did and it affected all sorts of things, but was only a single activation at the time - was replaced under warranty.]
    The other possibility. There are vast differences between what TOYOTA does & supplies with Gen 4 PRIUSs in different countries. Maybe it's something to do with the models they send to your country.
    Check with someone else in Hawaii maybe.
    #17 alanclarkeau, Jun 14, 2018
    RCO and FuelMiser like this.
  18. Kuluz4Dayz
    Hawai‘i
    Four Touring
    One morning I think in January I pressed the brake to slow down before approaching a curve and the malfunction triangle flashed and something in the display said something about brake pressure (I think). It went off so fast that idk exactly what it said. I used my Carista app and no error codes came up. Never got that warning again after that.
    And then this just happened last week. Idk if it’s related. I do have an appointment for it next week so I’ll follow up with you guys.
    RCO and Tideland Prius like this.
  19. Kuluz4Dayz
    Hawai‘i
    Four Touring
  20. alanclarkeau
    7,045
    7,593
    Mine was when she was only a few weeks old - iand was 5 months older when I too her for service and mentioned it had MALFUNCTION - she flashed a number or malfunctions but by the time I found something to write on they'd all disappeared. Service looked into the "Vehicle Data Recordings", and at that time there was a BRAKE LIGHT MALFUNCTION - which would have affected many aspects of the car, hence the multiple Malfunctions. They put a new Brake Light Switch on at the following service and it's never recurred..
    RCO and Kuluz4Dayz like this.
