Energy monitor not working. Help please
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lonewonderer, May 4, 2016.
  1. lonewonderer
    lonewonderer Junior Member
    SO CAL
    hello everyone, it is my first time asking here. I need help please. I have a 2010 3rd gen prius. I have changed the supplementary battery at the back because it does not hold charge anymore. Now that i have changed it. I noticed that the energy monitor does not work. The prius car display is there and the wheels are rolling but why is there no arrows coming out of the battery and the engine. Please help. Do i need to reset something? Im getting paranoid about this.
    Thanks a bunch
    Chris
  2. icyrius
    icyrius Active Member
    225
    108
    Florida, USA
    2014 Prius v wagon
    I have a 2011 and recently experienced the exact same problem after shop changed my battery.
    I also posted this same problem here and no one was able to suggest a fix.
    One of the things I tried was pressing the start/stop button a few times to reset the car. But that did not fix the problem.
    There seems to be an electrical bug once these cars hit this age. The new thing I am also experiencing is my radio will stop working and starting intermitently. It is beginning to make me nervous since I only owned my 2011 Prius for 3 months.
    I hope someone knows a fix for this problem.
  3. Joost78
    Joost78 New Member
    zwolle
    Just came back from the dealer with same issue. The issue was that previous owner/dealer forgot to reattach the temp sensor on the 12v battery! And the reset the car and it worked like a charm. Hope this helps
  4. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    Whoa there's a temperature sensor on the 12V battery?
  5. Joost78
    Joost78 New Member
    zwolle
    FuelMiser likes this.
  6. Mendel Leisk
    38,314
    I'm wondering: did they reconnect a temperature sensor AND do some general reset, say with Techstream software??
  7. icyrius
    225
    108
    Florida, USA
    2014 Prius v wagon
    FINALLY FIXED!!!!! There is no need of any reset. I just completed the procedure. It literally takes less than five minutes. You need to stick your hand behind the battery to reach the cable with the temperature sensor attached to it. As soon as you start the car, the arrows begin to show again.
    Thank you so much for providing the solution!!!!
    FuelMiser and Mendel Leisk like this.
  8. Underfoot
    Underfoot Junior Member
    michigan
    2011 Same problem after unhooking positive for simple reset. I must have bumped the sensor compromising the connection. I did not disconnect it.
    Arrows disappeared as leaving driveway and hit a bump then came back on after 2 miles then off again
    I feel there must be some corrosion making the connection suspect.
    The connector looks as it sounds” just a connection” were in this system is the sensor?
  9. TerryP
    TerryP New Member
    Mission Viejo
    Check the sensor on top of the 12-volt battery (auxiliary battery, not the hybrid battery). It is attached to the battery holding bar and connected to the 2-wire connector running to the back to the inside trunk
  10. JPalmen
    JPalmen New Member
    Groningen
    Thank you Joost78.
    I recently bought a Prius, and I had the same problem with my car. It turned out that the cable of the temperature sensor at the 12V battery was not connected to the sensor.
    After connecting the sensor cable and starting the car, the energy monitor was showing everything as it should be.
  11. StlLewis
    StlLewis New Member
    St. Louis, MO
    I created an account just to say thank you for this info as well. The 12v battery was drained and after I charged it up the energy monitor wasn’t showing any “flow” in any direction. I was afraid I would have to take it in to the dealership and pay $5000 for a new hybrid battery because of something I messed up when taking care of the 12v battery. There was the disconnected cable, right on top! I plugged it in and everything is working perfectly now!
  12. Mendel Leisk
    38,314
    Did you remove the battery to charge it? I appreciate Toyota cautions to do this, but I believe it’s mostly liability issues that are behind that: ours is near-constantly on a smart charger while fully connected, even have a quick-connect cable wired in for the purpose.
