Energy Saver vs Energy Saver AS
Discussion in 'Gen 3 Prius Main Forum' started by mark lybarger, Feb 6, 2018.
  1. mark lybarger
    mark lybarger Junior Member
    Clearwater, FL
    I need replacement tires at 45k+ on my 2015. Energy Saver A/S seems to be the tire of choice, but I can't find a set anywhere. I've been looking for weeks. There's plenty of Energy Saver tires (which cost about 20 more per tire). I can't find info on what the difference is. I live in central Florida where our seasons are Mild, Hot, and Hotter. I'm not concerned with "All Season" tires. I am concerned with loosing some mpg. The original Ecopia EP20 seemed average at best.
  2. Mendel Leisk
    42,368
    Just for a "data point", I'd say the EP20 are pretty good for rolling resistance, the Energy Saver (A/S or not), would probably edge them out, but not by a lot.
    Situation is similar up here, Costco has Energy Saver, but not the A/S iteration. Is it just me, or does Michelin seem to be "mailing it in" these days? o_O
    Merkey likes this.
  3. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    Use TireRack if you can't find what you want locally:
    Michelin Energy Saver A/S | 195/65R15
    I've used the TireRack process and it works very well. Heck, I even used it to get the Energy Saver A/S because I couldn't find it locally. :)
  4. mark lybarger
    Clearwater, FL
    Thanks i checked tirerack. They have less than 2 in stock. difference between energy saver vs a/s?
  5. Quattro
    Quattro Member
    60
    28
    Silicon Valley, CA
  6. Mendel Leisk
    42,368
    Without it means "summer" tire, fwiw. It is distinct tread, proceeded the A/S version, and has a similar LRR pedigree, though not sure which could come out ahead.
    Bay Stater and m.wynn like this.
  7. bisco
    52,886
    probably fine in florida.
  8. Markdizle
    Markdizle Member
    110
    76
    Huntington Beach
    I have ecopia 422 Plus and the mpg is outstanding, never before have I seen a 55mpg average for the tank in my Prius. Same driving style and commute just the tires are different. Inflated to 42 F and 40 rear. And it’s winter.
    m.wynn and Merkey like this.
  9. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Agree, the Ecopias (both EP 20 and 422) and the Energy Savers (I've got the A/S at present) are the best rollers out there with no clear best between them. Not sure any of the other LRR's are even close.
    Markdizle likes this.
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    like 0 F winter or 34 F winter there?
  11. Markdizle
    Markdizle Member
    110
    76
    Huntington Beach
    50 F winter here in Newport Beach, CA
  12. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Wouldn't the Energy Savers be a much quieter tire?
  13. Mendel Leisk
    42,368
    EP20 get pretty noisy when worn. Not untenable, just saying.
  14. m.wynn
    684
    1,230
    Queensbury, NY
    In my experience with the 422, it was as quiet as the Energy Saver with the same, borderline ridiculous mpg. Very similar feel and sound between the two. Noise level with the 422 never got bad toward the end but maybe I just didn't run them down enough. Only about half way through my Energy Savers so can't comment on if they get loud toward the end. Overall, I'd give the nod to the Energy Saver, but I'm admittedly partial to Michelin.
    #14 m.wynn, Feb 8, 2018
  15. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    I went to Costco today to order a set of Energy Saver A/S since this is the last day of their Michelin sale. After he made two phone calls he told me Michelin has discontinued both the Energy Saver and the Energy Saver A/S. Is this the case? Any quick suggestions on which route to go? I will also look at other threads here.
  16. Mendel Leisk
    42,368
    Maybe blowing smoke, as is often the case when they really want to sell what's more readily available, and/or in stock. Just went to Michelin USA, described my 2010, said it had 15" rims, and the first result was Energy Saver A/S. OTOH, no mention of the version without A/S (summer version).
    Sites-michelin-us-Site
  17. PA Prius
    762
    251
    SE Pennsylvania
    Interesting. I tried contacting them via Chat, but their office is closed for today. Btw, TireRack also told me they have been discontinued in my size.
  18. Mendel Leisk
    42,368
  19. PA Prius
    762
    251
    SE Pennsylvania
    I see they are still available via DiscountTire. I went ahead and ordered the Michelin X-Tour through Costco. Not the best RR, but the 80k warranty and $404. price (incl. mounting and tax), seemed right.
    Merkey and Mendel Leisk like this.
  20. Mendel Leisk
    42,368
    That would be my pick in 15". (y)
    PA Prius and Merkey like this.
