Engine always running
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by flamebird, Jan 17, 2013.
  1. flamebird
    flamebird Junior Member
    Australia
    Hi everyone,
    I have a Prius C with 10,000km / 6,200mi. It recently developed an intermittent issue where the petrol (gas) engine does not shut down at times when the car would normally be in EV mode (downhill coasting, stationary, etc). This does not happen every time, but only on around 50% of trips.
    Once the problem occurs, it will continue until the car is completely switched off, regardless of how long the trip is. If I restart the vehicle, the issue will sometimes disappear. I have been in the car driving normally for well over an hour, and the engine has not turned off the whole time. As a result, fuel economy is suffering.
    As it's still under warranty, I will be taking it to the Toyota dealer. However I thought I'd see if anyone else had seen this issue, or if anyone knows what the cause might be. Thanks!
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Is the heater on? See Why mileage gets worse in winter | PriusChat, under the better heater management section. Yeah yeah, I realize it's summer over there.
    On the Gen 2 Prius, at above ~42 mph, the gas engine must run. I believe on yours, the threshold might be 46 mph. There are others reasons for it to run, such as low HV battery charge and to warm up the catalytic converter (if the engine's cold).
  3. flamebird
    Australia
    Hi cwerdna,
    The heater is off - when the problem occurs, the engine will run whether the heater or A/C is on or off. This definitely isn't the normal behaviour you describe - as you said, the engine will run to charge the HV batter or warm the catalytic converter. However when this problem happens (not every time, but around 50% of the time I drive), the engine will run 100% of the time, no matter what the state of the battery is. I can come to a complete stop, with the battery showing full charge, and the engine will run indefinitely.
    Dearler update: No error codes have been recorded and the dealer tried to say there was no issue, and it was just normal operation. I explained that I am aware of what the normal behaviour is, but that on some trips, the engine will just run 100% of the time and never shut off (until the car is powered off).
  4. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Could the 12v battery be shorting or something else that is causing a large continuous power draw?
  5. flamebird
    Australia
    It's possible - is there any way to tell if this is the case? The problem comes and goes, unfortunately, so it's difficult to do testing/diagnosis.
  6. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    You can try a simple check of the 12v battery voltage with a volt meter. Make sure the car has been sitting off for at least 6hrs.
    You can have the battery tested by the dealer or independent auto parts store.
    It's worth a shot before you go after the dealer. :)
  7. flamebird
    Australia
    Thanks F8L, I'll get this tested!
  8. CMJAnew
    CMJAnew Junior Member
    87
    17
    Being mechanically challenged, I would ask you to explain the relationship between the 12v battery voltage and the ICE not shutting down. Thanks
  9. flamebird
    Australia
    Frustratingly, the dealer tried to give me a lecture on how a Prius works because they could not replicate the issue. I explained to them that it's not normal for the vehicle's engine to run non-stop for an entire trip lasting over an hour. However I do understand that since they couldn't observe the problem, they couldn't do much.
    There doesn't appear to be any voltage problems causing a high draw, and there are no error codes recorded.
    The issue hasn't happened again since last week, so all I can do is wait. For now, it remains a mystery.
  10. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Are you driving many short trips? The Ice needs to run to warm the converter up. What is the MPG you are getting?
  11. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Were you making a lot of very short trips prior to the incident? Maybe the hour long trip charged the battery back up?
  12. flamebird
    Australia
    Hi JMD - I'm familiar with the time required to warm the catalytic converter, this incident has occurred multiple times on several long journeys. At other times, the car operates normally.
    Hi F8L - It happened several times over the last 2 weeks, after both long and short trips. For example, I took a long (45 minutes) drive, the ICE was running 100% of the time. After restarting the car, the problem continued. It seemed to happen regardless of HV and 12v battery charge.
  13. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Ok. Well that would rule that out then.
    Does anyone remember what the ECU problem was on the earliest c? I seem to remember someone having an issue with poor fuel economy and I thought it was similar to this.
  14. JMD
    3,779
    1,282
    Perhaps the computer that controls the Ice and battery management is malfunctioning. Try a different dealer. What is the MPG? Is it off plenty? That may be where the conversation starts.
  15. ufourya
    ufourya We the People
    1,258
    336
    42
    There is something I haven't seen mentioned here. Is there any possibility that you are travelling with anything in the rear footwell that might block the air intake that keeps the main battery from overheating? I understand when this happens the battery ceases to operate normally and ICE runs full tine.
  16. Gcoop
    Gcoop Member
    156
    79
    niagara region ontario canada
    i was going to say the same thing as above
    i remember another poster here having a problem where the engine wouldnt go into ev
    problem was there was something in front of the vent in the back seat
    Oic120, flamebird and RocMills like this.
  17. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    While on the idea of a hot (temperature) high voltage battery, possibly the cooling fan under the back seat does not operate.
  18. flamebird
    Australia
    It looks like you folks may have been on to something! I located a plastic shopping bag that was firmly lodged against the vent, partially blocking it. Thank you all for suggesting this! I had no idea the vent was there.
    I'll see if the problem goes away and report back.
    Rob.au and RocMills like this.
  19. ufourya
    1,258
    336
    42
    You're welcome! I'm betting everything will get back to normal.
    flamebird likes this.
  20. flamebird
    Australia
    Just a quick update - the car has behaved normally since I removed the blockage. We are expecting some hot weather this week, so it will be a good test. I'm confident the problem is solved, thank you all again.
    On a related note, it's disappointing the dealer didn't think to check the HV battery ventilation after I reported this issue!
    RocMills, Rob.au and cwerdna like this.
