Engine and inverter coolant
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Functional, May 12, 2022.
  1. Functional
    Functional Junior Member
    Hello.
    I have a 2015 Prius with 68k miles. I am the second owner.
    The engine and inverter coolant are close to the low mark. I don’t suspect any leakage.
    Engine coolant and Inverter coolant replacement is suggested at 100k/10 years.
    Best way to check for leaks?
    And if there are no leaks, should I just top off? Or do the replacement and fill early?
    Thanks
  2. Mendel Leisk
    42,352
    Just top up. Ours was at the low lines (both), around 5 years in, happened very gradually. Topped them up and they stayed there, till I did a change at 10 years.
  3. Functional
    I just performed a top off.
    just realized that I didn’t need to add much on the inverter and engine coolant…. Used about half a quart…
    was this a waste of a new gallon of coolant?
    #3 Functional, May 12, 2022
  4. Mendel Leisk
    42,352
    Hang onto it till the 10 year or 100k mile engine coolant change and it’s not.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Look for pink spots or runs. The coolant dries pink. But, as others said, it might not be leaking. Some cars have a little of it disappear.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,603
    Taylors, SC
    I'd just change the coolant. The quality of the coolant affects the head gasket and many othe components that it contacts. You don't know how the car was used and driven. Coolant is cheap compared to a head gasket replacement. Worn out coolant can degrade the head head gasket. 10 years or 100k miles is too long.
    Foxglove and nicoj36 like this.
  7. nicoj36
    nicoj36 Active Member
    518
    162
    Just drain the old fluid out and replace with new.
  8. Mendel Leisk
    42,352
    OP’s coolant levels dropped maybe 20 mm’s in the reservoirs, over maybe 7 years of ownership, he’s topped them up, and now he should replace both? When Toyota USA says 10 years or 100k miles (for engine coolant) and 15 years or 150k miles (for inverter coolant)?
  9. Georgina Rudkus
    3,576
    2,603
    Taylors, SC
    I just came home from my local Walmart.
    Red Asian coolant is chreap right now at WalMart. It is Toyota SLCC equivalent. $9.97 for Peak on clearance. $10,97 for Super Tech store brand.
    It better to be absolutely safe for at least the next 5 years.
