Engine behaving strangely and popping hoses off intake manifold
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by anonymous, Jan 13, 2019.
  1. anonymous
    anonymous Member
    177
    99
    US
    Hey, that looks like the issue!
    https://attachments.priuschat.com/attachment-files/2015/10/96212_T-SB-0041-15.pdf
    So their repair procedure is to replace the "Purge Vacuum Switching Valve Assembly" (that's this thing right? also known as canister purge valve?) and reprogram the ECU with the "latest calibration" (so like update the software?).
    So hmm, I don't see how a malfunctioning EVAP purge valve could cause enough pressure to blow hoses off... I don't think there could be that much pressure in the EVAP system, and even if there was, the gas cap has a pressure relief valve.
    But what might make sense is that there's a software bug that's triggered when the purge valve malfunctions… which caused it to do something to the engine that made it pressurize the intake… The ECU can adjust valve timing, right? So maybe it could have not fully closed intake valves before ignition or something like that.
    If it is a software bug caused by a faulty purge valve then that would make sense with the repair procedure: replace the faulty valve, and fix the software glitch caused by said valve. If that is true, then, in my case, changing the faulty valve should fix the issue. As long as it functions properly, the software should function properly like it originally did and professional calibration may not be worth the cost. BTW, if the software is updated as part of a recall, would that include the updated calibration that fixes this issue? There's another recall for our vehicle involving a software update (forgot what it was about); maybe that'll fix the (potential) software bug too. Yeah, we need to get that done; keep forgetting...
  2. anonymous
    anonymous Member
    177
    99
    US
    So about that EVAP leak… I made a crappy smoke machine to pump into the EVAP system and saw smoke coming out from the fuel cap area. It couldn't be the fuel cap again, it's brand new and seals tight. So it must be something else near it. I found and removed the panel covering the filler neck in the wheel well and had a look. There's this plastic thing clamped around the filler neck; it snaps together but the snap thing is broken so it is split and loose and I can twist and slide it all around. This is part of the EVAP system, for reclaiming vapors from the filler neck? It was caked with mud so I washed it out. I guess I could just strap it together, but I would want to take it off because dirt and water has probably got inside.
    mjoo, Mendel Leisk and Robert Holt like this.
  3. Mendel Leisk
    41,457
    That's brilliant. (y)
    Sounds like good to check this periodically.
  4. anonymous
    anonymous Member
    177
    99
    US
    So I got that plastic thing out… and it's just some sort of air filter… between that tube and the outside air. There's no hole in the filler neck itself, it's just smooth. :confused:
    This plastic thing has the metal tube going in to one side of the filter, and the other side is connected to a couple of small holes at the bottom, and a large hole on the inside of the collar.
    So besides discovering what this thing is I achieved nothing. Oh well, need to test further. thonkang copy.png
  5. anonymous
    anonymous Member
    177
    99
    US
    Ok so I believe that is the input of the fresh air line which I reckon is needed to let air in when purging vapors into the engine intake. I did a leak test using the blower end of a vacuum cleaner. Air blew out of that tube.
    So looks like the "canister closed valve" has failed to close; either it broke or maybe the rodents finally chewed some wires! Or maybe it's the "fresh air valve" but that doesn't appear to be an active component?
    This document is helpful, though it's for 2nd gen so a lot of things are different. https://priuschat.com/attachments/prius-fuel-and-evap-pdf.51790/
    #25 anonymous, Jan 20, 2019
  6. Mendel Leisk
    41,457
    google 77745-48020 (from pic) indicates it's:
    Filter, charcoal canister, number 1
    See from PDF you posted above it's the filter for the charcoal canister proper, which is down lower.
  7. anonymous
    anonymous Member
    177
    99
    US
    I tore down the under panels and followed the fresh air tube.
    First it goes to a boxy thing in the corner. (77746-47010)
    Then another hose comes from that and goes to a square thing plugged into the socket of a cylindrical thing. It also has an electrical connection.
    Another hose comes from the other end of the cylindrical thing to a rectangular thing.
    The rubber hose in the middle looks like the one that goes to the engine (where I tested from).
    The other hose goes somewhere over the gas tank.
    I was confused what these things were but after some research I think the first boxy thing is the "charcoal canister filter" (so another filter after the first one up top), then the assembly with the rectangular thing and cylindrical thing together is the actual charcoal canister assembly. It's not clear what each part exactly is but I guess the rectangular thing is the charcoal canister, and the boxy thing attached to the cylindrical thing with the wires connected is the "canister closed valve". do not know what the cylindrical thing itself would be then. I also wonder where the leak tester thing is, the one that makes the mysterious noise a few hours after shut down.
    So I guess tomorrow I'll debug what I presume is the valve.
    mjoo, Robert Holt and Mendel Leisk like this.
  8. Mendel Leisk
    41,457
    I'm a little slow on the uptake; here's some third gen charcoal cannnister info. I extracted this a while back, haven't read through it really. There might more info, so lemmee know if you're still drawing blanks; I could look for more.
    anonymous, Raytheeagle and gliderman like this.
  9. anonymous
    anonymous Member
    177
    99
    US
    Thank you that helps a lot.
    Ah ok so that plug-in thing is the leak detection pump.
    HMM, the inspection process involving the fresh air inlet and purge port indicates that they are supposed to be pneumatically connected by default. The "purge port" is what I believe goes straight to the engine and is where I was pumping smoke or air from.
    Does that mean that the EVAP line in the engine bay upstream from that purge valve is SUPPOSED to be always pneumatically connected to the air inlet filter around the gas cap? So I'm testing it wrong? So then that must mean that this guy was testing it wrong too?
    But hmm, if that unit is the leak test pump, the cansiter closed valve must be before it so it can pressurize the system. So it must be part of the unit.
    And... according to the 2nd gen document, the canister closed valve is normally open! If that is so then it must be true; the purge line is "normally" connected to fresh air, so you cannot do a leak test there because the air or smoke will just always come out of the gas cap area, making you think it's a bad gas cap!
    You know what… I am thinking this EVAP leak is the same issue as what caused hoses to pop off (instead of thinking the pressure blew a hose in EVAP system): a bad purge VSV (next to the intake manifold) as suggested by the TSB for the explosive hose issue. I think it's stuck open now. In that case, while it's open when it's not supposed to be (it's normally closed), it causes a vacuum leak by letting fresh air from the fresh air inlet through the charcoal canister. And of course during a leak test after parking, all the pressure is lost into the intake manifold. But assumedly when the valve is supposed to be open everything is normal as the ECU compensates for the vacuum-leak-like EVAP purging.
    I did clamp the purge line though; that should've prevented the P0455. Maybe it didn't seal well enough… or maybe it decided to finalize that DTC anyway, along with P0441 which is expected.
    I am going to go straight to that valve and inspect it.
    Edit: ah damn it's raining :(
    Edit 2: but that won't stop me :sneaky:
    #29 anonymous, Jan 20, 2019
  10. anonymous
    anonymous Member
    177
    99
    US
    Ok so I got the valve out. It wasn't stuck open but repeatedly testing it with a 12v battery revealed that sometimes it would stick open. When stuck, it could be unstuck by a tap, by blowing a large enough volume of air though it, or by reversing the polarity.
    I did rinse it thorougly with isopropyl alcohol and tested/dried it on the blower but it still occasionally would stick while the vast majority of the time it worked fine.
    My father wanted to get a new one to be sure so I found one and let him buy it but it will take a long time to ship :(
    But since that's ordered I cracked open this valve with a hammer to see what is inside.
    IMG_3363.jpg IMG_3372.jpg IMG_3371.jpg IMG_3382.jpg IMG_3383.jpg IMG_3385.jpg
    Inside there is a magnetic slug on a spring on a plastic pivot piece in the solenoid body. The spring pushes the slug with the seal on top against the top piece, and the solenoid pulls the slug down when powered. There's a broken filter screen in front of the inlet port. The valve parts itself look perfectly fine, though; there really isn't anything that can go wrong. I guess it was sticking because of gunk or fluid. A thorough cleaning (and maybe lubrication) of the solenoid bits would probably prevent it sticking. Unforunately the unit isn't serviceable; you have to smash it open with a hammer and then glue the top back on. But maybe it could be cleaned or lubricated well enough without opening. Maybe a squirt of WD-40 would solve it. Unless it's sticking because of fluid sealing a vacuum behind the slug. In that case you'd have to thoroughly dry all fluids after cleaning it. But whatever, we ordered a new one.
    gecko, SFO, wheezyglider and 3 others like this.
  11. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    You can get a pirated TechStream from eBay for about $20. You need a laptop with an older version of Windows. I just bought an old junker laptop, without Internet connection, which is my “TechStream” system. $90.
  12. anonymous
    anonymous Member
    177
    99
    US
    Ok so the new valve arrived a week later (Jan 28) and I installed it. Since then there have been no more issues so that marks the problem fixed :)
    So if you are having your engine behaving strangely and popping hoses off, your problem must be that your EVAP purge valve is sticking in the open position. Because the EVAP system is, apparently, normally connected to fresh air, it causes an unmetered intake leak which screws with the ECU. It is in this vacuum leak condition that at some point, somehow, a high positive pressure in the intake manifold blows either the PCV hose or the EVAP purge hose off, creating an even larger intake leak that really screws with the ECU, such that it soon gives up trying to operate the engine, throwing a P3190 and forcing you to pull over.
    Who knows how it blows hoses off?? One thought I had is it causes a software glitch in the ECU to adjust things to pressurize the intake. Another thought is a fuel vapor explosion, but I can't see how that could happen. Oh well, at least we know the cause.
    So your solution would be to either change the valve with a new one, or maybe try fixing it yourself. It's a simple device and there doesn't appear to be anything to fail; I think it sticks because of residue collected over time that needs to be cleaned out. While it's not serviceable, you can break the top off cleanly by pounding the sides of the seam against a hard surface with a mallot (or maybe a vice would work if you have one). Then you can thoroughly clean all the parts and reassemble. The top fits back on snugly and has a porous edge so I think it would glue back together well with epoxy or something similar.
    Thanks to @EBATX for mentioning TSB-0041-15; that was most helpful to pinpoint the exact issue.
    Perhaps the past similar issues were also caused by a sticking valve. Maybe there never was a leaking gas cap, and the only reason I felt air blowing out when testing for leaks with a blower was because I tested upstream from the purge valve, and the canister closed valve that is used for the system's own leak testing, is normally open, and the fresh air inlet is right around the gas cap. The previous time when we thought it was a loose gas cap was also odd, but went away at some time after tightening it again which probably might've just been the valve un-sticking with some vibration. The first time I heard the engine behaving strange, went away before the MIL was presumably going to be triggered.
    So yeah, if your engine has randomly started to run strangely but then later randomly stopped, it was also probably because the EVAP purge valve stuck open. And it would probably occasionally get stuck again, causing what appears to be any of several different strange issues. Strangest being popping hoses off the intake. :confused:
    broski, gecko, SFO and 5 others like this.
  13. protrex
    protrex New Member
    Southern Indiana
    Oh. my. god - THANK YOU.
    2010 Prius w/ ~256k on it.
    I've been having weird surging issues intermittently for the last two months and have been ripping my hair out looking for an answer. Normally the car wouldn't say anything was wrong (no codes) but it would typically happen during my 33 mile commute.
    Drive 20 miles at 55-65 consistently on a 2 lane highway from my rural home, to closer to the city.
    When I get into the first town I hit a school zone and the speed limit drops to 30mph, I slow down.
    The engine would surge from ~900rpm to ~3000rpm and back down instead of the engine shutting off.
    It seemed like when it tried to idle, it would freak out instead of shutting down the engine.
    You could hear the engine surging up and down the entire remaining duration of the commute when I slowed down. If there was traffic on the interstate, I would hear it while sitting in traffic. I would hear it on Louisville city surface streets when stopped at traffic lights. The car seemed fine when at full speed (RPMs higher than 1200).
    This would not happen consistently, which made it a nightmare to troubleshoot. For example, driving 20 miles on the weekend after doing "repairs" would rarely cause the issue to reoccur.
    At one point the car produced a P0171 Too Lean Code, so I tried.
    Originally I tried:
    - New Fuel Pump
    - New Fuel Injectors
    - New Intake Manifold Gasket
    - New Upstream AFR (O2) Sensor
    I eventually got a Bluetooth OBD2 Scanner and Torque for my phone, which clearly showed me it was a vacuum leak... from somewhere. The vacuum meter would shoot up when the issue occurred. I spend over an hour with the car in Maintenance Mode (often idling fine) with a can of brake clean (and a propane torch) trying to find the leak, but was unsuccessful.
    I had replaced the PCV valve and installed an oil catch can last year when I bought the car at 241k miles. I removed the catch can. Issue still reoccurred.
    Last week, believing the issue was the PCV I replaced the PCV... No dice.
    Next, as a hail mary, I capped off the PCV intake on the mainfold and ran the output of the PCV into the oil catch can with an external breather. This seemed to work, for about a week, when the car decided it wanted to freak out again this morning on my way into work.
    When I ran Torque, I found I had a pending P0171, P0441, and P0455 code that had not yet thrown a CEL. I had seen Evap codes in the past, but I assumed that it was due to me unhooking Evap components during my repair attempts.
    I searched around the 3 codes, and found this thread I had not found before. THIS MAKES TOTAL SENSE. I know that this Evap solenoid is connected directly into the intake and would cause a vacuum leak if it gets stuck open.
    The local dealer has the part for $95, in-stock, I will pick it up on my way home and install it tonight. Then I will carefully monitor and pray that my months of trouble are finally over. I will update if it does.
    Atleast the car never left me walking..... but the constant surging has not done wonders for my fuel economy.
    Raytheeagle, anonymous and Rebound like this.
  14. protrex
    protrex New Member
    Southern Indiana
    So I got out to my car yesterday after work and started it up. When idling with the A/C on to cool it down, it was stuttering and fuel trims were off and the vacuum pressure was pegged out via the Torque app. I shut the car off, opened the hood, used my patented Harbor Freight emergency socket set that I got for $5 on a coupon and threw in the trunk of the car at some point last year to remove as much of the airbox as I could.
    I got the airbox out of the way enough to whack the Evap solenoid with the back of the ratchet handle a few times. I then put everything back together and restarted the car... the car then idled smooth without any weird fuel trim issues.
    I then drove to the dealer, bought the Evap Solenoid (for $95!) and went home and installed it, reconnected my Oil catch can to the intake, and cleared codes.
    After a 40 mile drive last night and my 33 mile commute this morning, everything seems perfect. Power seems great, no surging, no stuttering, and the engine starts and stops smoothly. Of course this issue was so sporadic that it could reappear at any time, but I'm confident it won't... Time will tell and I will update. Also, no codes for EVAP problems are present in the computer and EVAP tests were marked as completed.
    I did notice that this issue would occur more often when the car was low on fuel. It occurred yesterday when I had 3 bars left. I am assuming (I may be totally wrong) that when the fuel is lower, there is more room for gas fumes to evaporate off and fill the space within the tank, these are then purged off via the solenoid into the intake. If the ECU is purging the system more often, there is more of a chance that the solenoid will stick and wreak havok.
    Looking good so far, we'll see how it progresses. I need this car to be solid for the next month since I'm planning on driving it to Arizona in June and back. If I can't rely on it, I'll need to take another (much less efficient) vehicle.
  15. gliderman
    gliderman Active Member
    751
    225
    protrex, what is the part number for the Evap Solenoid you replaced?
  16. Mendel Leisk
    41,457
    #36 Mendel Leisk, May 16, 2019
    Christopher Hunt likes this.
  17. gliderman
    751
    225
    Thanks Mendel Leisk! Sounds good. Now where does it go? Any parts diagram?
  18. Mendel Leisk
    41,457
    Pretty sure it's just to the right of throttle body, a little further back.
  19. Mendel Leisk
    41,457
  20. Rebound
    3,996
    2,644
    Portland, OR
