Engine Block Heater Question
Discussion in 'Gen 3 Prius Main Forum' started by djlen, Dec 7, 2011.
  1. djlen
    djlen Junior Member
    68
    Somerdale, NJ
    How difficult is it to install? Can it be done by the average guy? Looks a bit complicated looking at the instructions on line.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    It is not complicated, but it can be tricky only because the space you're working in is a bit tight, so it takes some patience to find the spot and get the thing in there.
  3. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    IMHO, the simplest way is to remove the windshield wipers, the motor, and the tray at the base of the windshield. This provides enough room to access the hole in the block from above. I did mine when I installed my strut tower bar.
    Removing the wiper hardware & tray isn't very difficult. See the instructions here:
    http://priuschat.com/forums/gen-iii-2010-prius-accessories-modifications/88655-tanabe-sustec-strut-tower-bar-under-brace-diy-installation-pix.html
    There is one trick: a wire harness behind the engine needs to be moved. See the instructions here:
    http://techno-fandom.org/~hobbit/cars/bh3/
  4. djlen
    djlen Junior Member
    68
    Somerdale, NJ
    Looks a little too much for me. I don't want to screw anything up with my new Prius.
  5. Dark_matter_doesn't
    692
    151
    Seattle, WA
    I can say I felt the same way, but I've worked my way up from smaller things (like oil changes) to bigger jobs like suspension mods. Look at the instructions and think about it - your confidence may grow with time.
  6. pederson80
    pederson80 New Member
    Cambridge, Wi
    I am no master with tools and I did mine. I would suggest giving yourself 3 or 4 hours and buy all the tools first. A very long extension to remove the wire harness bolt for example. All you have to do is feel around for the hole and you should find that no problem too. It's no big deal if you allow yourself plenty of time. Just make sure to follow those instructions exactly and you'll do fine.
  7. djlen
    djlen Junior Member
    68
    Somerdale, NJ
    I'm thinking about it. Maybe not this Winter, but I might do it in the Spring for next Winter.
  8. Qyota
    Qyota Junior Member
    Bemidji, MN
    Thanks for the helpful links! I just purchased one, so I hope to install it in the coming weeks.
  9. Mare1083
    Mare1083 New Member
    Illinois
    Would it be difficult for someone who is experienced? My husband is a Saturn/GM technician, but doesn't have any experience with the Prius.
  10. djlen
    djlen Junior Member
    68
    Somerdale, NJ
    Mare, if your husband is a technician/mechanic I don't think it would be a problem for him. I don't think it's all that complicated or I wouldn't even consider doing it myself.
    I'm sure others will chime in on this for you.
  11. Dark_matter_doesn't
    692
    151
    Seattle, WA
    With his experience and the info on this forum about installing the block heater, he shouldn't have any big problems. There will be some learning curve with any new vehicle. Have him look at the links I gave above and then look at the engine compartment.
    Elsewhere on this forum, you or he can find a complete set of maintenance documentation for the 2010 Prius. That should help overall.
    The neat thing about the Prius is that it needs significantly less maintenance than most any other car.
