Engine Braking, is it possible to over rev the engine?
Discussion in 'Prius v Main Forum' started by wstt, Jul 11, 2013.
  1. Mendel Leisk
    42,347
    I can't see slowing for curves via cruise control. I'm sure it can be done, but I'd much rather touch the brake (disabling cruise) and take over control myself. FWIW, when you use the brakes you're typically not actually applying the brakes, anyway: it's still mostly regen that's slowing the car.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    And when hitting the brakes, you have the added benefit of actually warning your fellow drivers you are slowing. (Yes, rear ending you will technically be their fault, but it is much better not to bend all that sheet metal)
  3. thymara
    thymara Junior Member
    59
    Edmonton, Alberta
    2020 Prius Prime
    Common sense suggests that whatever action you undertake you do so with the full awareness of what is happening around you. I recently had a semi so close behind me that all I could see was a small portion of his grill, he could not possibly see what I was doing. I quickly changed lanes so he could tailgate the traffic in front of me.
    It is perfectly acceptable to use cruise to slow down and it is equally acceptable to slow down using braking, based on traffic conditions. Failure to understand traffic conditions may result in bad things happening and your fault or not, dead is still dead.
  4. fuzzy1
    10,707
    That link is specifically for the GenII Prius. Different gearing shifted the magic speed up to 46 mpg in the GenIII Liftback. Magic speed shifted again for the 'v' and 'c'. While the concept is still the same as in GenII, I wouldn't use this link as a reference for the specific speed in other models.
    thymara likes this.
  5. Jzerocsk
    Jzerocsk Member
    108
    31
    Is any fuel being used at all? I would have guessed that just like coasting in gear in a stickshift, the wheels are turning the engine and no fuel is burned. I guess that's something else that could be confirmed with a scangauge.
  6. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The fuel is shut off to the ICE in several different circumstances. One of those circumstances is during engine braking, which also includes changing the valve timing to reduce stress on the engine.
  7. Mendel Leisk
    42,347
    I'm not really sure, just suspecting the engine can't be rotating without some fuel being burnt. ScanGauge does have some setting (Gallons per Hour??) that might show.
  8. thymara
    59
    Edmonton, Alberta
    2020 Prius Prime
    my scangauge quite often shows 0.2 l/100k while the computer is showing 0.0. I guess it's a question of which instrument is actually correct
  9. econo-one
    econo-one Junior Member
    Lake Tahoe, Nevada
    My scangauge indicates that fuel is being consumed when using engine baking. I have a 2016 Prius. The MPG seems to vary between about 50 and 100 mpg. Maybe my scangauge is pulling my leg?
    mtuck likes this.
  10. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    That'll depend on circumstances, engine temp, etc.
