Engine Break In?
Discussion in 'Prime Main Forum (2017-2022)' started by Piwacet, Mar 20, 2017.
  1. bisco
    52,862
    not sure on the gen 4, on the gen 3, you would use one of the trip meters and not reset it. i think it's called the ratio screen
    the transaxle needs nothing, but some like to change the oil at 5,000 miles.
    if you stay at or below the speed limit, varying the speed a little bit, you'll be fine.
    keep in mind, you're not the first to break in a car, there's nothing to worry about.
    GT4Prius and Mendel Leisk like this.
  2. CharlesH
    2,798
    1,166
    Roseville, CA
    It seems that only the engineering types like those who frequent this forum would be able to "properly" put the ICE in a Prime through the designated break-in process. Toyota really cannot expect the average owner to go to the appropriate MFD entry to accurately determine actual ICE usage and go though special steps to exercise the ICE at the appropriate RPM. The process for a conventional dumb ICE are reasonable to expect an average owner to do, but not for this computer system on wheels.
    IMHO, anyway, speaking as one of those geek types.
    jtv likes this.
  3. Mendel Leisk
    42,352
    The reality of break-in is:
    1. For the engine: avoid going on long road trips, abide by speed limits, avoid hard acceleration.
    2. For the brakes: keep a generous following distance, drive cautiously, brake early/gently.
    With a plug-in, extend the the engine brake interval relative to your EV portion.
    Not that tough.
  4. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    Sorry didn't quite understand point about plugin.
    "extend the the engine brake interval relative to your EV portion."
    . Could you say that a different way? Thanks.
  5. Mendel Leisk
    42,352
    Well, if you're running EV 50% of the time, double the break-in period.
    Still, with any new vehicle we've had, it's always been very informal, any concerns or considerations regarding the break-in period. Again, take it easy, you're fine.
  6. Piwacet
    Piwacet Junior Member
    36
    San Francisco
    Thanks everyone for the discussion.
    I guess since the range on 1 tank of gas is a little over 600 miles, it's reasonable to use 1 tank of gas as a metric to indicate when the ICE has reached its 600 miles of use.
    The break in period for brakes seems a little confusing to me, as disc brakes may not always be used when one pushes the break pedal. I guess it's reasonable to extend that period too.
    I'll plan on gentle driving for the first tank of gas.
    Thanks!
    GT4Prius, davidtm and Mendel Leisk like this.
  7. bisco
    52,862
    some say the discs get used a bit quite often, if you watch with a scan gauge.
  8. Mendel Leisk
    42,352
    Whenever our rotors are a bit rusty, say after a wash and a day or two sitting, I can hear them, each time I touch the pedal, for the first block or two.
  9. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    My rear rotors, or "discs" in UK English, are only about 2 years old and are quite rusty, especially the part that the parking brake pads press on to. ( Actually just thinking that u.s. Gen2s have drums on the rear not discs so you may not have seen these).
    But I agree that there does seem to be contact between the pads and the discs when braking normally.
    Off topic but I still wonder why Prius discs corrode so much when I see other cars showing no signs of disc corrosion.
    Maybe it's our weather, but my Gen2 is on its third set of discs in 94000 miles and 10 years, due to corrosion.
    I know that Prius discs are used less by the car than by other cars of course, but the parts of the disc that are not cleaned by the pads rust on Priuses and not on some other cars that I see about. Are these other cars using very expensive non ferrous discs?
  10. Mendel Leisk
    42,352
    The rotors (aka discs) are not stainless, a few days idle and the contact surfaces will get rust bloom. Especially if they were wet to begin with. Protracted idle time can be problematic. And beyond the contact area it's heavy rust of course.
  11. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Just try to use a 2 times a week harder breaking to activate breaks and you will not have issues.....only Hyper Sport cars with Ceramic or carbon breaks will not have this issue any other will have same issue..where hybrid will have biggest problems if not used this practice.....
  12. RKIRKI
    RKIRKI Member
    31
    32
    Chicago NW Suburbs, IL
    Good morning! I am planning to take delivery of a new Prius Prime Premium on Friday. Due to limited inventory in my region, the best option for me was to purchase out of state. While I am excited about my purchase, I am all of a sudden feeling stressed out about engine break-in, as I will need to drive 577 miles from the dealer (western New York) to my home (Chicago area).
    There are two options for my trip:
    1. I-90 tollway with speed limit of 70
    2. Old U.S. Route 20, which parallels I-90, and meanders through cities and towns.
    If you were in my situation, which route would you take? There is obviously a significant tradeoff in trip time, but I'm willing to take Route 20 if beneficial.
    I understand the general guidance about avoiding jackrabbit starts, applying gradual braking and attempting to drive at varying speeds. I thought I would reach out to the folks here who are more knowledgeable about engines.
    Would really appreciate your thoughts a.s.a.p.!
    iskey likes this.
  13. bisco
    52,862
    i would take the back roads, take my time, learn about the prius controls and screens while doing so, and enjoy the ride.
    if you do take the highway, no worries. stay to the right, and slowly vary your speed by 5-10 mph. people in the right lane should not have a problem with that.
    check the oil level and tyres pressure before leaving the dealership.
    FA6, ruby and Mendel Leisk like this.
  14. RKIRKI
    RKIRKI Member
    31
    32
    Thank you, bisco! I am glad to be on this forum with knowledgeable people like yourself. I am conscientious about following manufacturer recommendations, but they are slightly vague with regard to break-in.
    Moments ago I received an e-mail from the dealer confirming delivery Friday morning!
    bisco and ruby like this.
  15. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Rt 20 is peppered with stop lights through those towns. Also, peps cannot pass most the time, and will tailgate if your speed is not to their standards.
    Rt 90, you'll have three lanes.
    Enjoy the Berkshires
  16. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    You might email your dealer and ask that the car not only have a full tank of gas but a full charge as well. The drive back should be fun and a good learning curve for driving the car. I bet you can't wait for Friday to roll around. Share your experience with us when you get back. CONGRATS !!!!!!!!
    Oh, also check to make sure the charge cord is with the car.
    FA6 likes this.
  17. RKIRKI
    RKIRKI Member
    31
    32
    Thanks for all the great suggestions!! I definitely will check those things before leaving the dealership Friday morning. Right now my plan is to take the U.S. 20, and I found I can switch to U.S. 30 to bypass Cleveland.
    I'll plan to post driving impressions after my trip. Coming from a Gen 3, i think the whole Prime interface will be exciting. I just want to take care of my new baby with what I learn on this site!
  18. FA6
    FA6 Member
    45
    150
    Less than 600 miles is a nice ride. Take your time, stop and take pictures, let someone take a pic of you and your car, it will be a fun adventure to remember(y).
    If my car was not bought from a dealer nearly 1900 miles away, I would have loved to drive it home as well:LOL:!
    RKIRKI likes this.
  19. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Modern machining techniques in the manufacture of the engine and gear boxes, modern excellent oils, and modern clean low sulfur gasoline have greatly reduced the need for a special break in procedure. Basically avoiding abusing the car at first is the best idea. Yes, variable speeds and loads are always a good idea.
  20. Mendel Leisk
    42,352
    Treat every cold-start like a mini-break-in too, is good: engines are most vulnerable then.
