engine cant start after small accident :/
Discussion in 'Gen 4 Prius Main Forum' started by dziadek1818, Oct 14, 2017.
  1. dziadek1818
    dziadek1818 Junior Member
    28
    poland
    Hello!
    Please apologise if i get this wrong but checked forum and never found similar problem.
    Other car hit side of my prius 16.
    The problem is that i cant start my engine Dashboard lit up and radio but not engine.
    Damaged is not big, no hit of the engine, just drivers front doors.
    Could it be that main computer blocks the engine, so nobody gets hurt?
    Cant contact any toyota shop near me as it is long free weekend down here.
    Wonder if any of you guys had similar problems?
  2. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    I don’t have any specific knowledge about the 2016 Prius, but until someone smarter than me replies, you may wish to google “fuel pump cut off switch”.
    RCO likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    It could be the DOOR OPEN sensor, and it thinks the door is OPEN.
    If I try to put mine into gear with the door ajar, it will BEEEEEP at me, and give a warning message, but will actually drive while Beeping.
    BUT - because TOYOTA has so many versions of the software in different areas of the world - maybe yours locks it from going into gear? Is there another PriusChat member in Poland?
    Raytheeagle and Prodigyplace like this.
  4. dziadek1818
    28
    poland
    Thanks for replies guys!
    The car was hit by side. No front damaged.
    Dashboard lit up but engine not
    Thinking that perhaps computer blocks it? Dont know if there is such system...
    Unfortunately, prius is not popular in Poland, honestly.
    Myself and my wife love it so much! This is great car!
    pilotgrrl, Raytheeagle and RCO like this.
  5. Prodigyplace
    12,716
    11,848
    Central Virginia
    You picture shows the car thinks the left front door is open. The car software may prevent normal driving until it senses all doors closed.
    Raytheeagle, jerrymildred and RCO like this.
  6. alanclarkeau
    7,045
    7,593
    Can you slam your door hard so the sensor goes off?
  7. Prodigyplace
    12,716
    11,848
    Central Virginia
    They are likely using translation software. The goal is to satisfy the door alert. We do not want the sensor to fall off. :LOL:
    dziadek1818 likes this.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Sorry to hear of your problem @dziadek1818 , but I think the open door indicator is one thing. The crash could very well have tripped the fuel cut off as pilotgrrl said and no fuel reaching the engine is the most likely reason it does not start. I hope you can get it fixed soon, and Welcome to Prius Chat! (y)
    dziadek1818 and Prodigyplace like this.
  9. dziadek1818
    28
    poland
    Smashed the hardest
    Guys , i really appreciate your help here!
    Doors cant be locked, bent too much. Reading these info about fuel switch off, it can be!
    It can be!
    But is the prius engine start only electric?
    Obvioulsy , will check it on monday, but i really appreciate your help! Didnt exoect such help so i am very positevely surprised! in poland forum not much info about prius.
    Raytheeagle likes this.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    The Prius may not be programmed to start the engine if it detects there is no fuel pressure. That may be why it does not start. Anyway, you are welcome to ask again if problem cannot be fixed. Please let us know how you get on. :)
  11. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The engine is only started by the electric motor, using the 200V battery through the inverter. It will only -be- started if the computers think it's ok to do so. If you are moving the system still uses the 200V battery, but in this case it will "lock" the electric motor to turn over the engine using vehicle motion. There really is no difference between the two cases, you still need the computers to be happy everything is ready.
    There is supposed to be a switch that can be manually reset to get the car out of "crash standby", but I don't know where it is. A Toyota dealer should.
    RCO and dziadek1818 like this.
  12. dziadek1818
    28
    poland
    Thanks Dave for this and all the users that replied!
    Never kniw about this inertial switch, read more on google, it can be the reason.
    Airbags got deployed now need to locate this :)
  13. alanclarkeau
    7,045
    7,593
    I didn't realise that Airbags had deployed.
    I wouldn't be surprised if deploying Airbags could disable the car- intentionally. I remember reading about a car (VW??) which applied the brakes if airbags deploy, so the car won't continue to keep rolling out of control. Not sure if TOYOTA has some other system.
  14. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    Do European models have seat belt pretensioners? Those might need to be replaced, if applicable.
    dziadek1818 and RCO like this.
  15. Mendel Leisk
    42,355
    Time for professional assessment? (n)
    Raytheeagle and bbald123 like this.
  16. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    Long past time.
  17. ChapmanF
    19,035
    Can you get to the repair manuals on toyota-tech.eu ? The site should be online even on the weekend, I would think.
    The manuals should tell you what safeties may have been tripped, how to identify them and what to do.
    -Chap
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Well, mine has from 2016 but haven't checked recently. Don't think it's the kind of feature they'd drop without good reason.
    pilotgrrl likes this.
  19. fuzzy1
    10,713
    In the U.S., that definitely means the car won't start until it is repaired.
  20. dziadek1818
    28
    poland
    Yes, driver seat airbag and left curtain was deployed.
    I am pretty sure that pump switch was activated as you guys mentioned earlier.
    Tomorrow going to take it to toyota shop and let you know!
    Long weekend here had blocked me, had to wait till Monday, but you cant imagine how i am glad to get help from you guys!
    Priifan, RCO, krmcg and 1 other person like this.
