engine cant start after small accident :/
Discussion in 'Gen 4 Prius Main Forum' started by dziadek1818, Oct 14, 2017.
  1. dziadek1818
    dziadek1818 Junior Member
    28
    poland
    I can imagine seat belt would need to be replaced as well.
  2. Yippeekyaa
    Yippeekyaa Active Member
    137
    160
    North Carolina
    I don’t understand why they would need to be replaced..please educate me. I know if you grab a seat belt and pull it quickly it will lock as intended. If after the accident it still works that way then why replace a proper functioning part that otherwise appears to have no damage?
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    They have some sort of pre-tensioner (used to be pyro-technic explosive charge, but could be different now) which, at least in my old VOLVO, is linked to an airbag deployment and will tension the belt - thus ruining the belt.
    Yes, the normal lock may work, but the pretensioner, which is a sacrificial, once only item, won't ever work again (just like the airbags).
    <EDIT> - reading on GOOGLE, it seems that some cars have electric, or even hydraulic on some older ones. The electric ones may be reusable. Many are mounted at the Buckle end, some at the retractor end.
    #23 alanclarkeau, Oct 15, 2017
  4. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I'm pretty sure the Toyota ones have them at the retractor. I say this because there are wires going to it. ;) There is also one wire at the buckle but that is for the belt connected sense.
    pilotgrrl, alanclarkeau and RCO like this.
  5. dziadek1818
    28
    poland
    Apologise for late follow.
    So the thing is that after airbags deployment one cant start engine but you can start it up by car battery booster and drive with all icons being light on :)
    But one can drive it.
    As you get to mechanic you have to dissamble airbag module and put a new one .
  6. bisco
    52,758
    wouldn't that mean the 12v is low?
  7. Prodigyplace
    12,710
    11,848
    Central Virginia
    That could be true.
    It is also possible the air bag issue can be reset for one drive by disconnecting & reconnecting the 12 volt battery. I believe some other code have a one use reset like that.
    RCO likes this.
  8. bisco
    52,758
    why would you need a battery booster?
  9. Priifan
    Priifan Member
    93
    143
    Cary, NC
    You will find the forum members are extremely helpful and know an awesome amount about how the Prius operates. It is a pleasure seeing how easily they share this info with those of us not in the know. Hope your baby gets well soon and Merry Christmas to your family!
    dziadek1818, RCO and Raytheeagle like this.
  10. padroo
    padroo Senior Member
    2,763
    2,253
    I noticed this thread has just gotten active again. I read the whole thing and the one thing never mentioned is the car needs to be scanned for codes. It would be a logical step. JMO
    RCO, Prodigyplace and Mendel Leisk like this.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Just a theory, but I seem to recall that there is a fusible link in one of the G4 12v battery connections, I suspect this may have blown, disconnecting the battery. Connecting a booster to the 12v will trip the HV battery relay into action possibly enabling the car to start.
  12. dziadek1818
    28
    poland
    Yes.
    airbag deployment dissconet battery. You cannot start the engine, boosting it up allows to drive it, that what we did there.
    All icons were falshing like crazy :D :D :D but it was ok to drive it.
    At the shop, my mechanic took the airbag module and scanned put it back, in the meantime we install new airbags (side and courtain) and everything was ok :)
    Thanks Priifan!
    Yeah, forum is just great! here in Poland there is no much about Priuses but I am very pleased that I could exchange thoughts with all of you guys and perhaps my experience can help you too :)
    Merry Christmas for You and Your Family :)
    kithmo, bisco, RCO and 2 others like this.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Congratulations on your English also. (y)
    Prodigyplace likes this.
