Engine charge for HV Battery not working properly.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rob Stone, Oct 13, 2012.
  1. Rob Stone
    Rob Stone Junior Member
    49
    Portsmouth Ohio
    After the last tests, it seems to me that this problem seems temperature based, and not HV charge based.
  2. Rob Stone
    49
    Portsmouth Ohio
    If the engine is setting codes, I see no indication on my dash. How do I get it to display trouble codes?
  3. Rob Stone
    49
    Portsmouth Ohio
    So it appears to have a fixed set of parameters loaded for cold start and the control unit switches over to sensors after warm up for feedback?
    52,720
    you have to hook up a scanner for trouble codes, but i think you would get a dash warning lite if there were any codes to scan. some auto parts places will scan it for free.
    Rob Stone likes this.
  5. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Have you cleaned the MAF sensor as in my post (13) this could make a difference, also did you check the vacuum hoses to the PCV valve and any other vacuum hoses on the system. Check for leeks where the manifold fastens to the cylinder head.
    I believe your lack of charge at what would normally be tick over is caused by the hunting "the engine ECU trying to establish control of engine speed until it does this it cannot set a speed to turn MG1 to charge the HV battery.
    When the engine is cold the speed is set higher and the mixture richer so that a small air leak makes little difference.
    If there is an air leek after the MAF there is no accurate measure of air flow into the engine. Revs will rise and the exhaust gas sensors will try to bring the mixture back to normal the ECU will then bring the revs down by shutting the throttle almost stalling the engine so it will open it again causing the hunting effect.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Just to answer your concern about Neutral, if the ICE is running when switched to Neutral it will coninue to run. If the ICE was off, it will remain off. This is normal.
  7. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    I'm wondering if you disconnected the battery (12V) while cleaning the throttle body? After reading the previous posts the next thing I would do is disconnect the 12V battery for around five minutes. This will make the ECUs relearn their adaptive settings. If that didn't work I would then put it in service mode and check the fuel trims with a scanner. As far as vacuum leaks go, I chase them down all the time, however, never on a Prius. Also, Prii do not have most of the stuff that commonly leak.
    Rob Stone and Britprius like this.
  8. Britprius
    5,194
    1,922
    Thanks I had not thought of resseting the ECU's.
  9. Rob Stone
    49
    Portsmouth Ohio
    Actually I think I realized something today. When I cleaned the throttle body, I totally removed it and removed the TPS and the throttle motor cover. Today after traveling 97 miles one way to work, the surging issue stopped. I am guessing that when the TPS is moved, that the engine control module needs to reset itself as far as TPS settings go? I had a Chevy that you had to drive it on the highway at a certain speed and time to get the ECM to adjust to new TPS setting. Now the only problem I am having is that the engine is not consistently shutting off when I come to a stop with full HV charge and cabin temp set cold. It tends to rev a tad high then calm down to a normal idle and not stop. I believe I may have the TPS a tad off. Going to adjust it for slightly slower idle to see what happens. I know I have it pretty close since there were no error codes, but.... Am I off in my assumptions?
    The throttle body cleaning greatly improved highway performance!
  10. Rob Stone
    49
    Portsmouth Ohio
    If adjusting the TPS does not do the trick, I will disconnect the 12 volt battery for 5 minutes. Thanks for all of the help folks!
