Engine chirping noise when in drive or reverse
Discussion in 'Prime Technical Discussion' started by Bluebells2, Jan 6, 2019.
Tags:
  1. Bluebells2
    Bluebells2 Junior Member
    46
    Silver Spring, MD
    When I start the car it is silent. When I put the Engine in drive or reverse it makes a chirping high pitched noise. My husband came in the garage from the house and said what is that noise? It sounds like a drive belt used to but higher pitch? It started a couple days ago. I have had the car for 8 months and it never has done it before. It is in hv and ev mode. Toyota said it was fine. However it never did it before. I don’t like or trust my dealership. Does anyone have any thoughts what this could be?
    52,841
    we would need a recording of the sound.
    did you ask the service manager to start a new one on the lot and compare them?
  3. Bluebells2
    46
    Silver Spring, MD
    It is engine noise and not cold weather related.
    I will take it back in and have them compare to another one tomorrow.
    52,841
    there are no belts, i'm not sure what could cause a chirping noise
    there are several electric pumps, perhaps one of those is starting to fail
  5. bisco
    52,841
    does it happen in ev mode?
  6. Bluebells2
    46
    Silver Spring, MD
    In both ev and hv mode. I only have 6,800 miles on the engine and have driven it for 8 months.
  7. bisco
    52,841
    in ev mode, it can't be the engine
    does it happen in drive or reverse when the car is stationary?
    i hope we're not talking about the proximity warning
  8. Bluebells2
    46
    Silver Spring, MD
    No noise when stationary. When moving in drive or reverse. Very loud when pulling in and out on garage. It is amplified in a enclosed space. Notproximity warning...not. It is a high pitched. The noise a triable makes on Star Trek Trimble episode.
  9. Bluebells2
    46
    Silver Spring, MD
    Tribble
  10. bisco
    52,841
    sounds like the proximity warning, honestly. were you familiar with it before this noise started?
  11. bisco
    52,841
    can you locate it? more under hood, or near a wheel?
  12. Bluebells2
    46
    Silver Spring, MD
    It is under the hood. Not at all near wheel.
  13. Bluebells2
    46
    Silver Spring, MD
    If it were proximity it should have kicked on for the last 8 month. Nothing in garage has changed.
  14. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    In reverse too?
  15. Bluebells2
    46
    Silver Spring, MD
    Yes in reverse also.
  16. bisco
    52,841
    proximity is changeable on the display, maybe someone hit it by mistake
  17. bisco
    52,841
    try going in and changing it
  18. bisco
    52,841
    look up vpns in the o/m
  19. Bluebells2
    46
    Silver Spring, MD
    I listened to the vpns...on you tube.it sounds exactly like that..
    I think you are right. I guess I should not take it back in. Does it do it in reverse also?
  20. bisco
    52,841
    yes, you can hit people going that direction as well
