Engine clatter on very cold start-up
Discussion in 'Gen 2 Prius Main Forum' started by JoelB, Jan 25, 2019.
  1. JoelB
    JoelB Junior Member
    Hello all, Our weather forecast here in Minnesota is abysmal to say the least. As it's getting really cold I'm hearing a lot more engine noise on initial startup, only when the car is parked outside all day at work. After a little bit the engine noise goes back to normal. With temps as low as -23F next week I'm a bit concerned.
    Is this something other owners are seeing or is there something to be concerned about here? Mileage is getting lower but not terribly so.
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    What weight engine oil are you currently running?
    edthefox5 likes this.
    52,863
    have you checked the oil level?
    how many miles on her?
  4. JoelB
    JoelB Junior Member
    It’s got 5w30 synthetic with about 50 miles on it. Level is good, slightly high if I’m honest.
  5. JoelB
    JoelB Junior Member
    Oh and it’s got 116k miles currently.
  6. kens97uber171
    kens97uber171 Active Member
    177
    133
    US
    You might throw some Seafoam or Marvel mystery oil in it.. maybe a bit too thick on the oil.
    Also.. you can get some rattle from the transmission when it's cold too.
    Also.. if you have a bad spark or coil failing. A slight misfire will make a hell of a racket... The misfire causes gear slop in the trans to bang back and forth making a rattling noise.
    Good luck.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    I would got to Walmart and buy 5 quart jug of Mobil 1 0-20 for $24.95 and install that asap. Your car takes 3.5 quarts with a new filter.
    30 weight may be too thick for that temp.
    #7 edthefox5, Jan 25, 2019
  8. TomB985
    TomB985 Member
    137
    68
    Isanti, MN
    My normal lives in the garage, but I was in a hotel last night so we got to start cold at -16° this morning. It was definitely noisier than usual, but I believe most of that was a very aggressive warm-up strategy that raised RPM significantly higher than usual as I drove. Mine has always been louder when cold, just like every other engine I’ve owned while living up north.
    0W20 is better at these temperatures, but the recommended 5W-30 won’t hurt anything.
  9. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    -23?, -16? I’m glad I live in California. The natives here complain when it gets to freezing.
