Engine Code P261B Water Pump
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jon Batchelor, Mar 3, 2026.
  1. ASRDogman
    ASRDogman Senior Member
    8,053
    4,083
    Type in the model and year, sometimes vin number, and then the part you are looking for.
    I don't understand how that is hard? Or take the info to Toyota....
    Seems like you need the coolant pump, and coolant.
    Shouldn't hurt to get the thermostat also.
  2. Jon Batchelor
    Jon Batchelor Junior Member
    25
    FL
    Apologies. I love my car, but that doesn't mean I know a heck of a lot about them, in general. I put in my car's information on the dealership sites (and it seems to be all of them, I didn't try just one) and ask for water pumps and they give me listings for at least a dozen things, with all kinds of diagrams and blow ups and related parts. Then they call it the water pump assembly, and with things like gaskets for it and other bits, and mounting stuff and so on ... as a noob to their website, it's very confusing, and I don't know if that water pump assembly has all the parts I need to replace the pump, or if I have to get the gasket and/or other things separately.
    That's why I asked. But it had the proper part number, so I finally decided it was probably the whole thing. (Though, yes, will also be getting thermostat, since it's cheap and right there, and the actual Toyota coolant.)
  3. ASRDogman
    8,053
    4,083
    They ask way too many questions! If they have the vin number, that is all they need
    because it tells them all about the car.
    I "think" it comes with the gasket.
  4. Jon Batchelor
    25
    FL
    I think next time I just let the dealership bend me over.
    Toyota charged my friend vastly more than they said on the website, while telling him they were giving him a big discount. About $150 more for parts. I called to complain, they told me "You have to order online to get online pricing." I won't be doing any business with that dealership ever again.
    They've been out there for five hours so far. Broke the new thermostat by tightening it too far, and are now in the process of putting the old one back on, then still have to get the new water pump back on.
    The videos made it look so easy.
  5. Jon Batchelor
    25
    FL
    Took 6 hours, but they finally got it finished. Everything works great, check engine light went out, and my car is good to go, again. (Even if my car is dreaming if it thinks it is going to get 507 miles out of 9/10 of a tank of gas.
    And after watching the video once, a couple of days ago, I was able to disconnect, and after work reconnect the big battery, so Toyota obviously made that a very easy process.
  6. ASRDogman
    8,053
    4,083
    They didn't do anything bad to you.
    "You have to order online to get online pricing." They is reasonable. They could have given you
    the online price, but didn't have too. You could have went home and ordered the parts, then go
    pick them up.
    It's only difficult because it's your first time doing it. And if you aren't really mechanically incline,
    it's more difficult.
    Do you have heat? You should check that. Because if you don't, you have air in the system.
    Did you fill it slowly a little at a time? This allows the coolant to push out the air...
    Afterwards, be happy about the money you DIDN'T pay to tech that you can now spend
    on something else!
