Engine coolant low, need to fill with lower quality coolant?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by THF, Oct 29, 2013.
  1. THF
    THF Junior Member
    71
    MO Ozarks
    I just realized my '04 is really low on coolant. (I know, bad Prius owner right?) I can't go to the dealership right now to get the proper SLLC Toyota coolant; can I get coolant for the Prius from Oriellys or Walmart for now, or would I then need to flush out the system and put the right coolant back in?
    My car also has a code of P1121; does this mean I should actually cough out $275 to Toyota to change the Engine Coolant COntrol Valve Sensor?
    Thanks!
  2. Patrick Wong
    18,210
    6,517
    You should use the correct SLLC. If you mix in a different coolant then you would eventually need to drain and replace the coolant. "Flushing" is not too helpful since ~ 1/3 of the old coolant will remain after the coolant is drained - so if you use water to flush, the antifreeze to water ratio will end up being lower than it should be.
    If you want to fix the problem causing DTC P1121, the engine coolant valve will need to be replaced. However that is a less important issue than making sure the engine coolant level is correct. $275 is a pretty good price for a Toyota dealer's service dept.
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Low coolant has been known to cause a sticking control valve, the problem clearing once the fluid is topped up.
    John (Britprius)
  4. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    One option would be to top off with distilled water. Later you can bring the concentration up with Toyota super long life coolant. Make sure to keep note of the amount of water so you can put at least the same amount of llc in. Keep in mind your level of boil/freeze protection will be lower until you do so.
    I second John's reply on low coolant causing a P1121. I recommend you see if the check engine light sticks around with the cooling system fillled up. I also recommend you check if your engine water pump is leaking as this is most often the cause of low coolant.
    Avi
    Mike500 likes this.
  5. Avi's Advanced Automotive
    776
    363
    Are we talking about the radiator itself, or the reservoir?
  6. THF
    THF Junior Member
    71
    MO Ozarks
    Thanks for your replies everyone. The problem appears to be a leaking coolant flow control valve. The P1121 has been active for some time, but we were told the sensor would not need replacing until cold weather became an issue. I took it in today, and they topped the coolant off. The check engine light promptly came back on. I have scheduled an appointment to have the valve replaced.
    On another note, they wanted $100 for a new rear hatch latch. Does anyone know where I can get one?
    Thanks, HF
