Engine Coolant Quick Fill
Discussion in 'Gen 3 Prius Technical Discussion' started by Bill Tribley, Nov 14, 2015.
  1. Bill Tribley
    Bill Tribley Junior Member
    Telford, PA
    A demonstration of how the Airlift tool spares you from the hassle of burping the system and attaching a hose to the top air vent on the engine. Done on a 2010 Prius but it applies across the board.
    Andyprius1, m.wynn and GrGramps like this.
  2. Mendel Leisk
    42,355
    Dang, link not working for me. Is it YouTube?
    Working now, thanks.
    #2 Mendel Leisk, Nov 14, 2015
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Good video!
    The AirLift is a real time-saver and takes the pain out of changing the coolant, making it a simple drain, pull a vacuum and refill.
    Thanks
  4. Mendel Leisk
    42,355
    He says near the end he put 4690 (grams or cc's) in. Maybe he just drained the radiator, not the block? Repair Manual shows "capacity" significantly more. It doesn't specify if that's what go in on a brand new, empty system, or typical refill during maintenance:
  5. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I used about 1.75 gallons when changing out the Engine and Inverter coolant. I was not concerned about measuring mine.
    I knew that I was not going to be able to drain all of the old so as long as the levels in the reservoirs returned to the full lines I was OK. I even removed the engine drain plug.
    After using the AirLift device I think I may have added a couple of ounces after driving to work.
