Engine Coolant Replacement, Control Valve Position?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nate0918, Jun 18, 2025.
  1. Nate0918
    Nate0918 Junior Member
    I need to replace the coolant control valve on my prius and I am changing the coolant while I am at it. I have read several threads regarding the coolant change but I have a couple questions that I couldn't find an answer for. First, I have techstream a no-spill funnel, and a venturi vacuum for my shop air compressor. I'm curious on the position of the coolant control valve, is it possible that it could be in such a position that would prevent coolant from entering either the heater core loop or the heat storage tank? How about applying vacuum to the system, would the electric pump or the valve impede the vacuum? I was wondering also if I could attach the vacuum to the bleeder port of the radiator(with the port open) to apply the vacuum rather than buying an Air Lift type setup. Your thoughts would be greatly appreciated.
  2. Tombukt2
    Tombukt2 Senior Member
    13,785
    2,497
    Durham NC
    Do you have a breakdown of the coolant hosing or the schematic of such but to answer pretty much no. Look at valve and hoses to see why .
  3. Tombukt2
    13,785
    2,497
    Durham NC
    You won't need Toyota software to fill up the thing if you've got the fancy coolant funnel business and all that you should be finished by now and coolant standing at the top of the filler neck for 10 minutes and not moving
