Engine coolant temp one hundred seventy two degrees
Discussion in 'Gen 3 Prius Technical Discussion' started by Taxi/Limo, Mar 19, 2023.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    Is one hundred seventy two degrees excessively hot after a night of taxi driving
    last time I checked after working it was 148 degrees but I did not drive as hard that night
    So I am wondering
    Was it hotter tonight because I just changed my coolant and it was drawing more heat off the engine ?
    I drove harder this time?
    There is a air bubble in my coolant system and the engine is running hotter?
    or am I worried over nothing ? Thanks
  2. Tombukt2
    Tombukt2 Senior Member
    13,765
    2,491
    Durham NC
    172 is not even operating temp for good running engine . Per SE . Most thermostats are opening around 180. You're not they're yet!. Did you fill to B line warm up ! Let sit then inspect for water line at F mark???.
  3. ChapmanF
    18,890
    A Prius will eventually get to thermostat-opening temperature in steady cruising. But being a bit below thermostat-opening temperature after a night of taxi driving doesn't surprise me much.
  4. fuzzy1
    10,673
    No, it is still slightly cool. My 'normal' highway cruising temperature is 195 F. The radiator's electric fan doesn't turn on until about 203-205.
  5. Taxi/Limo
    526
    107
    Not sure I understand what you're saying here
  6. Taxi/Limo
    526
    107
    Why does that not suprise you? Thanks
  7. ChapmanF
    18,890
    A night of taxi driving probably doesn't run the engine all the time or run it hard, so it's not surprising to have the temperature be lower than it would in continuous cruising.
  8. Tombukt2
    13,765
    2,491
    Durham NC
    Crap even running hard on SE 90 day cars cool running . It's gets hotter when I stop . Standing heat soak I guess.
  9. Taxi/Limo
    526
    107
    That makes sense
  10. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Completely impossible to say. There are way too many variables in a hybrid that effect coolant temp.
    The best way to gauge cooling system performance is steady state cruise on the highway. For example, my car runs 195.8f at anything over 60 mph. Large loads like bigger hills or heavy acceleration with lots of passengers spike the temp up. You can see the thermostat open more and the temp drop back down to 195.8 as more coolant sees airflow from the radiator.
    Sustained higher temps then 195.8 or a longer time to return to that temp would better indicate cooling system performance.
  11. Taxi/Limo
    526
    107
    [QUOTE"Sustained higher temps then 195.8 or a longer time to return to that temp would better indicate cooling system performance.[/QUOTE]
    Can you reword that ? I don't understand
  12. Taxi/Limo
    526
    107
  13. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    Can you reword that ? I don't understand[/QUOTE]
    if the temperature stays higher than 195 for longer than 5 minutes somethings wrong /
    Taxi/Limo and Mdv55 like this.
  14. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    That.
    If it stays higher you either have a weak pump, a stuck closed thermostat or other flow issues.
    If you can't even reach and and/or maintain the thermostats set temp on the highway, you have one stuck open.
  15. Ryan Will
    Ryan Will Member
    68
    43
    Southern California
    I use the Hybrid Assistant app on an old Android phone and my Bluetooth OBD2 reader while driving, and I am usually between 194-196 F. Uphill or heavy acceleration gets me around 199-201 F but almost immediately drops back down to about 195-196 F. I drive about 85% highway, as well.
    Mdv55 likes this.
