ENGINE CRANKS, BUT DOES NOT START
Discussion in 'Gen 2 Prius Technical Discussion' started by Dxta, Aug 21, 2017.
  1. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Hey guys, thanks for your replies as regards my posts here.
    I'm currently facing a terrible challenge with a Prius.
    The car was driven to the parking lot, then suddenly, there was loss of power. Some kind of hesitation.
    We trued starting the car, it couldn't.
    The dash lights all came on, except the CHECK ENGINE SIGN(ECU).
    That made me to think that there could be power issues with the ECU.
    Techstream could not scan the engine side of the car, because there was no check light on.
    Did a general Heath check, and got the following codes:
    C1201
    U0073
    U0100
    U0101
    U0142
    U0155
    B2788
    C1201
    I'm suspecting the ECU isn't communicating with the CAN. Has the ECU failed or what?
    Thanks for your replies.
  2. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Before doing anything else, check the voltage on your 12 volt accessory battery (NOT the large traction battery). If that goes low, it can cause all sorts of lights and codes because the ECUs can't communicate properly. That's the place to start. Good luck!
    SFO and bisco like this.
  3. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Thanks for the reply sir!
  4. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Tested the new battery using a DVM, and it read 11.8V.
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    That is effectively DEAD.
    Exactly how "new" is it ?
    Was it charged from an external source before being installed ??
    Who installed it ?
    Anyhow, now it needs to be thoroughly charged with an external charger.
    With a small, maintenance charger that might take as much as 24 hours.
    With a standard 6 to 10 amp charger, maybe 6 to 8 hours.
    You do not have to remove or disconnect the battery to do this charging.......but you should NOT try to start the car until the charging process is done.
    WilDavis likes this.
  6. bisco
    52,891
  7. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    The auxiliary battery was replaced two months ago.
  8. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Might inquire at the retailer about a warranty replacement.
    Is this an AGM battery?
  9. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    No
    No sir.
  10. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Best bet is find another usable battery or a trickle charger.
  11. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Want to thank everyone for your contributions.
    The issues has being resolved.
    Problem was the ECU power source from the engine fusebox, got burnt, and had to be repaired.
    Now all lights are functioning normally, as they should.
    Regards to everyone
    SFO likes this.
  12. Sam Spade
    2,036
    1,024
    2017 Prius c
    Having the most obvious symptoms fixed does NOT change the fact that this measured battery voltage is WAY too low.
    You NEED to check that out too.
    If you don't, you might be sorry.......and very soon too.
  13. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Do anyone with issues like these, should first of all follow start from the least to the complex troubleshooting procedure.
    1. Check fuses and relays
    2. ECU and fuselage wire harnesses
    3. Carry out resistance, continuity and voltage tests on related wiring circuits for shorts/opens.
    Atleast that was what I did in my case.
    Discovered it was the ECU power source that had an open in the ECU harness circuits.
  14. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Would car
    Would carry out a battery analyzer test on it later and see how it performs.
    Meanwhile, I'm kind of like testing the car first.
  15. Sam Spade
    2,036
    1,024
    2017 Prius c
    Even the best "battery analyzers" sometimes will not catch a marginal low voltage condition.
    And most of the testers in use are not the best.
    IF......you continue to measure a battery voltage below 12.0 volts, SOMETHING is wrong.
    If it stays that low while the car is in "ready" mode (running) then the charging system is not working.
  16. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Wao! An eye opener for me here.
    I think the best solution to situations like these, is to ensured batteries are procures from reputable brands.
  17. Sam Spade
    2,036
    1,024
    2017 Prius c
    Even the best things ever made sometimes fail in actual use.
    But yes, getting a brand that has a good reputation should give you a better chance of not having a problem.
  18. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    You're right Sam!
