Engine does not switch off even if I walk away from the car?
Discussion in 'Gen 3 Prius Main Forum' started by Richmond, Jul 13, 2010.
  1. Tom183
    Tom183 New Member
    652
    65
    Maine
    Instead of putting the car into "Park" first, just hit the power button. That way the car is either still in Drive or it's off - nothing in-between.
  2. claridiva
    claridiva New Member
    109
    Dallas, TX
    +1!!
    If you just hit the Power button in lieu of the Park button when leaving the car (it puts it into park automatically) you will eliminate the problem of leaving it on.
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    That basic problem here is that computers do what you tell them to do, not what you want them to do.
  4. Blizzard10
    Blizzard10 New Member
    168
    38
    Queens, NYC
    I push park in the Prius...
    My right hand is hard wired to go directly to the steering column and grab and remove the key, only to come up empty every time.
  5. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I personally prefer to just press the Power button, skipping right over that old Park thing...
  6. Priuschap
    Priuschap New Member
    SC
    Similar thing happened to me when I picked mine up from the Dealer... I exited the vechile and couldn't figure out why the thing wouldn't lock. The sales person came over to assist me again and go over the features once more. He didn't call me a "dummy" but I could tell by the look on his face he was thinking it when he said the moter was on! :)
  7. lonewolf69
    lonewolf69 New Member
    84
    Jericho, NY
    In a normal car you have to TURN the ignition keys counter clockwise to shut off the ignition, so in the prius instead of turning the key, simply push the button. In a normal car you wouldn't just park your car and walk away, you still have to TURN the key to shut off the engine first...
  8. Richmond
    Richmond Junior Member
    17
    Seatte
    In a normal car:
    1. When you turn the key to switch engine off, the key is right there, and you remove keys, lock door with the keys, and walk away. Besides, you need the key to lock (manual or remote), so if you left the engine running, looking for the keys to lock the door will alert you.
    2. You will hear the engine if you get out of the car without shutting down.
    3. When you close the door and keys are in your hands, you know the engine is shut downn.
    In the Prius:
    You push the button to power off, but the keys could be in your pocket, on the console, in your bag, anywhere inside the car. If the gasoline engine is not running (which is mostly the case inside a garage) when you exit the car, it is easy to not to notice that you have forgotten something (not having powered off).
    So, the Prius and a normal gas car are nor really comparable! One has to get used to switching the power off in the absence of any a noise clue (engine) or visual clue (keys...they could be invisible...in your pocket, etc.).
  9. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    There are visual and noise clues. The speedo and dash lighs are on as is the ready light. As for noise cues (at least on my 2nd gen), if you leave w/the power still on and close the door, the car emits a bunch of beeps and the yellow key light comes on.
  10. robertk328
    robertk328 Member
    206
    36
    Gen III does too and try locking the door (by touching the door handle) with the key inside and it beeps at you as well.
  11. lonewolf69
    84
    Jericho, NY
    Hi Rich,
    After years of driving a "normal" car, I'm programmed to automatically reach for ignition area whether there is a key or not. When I'm there, I just remember to hit the power switch instead of turning the key.
    Just imagine if you were drving a "normal" car or at least think of the Prius as television, power on when watching, and power off when finished. No I don't need to see the screen to be reminded that I have to power off the TV, it's by habbit...
    Good luck and seriously glad you didn't get any CO fumes in the garage hours later with the engine running...
  12. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    The Power Button isn't what's giving me fits, it the push the lever forward to go backward/pull the lever back to go forward! Anyone else find this a bit backward, not to mention completely different from a "normal" car where you tap it back a notch to go backwards and then pull it back a couple more notched to go forward?
  13. eestlane
    eestlane Member
    110
    Space Coast, FL
    The Prius shift pattern is more like that of a car with column-mounted standard shift lever, like we used to have before standard shift levers were moved to the center console.
  14. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    The Prius shift pattern follows the old standard, which is why it was used. Nearly all manual transmissions had reverse in the upper left. Some quasi-standards continue because of familiarity, not because they make more sense. Look no further than the QWERTY keyboard for a good example.
    Tom
  15. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Yep, on Gen II, if you try pushing the black buttons (lock dimples on 3rd gen) w/power still on, it emits a long beep. Also, pressing the remote's lock button does nothing if the power's on, at least when standing outside the car.
  16. Tideland Prius
    16,681
    It's in the normal PRND layout.... You just don't start at P lol.
  17. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I am curious, has anyone ever owned a car that did turn itself off if you walked away from it?
    I am trying to visualize why one might expect this behavior.
  18. qbee42
    18,058
    3,081
    Northern Michigan
    No, but I've known a few women who were turned off as I walked *toward* them.
    Tom
  19. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    Um, not me. Wait, we're still talking about the car, right? :huh:
  20. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    don't mean to sound rude or offensive but i could not stop laughing when i read the original post. smart keys are supposed to be a convenience, not to make us lazy. no matter what care you drive, you still have to turn it off when you get out...LOL!
    and i always lock my car doors when i leave it, even in a garage. If the engine is running, the car won't lock. So there's your idiot-proof safeguard right there.
    i know seriously...? lol.
