Engine drone under load
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by maxinthepnw, Dec 7, 2016.
  1. maxinthepnw
    maxinthepnw Junior Member
    Oregon
    Four Touring
    Just bought my 2nd gen on the first of last month! Was looking at 3rd gens, but found this one with less than
    85,000 miles - fully loaded - and a detailed service history. Got tired of my 16 MPG Subaru - My gas bill was $400ish!
    My background: I drive ~ 4,000 miles a month as a delivery driver and a college student. I live 40 miles away from school, up in the mountains on a gravel drive way. I live in Oregon, rust isn't a huge issue in my area.
    Recently, after my first oil change at the dealership I noticed an engine drone under load (Accelerating, climbing hills, etc.) I noticed that if I let off the gas and then continued to accelerate it would go away.
    This drone obviously appears when I floor the pedal (These things are quicker than I thought). Sometimes when I floor it though it sounds normal then the drone creeps in - other times it happens straight away. As a side note I don't floor the car normally. A few times to test this drone and once doing a 30-70 MPH roll with a BMW for kicks and giggles. Other than that I drive like a grandpa with this car.
    Anyways I figured the gas station I go to, which sells the cheapest gas in town without a membership was selling me terrible gas. I went to a chevron, had them fill me up with premium and used some Lucas fuel system cleaner to possibly clean out any gunk. (I had a similar issue with the Subie and this worked).
    The issue still remains. Though I'm not noticing MPG or performance drop it's something that bothers me.
    Oh -- I've also looked under the car. The exhaust system looks very clean, though I could be missing something.
    I'm not seeing a whole lot related to this issue either.
    What I've read so far:
    1) Dealership could've hit exhaust with lift causing some exhaust restrictions
    2) some sort of valve could be sticking (can't remember the name)
    3) Manifold needs to be cleaned
    52,891
    congrats and welcome! have you checked the oil level since getting it back?
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Also carefully inspect all of the air intake duct work to be sure it is snug and not damaged.
    Also have a look at the air filter. If it is a non-oem type, put a stock one back in.
    My C doesn't really do that but my Ford Fusion Hybrid makes a rather loud growl under acceleration and it comes from the air intake.
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Following bisco's train of thought, many shops, including dealers, overfill the crankcase oil. This can lead to all sorts of problems, as you'll see if you do a search here. I'm not sure if an engine drone is one of them, but definitely check the oil.
    The PCV valve may be fouled, and there may be excessive oil in the intake manifold.
    Checking the air filter's a good idea.
    I climb mountain grades nearly daily with my Prius and notice a definite change in pitch when the battery charge drops, but I'm sure you've noticed that before this oil change.
    And as you put more miles on this car, be aware that many Gen 2s start consuming oil around 130K to 150K miles. This is normal, but it's important to keep an eye on that dipstick, say every other fuel fill up.
  5. maxinthepnw
    Oregon
    Four Touring
    I always check the oil after getting it changed. Too many stories of technicians forgetting to refill the oil.
    I'll give it another look before work though.
    Ill have a look at the air filter as well, not sure when that was changed.
    Regarding the PCV valve where is that located?
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    I noticed when I replaced the engine air filter with a cheapo knock off the intake got alot louder so buy a Toyota brand OEM air filter.
    Then like everyone says check your oil as its probably overfilled by about a quart.
    And 1000 miles a week is super super duty for any car much less the tiny motor Prius. Put only high quality oil in the motor not the vat crap you will get at a dealer which is the worst. That's the oil you get if you throw them the keys and have them go at it.
    Keep your car away from the dealer.
    Change the trans fluid.
    And you car probably eats oil. Check the oil first thing in the morning before you start the car every few days till you get a handle on its consumption. Run a Prius real low on oil just once because you were not aware it eats oil and you will lunch the motor. You were not aware because the dealer does not check the oil before dumping it and then come out and say you were 2 quarts low.
    Was a new motor/trans in your budget?
  7. andrewclaus
    993
    326
    Golden, CO
    The PCV valve is easiest changed when you do spark plugs. You have to remove the relay block above the engine. It's not hard, just a pain to do for such a cheap and easy job as the PCV valve. My Bentley repair manual shows how to do it, but you can probably find instructions or a video on-line.
  8. maxinthepnw
    Oregon
    Four Touring
    I highly doubt at 89,000 miles the car will need a new engine or transmission. It could however be consuming oil. I'd also like to point out that most of my driving is cruising at around 55-65 mph on the freeway & highway. A sweet spot for any engine regardless of size or type.
    I'm about to check the oil level.
    Also, assuming it is an engine filter would a K&N OEM filter cause issues you think? Had a 50,000 mile washable one on the Subie that worked better than the original OEM one
  9. maxinthepnw
    Oregon
    Four Touring
    Also I'd like to point out this drone happens only occasionally. Most of the time it's fine - my first prius/Toyota so there's a chance this could be normal ¯\_(ツ)_/¯
  10. maxinthepnw
    Oregon
    Four Touring
    Oil is still full after about 600 miles. Air filter looks new, I can't find any markings indicating it's a Toyota brand filter however.
  11. bisco
    52,891
    the only thing i don't like about the air filter design is the extra rectangle of rubber. seems like an easy place for a leak. they changed that on the gen 3.
  12. Sam Spade
    2,036
    1,024
    2017 Prius c
    On every forum like this you will find some people with interesting "far out" ideas. The post from Ed is a good example. ;-)
    As for the air filter, that is exactly what you do NOT want to do.
    A filter with a different flow restriction might upset the fuel system, make more noise and let in more fine dirt particles.
  13. Sam Spade
    2,036
    1,024
    2017 Prius c
    If it is a pleated paper filter it's probably OK.
    And your occasional noise is probably nothing to worry about.
    As was mentioned in another post, the engine sound will change depending on engine load.
    Going uphill or accelerating with a low charge in the battery will probably sound different.
    The load on the air conditioner might sound different.
    There is a fan to ventilate the battery; it adds a bit of it's own noise.
    On and on........
  14. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Whats so far out about warning a guy thats going to drive the crap out of his car to check the oil freq as the dealer will never tell you your almost out of oil when you bring it in. Run a g2 Prius real low on oil once and it will damage the motor.
    You've been on this site 6 days and busting balls already.
  15. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Drones, Groans and GROWLS! I'm not a "hater", just observing and reporting.
    My new 2016 Prius has it all. I've had it 9 months with 7000 miles driven, and it's not getting any quieter. I just figure it's a combination of a small four-cylinder engine & bad cabin sound insulation. I really don't mind, but I must say this is probably the noisiest small to midsize car I have ever owned.
    I just drive it like a regular car. Normal smooth acceleration onto the freeway and you'll get a continuous GROWL. :LOL: It also happens around town if I accelerate even slightly briskly. But that's OK, at least it breaks up the silent monotony occasionally. :) Just don't plan on having any conversations in my car, at any speeds above 50 mph. Even without the growl, the cabin noise alone will drive you nuts. (The drone/growl doesn't have anything to do with the battery level, as my battery is always near fully charged.)
    Just another Prius Oddity...
  16. digbywombles
    digbywombles Junior Member
    GB
    I've had my UK 2010 Prius for 3 months and absolutely love it. I'm very grateful for all the tips and advice here to help get the most out of it.
    I did have a couple of buzzes and creaks that I've managed to sort out. In the middle of the dashboard, I wedged a couple of small pieces of folded card to stop that particular creak. But the reason for posting here was the growl that was coming from the passenger side whenever I accelerated. It turns out the piece of plastic above the brake fluid reservoir hadn't been put back properly. Now the car is beautifully quiet!
    Just something else to check anyway.
  17. andrewclaus
    993
    326
    Golden, CO
    One more thing to check: There's an air intake resonator under the right front fender. That often gets broken in a minor collisition. I've heard it doesn't do much even when it's intact, but it may be worth checking that too. It would have nothing to do with an oil change, though.
  18. Sam Spade
    2,036
    1,024
    2017 Prius c
    This is what you actually said.
    My opinion is that most of the above is just wild speculation and isn't really helpful at all.
    I am allowed to state my opinion, right........even when it doesn't match yours ??
  19. edthefox5
    10,096
    4,840
    Clearwater, Florida
    What exactly is wild speculation to you in my post? And why are you the one that makes the decision if its helpful or not?
  20. edthefox5
    10,096
    4,840
    Clearwater, Florida
    You may have come from a really nice car. What car? Since no dashboard alert lights the car is ok. I would check the tires. Try this as a test.
    Fill all the tires up to 45 pounds and see how different the noise is. Then deflate the tires to 32 lbs and see what that does. If you notice big change in cabin/road noise maybe a new tire may help. You can then sell your new tires on Craigs List. I went through this one with another car. And it really helped.
    As far as noise and ride quality I really like Kumho's. Nice quiet ride but life is not that great. Was worth it to me. Last tire I was talked into was a Goodyear Triple tread and there pretty noisey.
    The G2 is very noisey. I have not driven a 2016 so don't know how bad it is. One thing I did on my G2 that really helped was apply sound deadener in the trunk well. It is peel and stick sheets you just cut up and apply and worked really well. The tire well is echoing and micro phonic and tends to amplify booming road noise
    It is not a high end comfort car.
