Engine Failure.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tspoerer21, Sep 10, 2013.
  1. tspoerer21
    tspoerer21 New Member
    I seem to be noticing a lot (maybe an over statement - I have read 3 now) of people that have had Prius engine meltdowns early the cars life. By early I mean 110k to 130k miles. Mostly due to lack of oil. I have a 2010 Prius that started burning oil around 65k miles. I thought this awkward of course, but I averaged 140 miles round trip a day in a combination of highway and city driving - mostly highway. My car has been from California to Georgia and back, California to Oklahoma and back, California to Oregon and back, snow, rain hot cold, you name it, it has seen it. Not mention driving me back and forth from Temecula to San Diego 5-days a week for two and a half years. So, it has been used. I am currently in Afghanistan, been here for 6-months, but before I left I had the car serviced at the dealer as I always have. And, before I left I told my wife about checking the oil and showed her where the oil for it was in the garage. So much for that!! I got a message from her the other day that said the car broke out in Palm Desert. When she told me how this blinking caution light had been coming on and off every time she took a left hand corner and the maintenance light had been coming on I knew right then - the car was low on oil! Then she told me how it just stopped abruptly - locked up, at an intersection. I am still waiting on the diagnostics from the Toyota dealer in Palm Desert, but I am pretty sure I am looking at an engine replacement with only 120k miles on the car. I called my dealer in Temecula just to get a quote for this possibility and it was 7800 dollars - I think that would classify as rape in some places! Moral of the story, check your oil, and if it is burning oil have your mechanic investigate why and fix it if possible.
  2. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    There are very few reports of Prius engine meltdowns, specially early. Can you point some links?
    Thank you for the advice.
    Toyota owners manual refers that 0,5 litres per thousand km is somehow possible (but also referred as limit), so regular level checks are needed when oil consumption is reported.
    You might get an engine swap by a third of that price, in a salvage yard.
    Please update when possible.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  4. tspoerer21
    Don't get me wrong folks - I have loved my Prius and always touted it as the best car I ever bought. Put the back seats down and you have the room of a small SUV. 138 dollars in gas one way from San Diego to Georgia, snowboarding in Oregon - just can't beat it. But I am a little disappointed with this snafu considering I have had it serviced by the dealer ever since I bought it and no one else has touched it. I know cars don't run long without oil generally, if that turns out to be the case. However, I remember reading about all these synthetic oils when they first started arriving on the scene and how they test cars after running synthetic oil in them and draining them, and they would go for 6-8 miles before failing. And, how these synthetic oils were suppose to extend the life, but I guess you have to keep the oil in it for that to work. I am also pretty much over my love affair with Toyota over this pricing. I know I can pick up a rebuilt engine for 1200-1300 dollars. That means the rest is labor and misc parts. Either that or they are just trying to convince me to buy a new car vice fix it.
  5. telmo744
    2,181
    769
    Portugal
    Still to find what caused the oil to go away...
    Ring wear? valve seals? A leak?
    There is no outer routing of lubricant so maybe one of the first two. If so, you might be under warrant?
    Nevertheless I would fix it. Almost new car (3 gen) and not many miles in it.
  6. ETC(SS)
    7,562
    I'm sorry that this happened while you were in the Stan.
    Thanks for your service!!!
    7800 bucks is indeed sodomy for an engine replacement, but let's face it. You're going to have a tough time getting to that little tinker project yourself. DO NOT let Toyota do this work. Think about this for a moment.
    They're the ones who gave your motor a clean bill of health before you went OUTCONUS......riiiiight?
    I would advise that you get your wife to check some of the independent shops for a quote on a used engine replacement.
    The good news is that you live out on the left coast...or you WILL once you get back INCONUS. There are lots of Priuses out there that are getting killed in accidents and this means that you can get a low mileage used motor for less than a thou.
    SoCal has, I'm sure, several shops that specialize in all things Prius.
    Even if she only saves a few hundred bucks---it's worth the effort---right?
    Most Priuses do not suffer from oil related meltdowns despite the ludicrous 10k oil change interval, but they DO suffer from neglect sometimes, because let's face it. 99.44 percent of people do NOT check their oil even semi-occasionally. Some people let the dealer check their oil... When they go in for an oil change.... Every 10,000 miles.
    Sometimes people that change their oil every three thousand miles will detect that little problem that's causing oil usage about 7000 miles earlier than the folks who only swing wrenches on their car every 10K. SO....if you're down for the whole 10K change interval?
    Check your oil at least every other tank....which on a Prius is still every 1000 miles. :eek:
    Good Luck!
    Jeffrey Jessup likes this.
  7. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Something doesn't seem right about this. 120k miles on a Prius should be easily doable with very little ICE wear. Maybe the combo of hi-speed highway driving or severe driving conditions caused it to use more oil than typical, but likely oil wasn't checked regularly. Maybe the oil level got low once for an extended period of time and cause irreparable damage. Maybe one oil change was over looked. Who knows as we don't have all the facts in this story. If all the maintenance was done by the dealer, and no anomalies were noted (low oil, overdue service, deferred maintenance), it seems Toyota should offer some kind of 'good will'.
  8. ursle
    ursle Gas miser
    1,049
    192
    NH
    Well, it's a gen3 with the cartridge oil filter, it's possible the mechanic screwed up and all the oil leaked out.
    Rebound likes this.
  9. telmo744
    2,181
    769
    Portugal
    That would mean a very large pool of oil. Difficult to miss that?
    Anyway, I read again and OP said that noticed oil burning from 65k onwards...
  10. Former Member 68813
    3,524
    983
    US
    There is simply no excuse for driving the car (especially hard and long) without checking oil. This is user problem. As for oil burning issue, it possible in any car, especially at high miles. While, say 90% cars don't burn oil, the remaining ones do and one is supposed to check oil.
    I have oil burning in my kids' Corolla and I watch it very closely (like every week).
    Oil control rings is usually the weakness, especially with high miles. If one can catch the problem early, it can be partially reversible.
  11. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Even with engine oil abuse (ie letting it run way low, even below the dipstick) a modern engine still manages to hang in there for thousands of miles. It'll rattle, it'll clank and will burn oil once you top it up again, but it'll let you know for a LONG time that it needs filling with oil. I even ran a works taxi for a whole shift with no oil in it and God knows how long the previous drivers had driven it in that state, and still it was fine.
    Modern engines don't just suddenly melt down. Many years and hundreds of thousands of miles in abused company cabs is my experience of this.
  12. hlunde
    hlunde Member
    419
    75
    An issue is that many, if not most, new vehicles seem to operate needing no oil added between changes. This really intrigues me since every marine and stationary engine I have ever known (CAT, Perkins, Volvo, Yanmar) uses some oil from the getgo and throughout its lifetime -- and these engines use considerably heavier oils.
    So I'm thinking that auto manufactures design engines to use virtually no oil because that is what buyers expect. And, because of this, owners become completely complacent about checking oil on a regular basis.
    My take is that every vehicle should have a low oil level alarm, not just an alarm that sounds when the oil pressure disappears.
  13. tspoerer21
    Update for everyone. Just got the results of diagnostics and I am currently looking at 3800 bucks for an inverter and a 12vt battery. Oil was extremely low, but they won't know anything with regards to the engine until they get the inverter and battery replaced - until they can start the car.
  14. tspoerer21
    You are right! Hard for me to check the oil, or make sure the wife does it, from a war zone in Afghanistan though.
  15. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    If this is a California car isn't the inverter covered by warranty?
  16. jjPrius
    jjPrius Junior Member
    68
    22
    Southern California
    Yes, the inverter should be covered under the CA warranty.
  17. mtbiker53
    mtbiker53 Junior Member
    87
    22
    cape cod
    So,your kids have no excuse?
    steve..........
  18. Former Member 68813
    3,524
    983
    US
    This sounds fishy to me. What if you shell the money and the engine is goner? One should be able to turn the engine by wrench to see if it's turning.
    One more thing, I saw used inverters sold for $500 on ebay.
  19. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    My understanding is that the gen3 inverter is much cheaper than the gen2. When mine was replaced earlier this year (outside of warranty), I was informed the cost was £1,500 before £200 fitting (including 20%vat/sales tax). That makes $2,600 which appears much less that the $3,700 quoted by the op.If you minus our 20% tax, your costs in the US should be much less!
    The op indicates they have a 2010/gen3 Prius.
  20. fuzzy1
    10,710
    But do your kids watch it closely? If you were deployed overseas for a year, would they watch it close enough to prevent lubrication failure?
    mtbiker53 likes this.
