Engine frequently turning on during braking on gen 4
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by chrisnetcom, Apr 30, 2026.
  1. chrisnetcom
    chrisnetcom Junior Member
    I’m hoping to get some insight from others who are familiar with the Gen 4 Prius behavior, because something doesn’t feel quite right compared to what I’ve experienced before on previous generations.
    I just picked up a 2017 Prius (Gen 4) with approximately 130k miles, and I’ve noticed that the engine will frequently start while I’m braking, even in situations where I wouldn’t expect it to. A good example is coming off the highway: the engine is already fully warmed up, and the battery state of charge is sitting around 5–6 bars out of 8. I’ll be decelerating normally, and instead of staying in regen like I’d expect, the ICE kicks on at idle RPMs and will stay running for about 30 seconds or so, even after coming to a stop.
    What’s odd is that I’ve owned both a Gen 2 and a Gen 3 Prius before this, and neither of them behaved like this under similar conditions. The only time I ever saw the engine spin up during braking on those was when the battery was full and it needed to dump excess charge when braking down a steep hill, which makes sense. This doesn’t seem to be that situation.
    I'm not noticing any fuel economy hit, averaging 55-60 during my daily 100-mile commute. I've doubled checked the HV battery filter and fan to ensure they were clean. Dr. Prius app shows no strange voltage differential of the cells, and battery temps are good.
    Is this just a gen 4 quirk and I'm overthinking this? Thanks!
    #1 chrisnetcom, Apr 30, 2026
  2. BiomedO1
    BiomedO1 Senior Member
    4,575
    2,401
    Left Coast
    I haven't experienced that; but engine startup command can be triggered my many different factors.
    Please fill out year, and sub-model in your profile, so people can help you out
    52,823
    either my gen 2 or gen 3 used to start at the same place on my work commute every day. nice weather, no hvac, battery around 6 bars, low mileage, did it since new. I could never figure it out.
    the commute was 4 miles of back roads, 2 miles of highway, and less than a mile through an office park. it would start in the office park every time.
    PrimeDan likes this.
  4. chrisnetcom
    Bumping for visibility. Hoping for some more feedback.
  5. Mo. J
    Mo. J Junior Member
    Saudi Arabia
    2016 gen 4 here. Same thing since new.
    Usually after decelerating after long high speed cruising - not even that high, sometimes doing 90kph. ICE shuts off when I left the throttle, then start again shortly after braking.
    Didn't give it much thought, thought that it's something to do with the temperature of the battery.
  6. chrisnetcom
    Thank you. I guess this confirms it's just a quirk of the Gen 4, and not a traction battery issue.
  7. Prodigyplace
    12,712
    11,848
    Central Virginia
    What is the battery charge level at that time?
    If the gauge shows near full charge and you are using regenerative braking, the car spins the engine without any fuel to dissipate the electricity without overcharging the battery. The same thing can happen on a long downhill grade.
    i do not recall that unusual behavior when I had my 2017 Prius or on my current 2025 Camry.
  8. chrisnetcom
    5 or 6 bars out of 8. I'm familiar with how the previous generations of Prius would dump excess energy by spinning the engine, but this is different. It never seems to do it when there are 7 bars out of 8.
    Prodigyplace likes this.
  9. Mo. J
    Mo. J Junior Member
    Saudi Arabia
    It happens with me even with full battery. And the engine continues running for few seconds and won't go into EV mode even after deceleration.
  10. Travisfixingaprius
    Travisfixingaprius Junior Member
    34
    US
    I have driven 150k miles on my gen 4, this is 100% normal always happens. Can be annoying. I find that when you hit the break harder it will activate. So I do softer breaking cause I don’t wanna hear it or simply engage it.
  11. chrisnetcom
    Thanks. It sounds like this is completely normal for the Gen 4, based on reports from several owners like you. I appreciate the feedback.
