Engine gets stuck in low gear
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by mi2k, Jun 14, 2013.
  1. mi2k
    mi2k Junior Member
    42
    MD
    I have a 2012 Prius v 5 with 30K miles. Twice in the last 15 days the car has got stuck in a low gear on flat roads. I was pressing the pedal just enough to maintain 55 on the highway. It would not switch to EV if the speed went down below 44. The battery indicator did not show a depleted battery. There were no warning lights. We drive quite gently.
    Both times I shut off the car at the first chance I got at a traffic light. Both times, on starting again, the car behaved normal! It was as if a computer reboot fixed the problem.
    Does someone have an idea what could be going on? Has anyone else experienced it?
    52,747
    i'm not quite understanding what the problem is. what is 'low gear'? there are no gears, is the ice revving high? do you have a scangauge?
  3. mi2k
    mi2k Junior Member
    42
    MD
    I am sorry -- I am not technical or familiar with the internals. Yes, the engine was revving high, as in engine braking in other cars.
  4. Jzerocsk
    Jzerocsk Member
    108
    31
    Perhaps you had the "B" mode enabled? Worth noting, if you put it in "B" mode, it will stay there until you move the shifter back to "D". It seems like you might almost use it like a handbrake (at least that's how I thought it would work when I first tried it), but it actually stays enabled until you disable it.
  5. bisco
    52,747
    right, and if you shut the car off, it starts back up in park and you have to put it in drive again.
  6. mi2k
    mi2k Junior Member
    42
    MD
    I am quite positive it was not in the B mode (although I have never tried it). Both times I was driving normally and the transition to revving happened all of a sudden without me doing anything.
    That's correct.
  7. bisco
    52,747
    you can bump the shifter while driving, but bumping it into b mode would be difficult i think?
  8. Jzerocsk
    Jzerocsk Member
    108
    31
    Since "B" is straight down it's easier to do that than anything else. With the v-wagon shifter position it seems entirely possible to bump it accidentally.
    That said, mi2k has had the car for long enough that it seems strange it didn't happen until just the last couple of weeks...my advice is that when/if it happens again, check the dash to see if the car thinks it's in "B" mode...if it does and you're certain you didn't bump the shifter, then you have a clue that perhaps there's an issue with the actual shifter. And if it says it's in "D" then there's something else going on!
  9. mi2k
    mi2k Junior Member
    42
    MD
    I don't think I would have bumped it to B. I am aware of it now -- if it was to happen again I would make sure that it was not because I bumped it to B. I will also try shifting to D whether or not I bumped it.
    Thanks, both of you!
  10. MarathonMarty
    MarathonMarty Prii 4-timer
    38
    Spokane, WA
    2013 Prius v wagon
    Another indication that you are in 'B' mode is that you will not be able to activate cruise control until it is placed in 'D'.
  11. lbr
    lbr Junior Member
    Holland
    THe prius also reacts the same if the battery is full. Then instead of charging it will use the petrol engine to slow down when you take you're foot of the gas. It does not need to be in B for that.
  12. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    True. But even then, it will shutdown when reaching a complete stop.
    Mi2K,
    As others have said, your shifter maybe going B on its own. You might want to schedule an appointment with your dealer. The shifter is just an electronic switch and it may be going bad. Someone else had problems with the car going into reverse when put in drive so going into B could happen as well.
    Putting car in Drive, but goes to reverse | PriusChat
    We may be seeing two documented problems with the shifter.
  13. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    If it happens again, glance at the gear display to the right of the speedometer. Verify that it shows it in "D".
  14. Bob G IA
    Bob G IA Member
    167
    51
    It may be that you have a temperature sensor going bad causing the system to drop into warm up mode. If you have or could get a ScanGuage II you could look at water temp & ignition timing.
  15. bisco
    52,747
    time to visit the dealer.
  16. mi2k
    mi2k Junior Member
    42
    MD
    Thanks for all the new suggestions since my last post. I have just discovered a dealer mistake at the last service that I have posted in another thread. Do you think that could have a relevance to this problem?
