Engine Grounding Point that is accessible?
Discussion in 'Gen 2 Prius Main Forum' started by 2k1Toaster, Jun 26, 2012.
  1. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    I need a good grounding point under the hood. I see the two grounding points EE and EF but I don't know how to get to them with a socket wrench to attach my ground cable.
    Any good locations? Currently I am using one of the bolts from the inverter's case but it is not good enough. I can't physically see the other ground points.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I would think any bolt that is set into the body, should work. A good check, take an Ohm meter, attach one lead to neg terminal of the battery, poke around the engine compartment until you find a or nut that you get a Zero or very lo Ohms reading! That's How I found the points in my car for grounding my different toys!
