Engine is Toast. Needs Replacement. HUGE$$$ repair bill.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dbaguru, Feb 2, 2014.
  1. dbaguru
    dbaguru New Member
    I am facing a huge repair bill and need urgent help from this forum.
    My car recently started showing engine light and intermittently the red warning triangle. When I took my car to the dealer, he said that the engined needs to be replaced because of overheating. When he did a compression test, he said that there was no leak. But the coolant temperature showed over 275 degrees, which was 35 degrees over maximum. Also somehow the engine oil was overfilled and that too seeped into the engine.
    I have option of putting in a re-manufactured engine or a used engine ( something with about 75,000 miles on it ).
    If I go in for a re-manufactured engine by Toyota, the repair bill will be about $7000.
    For a used engine, it will be about $5000.
    In case of used engine, the dealer will not provide any warranty on parts; labor only.
    So my questions are as follows :
    Details of car
    2008
    Generation II
    Miles : 140,000
    a. How many hours of labor is needed to put in an engine ?
    b. In case of installing a used engine - does labor warranty means anything ? The dealer can always say that the part was bad and I have to pay all-over again for both parts+labor.
    c. Where are these "used engines" sourced from and what is their reliability ?
    d. Does it makes sense to get this repair done - given that car already has 140,000 miles on it.
  2. Patrick Wong
    18,210
    6,517
    a. My guess is ~12 hours.
    b. Yes, that is a risk that you take in installing a used part. The labor warranty means that if there is a problem because of something the tech did, that the dealer will fix that at no further charge. However you may need to be smart enough to figure out that the issue was due to a workmanship problem.
    c. From salvage yards, taken from totaled vehicles. Reliability is partially based upon odometer reading and partially upon the maintenance provided by the prior owner. You might know the former but will not know the latter.
    d. It might make sense to have this repair done but not for $5-7K. You should be able to purchase a decent used engine for ~$500 and find an independent repair shop that will provide the labor for $1,000 or so. However you bear the risk if the used engine has a problem.
    Finally, you need to figure out why the existing engine overheated. The normal coolant temperature is 180 degrees F. There may have been something wrong with your maintenance program which allowed that to happen. Clearly you do not want to see a recurrence of an engine failure, which is actually quite rare with Prius and is why you can buy a used engine with relatively low odometer miles for a three-digit price.
    Silver bullit, cwerdna and dbaguru like this.
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    The Prius engine is generally very reliable. If you can find a low millage engine say 60 to 70,000 miles you should have no problems with it.
    If you give a location in your avatar we can be of more help, possibly cutting that cost you quoted down to nearer $1500/2000.
    If you live and bought the car in a CARB state you may still be under guarantee.
    John (Britprius)
  4. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    My first comment is that are you sure that your coolant system is completely purged of air, and filled completely, with a properly running pump? There are many posts here over the years of DIY's and dealerships alike that had difficulty purging all the air from the engine coolant loop.
    It is hard to imagine how your engine could become toast all of a sudden like that, but I suppose it happens. Also, where are you located? Second opinions are worth seeking out, as the dealer is often not the last word as far as diagnosis goes.
    Any mechanic worth the name, that can follow directions, can do an engine swap, if that is really the problem. The engines are plentiful, for instance on eBay, and fairly cheap. It is up to you if the cost is worth it or not.
  5. dbaguru
    dbaguru New Member
    I live in NJ. I have been quoted 20 - 24 hours for replacing the engine. Does that sounds right ?
  6. bisco
    52,854
    no, unless they are talking about how long they need the car for.
    cwerdna likes this.
  7. bisco
    52,854
    why not try to sell it and see what you can get? a shadetree mechanic can do this job fairly cheap and make some good money on a turn around. 2008 with a rebuilt ice will go for decent money.
  8. vskid3
    vskid3 Active Member
    773
    228
    So does it run or not? From what you've said, it sounds like you're just getting warning lights and the dealer said the engine needed replaced. If it still runs, figure out what's wrong with the cooling system and put the right amount of oil in and go from there.
  9. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    First I would definitely get a second opinion. Sounds a bit fishy to me. It may very well be running hot, but not sure how you get from there to "needs a new engine."
    I would also call Steve at autobeyours:
    Prius hybrids sales and service Scottsburg Indiana
    If its more or less drivable I'd even consider taking it out there to have the work done by a well respected Gen 2 expert, and I'd bet at a much cheaper price than the dealer.
    Good luck!
    stevemcelroy likes this.
  10. dbaguru
    dbaguru New Member
    The car runs but the warning light ( red triangle ) comes up off. I would then put in oil and the warning light would go away. But recently the engine light also came up and stayed on. That is when I took the car to dealer and he said that the engine needs to be replaced.
  11. fuzzy1
    10,706
    At 140k? HV battery and some emissions, yes. Engine, no.
  12. vskid3
    773
    228
    So you overfilled the oil? Do you have the codes? Just seems strange that the compression is good and it runs, but the engine needs replaced.
  13. El Dobro
    El Dobro A Member
    7,106
    3,282
  14. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    At this point it seems pretty simple, get a second opinion.
    If you are in South Jersey you can try Gibbons in Media, Pa. They are about 10 miles from the Commodore Barry Bridge and do good work on hybrids.
  15. dpeverhart
    dpeverhart Member
    126
    23
    I
    I just had this repair done on a 2005 Prius. The quotes from independent hybrid specialists were around $2200 labor. I found a local trusted mechanic who has swapped many engines (never a Prius) and has some experience with hybrid battery repairs. He did the job in 10 hours and charged me just under $1000 labor. We got the engine from a local junk yard with 76k miles for $350.
    PriusGuy32 likes this.
  16. Mike500
    Mike500 Senior Member
    2,593
    767
    The other option is a certified used engine from Japan.
    As I recall, in the late 1980's a lot of car reaching their third year are taken off the road in Japan.
    I had a friend in California, who used to buy the engines all the time for his repair shop. He said that he never got a bad one.
  17. Lord Byron
    Lord Byron Member
    93
    Delaware
    I know this is way late. How did the engine replacement go?
    Also... did you check the coolant valve? Mine was bad for a while before the check engine light came on.
  18. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Post is from Feb 2014, OP hasn’t been on for 5 years, 4 weeks. I’m guessing he just walked away.
    Raytheeagle likes this.
  19. padroo
    padroo Senior Member
    2,763
    2,253
    I didn't catch that this is an old thread. The car wasn't as old as it would be now and that changes everything.
