Engine Issues. Dealer Suggests Engine Replacement. Advice?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bindu, Jan 26, 2020.
  1. bindu
    bindu New Member
    birmingham
    I have a Prius 2010 which at 155k miles had an engine issue. The toyota dealer says that it need be replaced at 5500 K cost which includes new engine / labor charges. 1 yr warranty on the new engine.
    Any adv?
    thanks in advance
    Priuslover09 likes this.
  2. Patrick Wong
    18,200
    6,474
    Have a used engine installed.
  3. Mendel Leisk
    38,718
    Have they told you any details as to what's failed on your current engine? If it's just head gasket, independent mechanics could take the head off, have a machine shop shop refurb it, and reassemble everything with Toyota's (very complete) gasket kit, for maybe $2500.
    2011 Prius Head Gasket Failure | PriusChat
    If the block has problems as well, piston/ring replacement, and perhaps a piston arm or two if bent, can be purchased: new piston ring set is around $100, and pistons are around $50 apiece. Guesstimate the piston arms are around $50 apiece, if needed.
    Another option regarding block: a complete/new "short block" can be purchased for around $1800, basically everything from the head gasket down.
    None of this is super cheap, but just food food for thought.
    #3 Mendel Leisk, Jan 27, 2020
  4. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I would by a new engine if I were u
  5. bisco
    49,477
    ay 155k, i would look around for a mech that will install a low mile salvage. you can find many threads here and maybe youtube videos
