Engine issues?!?!
Discussion in 'Gen 5 Prius Main Forum' started by Drew_priuschat, Dec 26, 2024.
  1. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Cabin air filter, engine air fiter, oil filter, .......
    Prodigyplace likes this.
  2. Drew_priuschat
    Drew_priuschat Junior Member
    23
    2024 Prius Prime
    XSE
    Yes I just went and confirmed, P0302. One is "current" one is "pending" one is "permanent"
    vvillovv likes this.
  3. Prodigyplace
    12,711
    11,848
    Central Virginia
    For the 2025 Camry, air conditioning recharge, wheel alignment, & wheel balancing are only covered for 12 months or 12K miles.
    Parts that are to be replaced during required maintenance are only covered up until the first required replacement.
    Hybrid system is 96 months / 100K miles. Hybrid Battery is 120 months / 150K miles.
  4. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    Not quite 3 year 36K mile bumper to bumper warranty.
  5. Prodigyplace
    12,711
    11,848
    Central Virginia
  6. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    No…wouldn’t that be nice.
    #26 daisy555, Dec 26, 2024
  7. Mendel Leisk
    42,305
    Nothing new though; nobody's ever warranted "consumables", or if they do it's pro-rated to the point of useless. They are trying to make a profit. ;)
  8. Paul Gregory
    Paul Gregory Senior Member
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    Mine shakes so bad that I have to keep it under 40, but I know the cause. Ice collects inside the wheel rims.
    I've spent dozens of dollars in car washes, but it usually doesn't help. I have to find a heated garage and spend at least an hour in there to fix the problem.
  9. Drew_priuschat
    23
    2024 Prius Prime
    XSE
    I recently got winter tires installed that are 16" steel rims and 215 tires, believe the aspect is 55(rims and tires were selected by kaltire) I personally haven't had any issues with the tires as of yet(knock on wood) I did have to go for a drive today and kept it on EV only and had no issues. The shaking with ice build up is a new one for me, I'll keep an eye out for that but haven't ever experienced that I normally kick out any snow/ice from the wheel wells when I see it.
  10. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    It happened twice last winter. I had to drive a hundred miles at 40 kph, pulled over in the right lane with the hazard flashers on. Not a nice trip. I pulled into a heated parkade, and after about an hour, all was well.
  11. BiomedO1
    BiomedO1 Senior Member
    4,550
    2,393
    Left Coast
    Check your warranty manual, almost everything is covered except obvious wear-out and abuse.
    RandyPete likes this.
  12. Prodigyplace
    12,711
    11,848
    Central Virginia
  13. Drew_priuschat
    23
    2024 Prius Prime
    XSE
    Hey guys just thought it would update. Got the car in and toyota took a look at it. Nothing definitive, no parts replaced. The running theory is that somehow water got into the tank/fuel injectors and caused the misfire.The recommendation is to use HV mode more, im not sure how or why water would be present but with the green light saying it was fine I took it for a spirited drive with no issues. It appears either lack of use caused some water to get in the fuel or its something not apparent that may crop up again, only time will tell. I completely forgot to get the tech stream data unfortunately. To give some information regarding hv use, I typically will get gas once every two months or so in the warmer months(most of my hv driving is for singular long trips) and I use ev for everything in town.
  14. thetoys
    thetoys Member
    50
    29
    Toronto, ON
    2024 Prius Prime
    XSE Premium
    Glad car is working in hv mode again. Which green light are you referring to?
  15. Drew_priuschat
    23
    2024 Prius Prime
    XSE
    The metaphorical green light that the car wasn't about to break something major. With a warning of misfire i had concerns driving using the gas engine would damage something
    thetoys and Prodigyplace like this.
