Engine kept running during idle with no battery charging
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Mikej, Jul 23, 2019.
  1. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    This happened few times already and I don't think it is normal behavior of a prius.
    Symptoms:
    Engine keep running during complete stop or parked(lasted about 2 min or more when I tested it)
    Does not charge the battery according to the monitor or do anything
    Happens at night time(cold temp) and daytime(hot temp), A/C off, heaters off
    Usually happens after a long high way/fast speed drive
    The problem goes away after turning on and off
    History:
    Recently swapped the ICE engine due to head gasket bolt issue. (could it be some wires were mis-plugged?)
    Only added injen intake for performance
    Video:
    Can anyone tell me what the issue is? Thanks.
    #1 Mikej, Jul 23, 2019
  2. Nick007b
    Nick007b New Member
    Trinidad & Tobago
    2014 Aqua
    The battery is on its way out, i had that problem now i have to replace 4 modules. Get ur battery checked
    52,854
    how many miles on the hybrid battery?
    how is the 12v health?
    any dash lights?
    is the battery cooling fan running?
    you might need tech stream to see what's happening
  4. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    Did you check to see if you were in neutral?
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Is it REALLY HOT where you are ?
    Was the A/C running at the time ??
    First thing you should check is the coolant level (s) and the radiator fans.
    The engine temp might be creeping up a bit and it is running to circulate the water.
    Also check the radiator to be sure there isn't a plastic "WalMart bag" stuck in it.
  6. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    ~148k
    just tested the battery and it was 12.6v
    any dash lights?
    no dash light, everything seems normal.
    Will clean that today according to remedied posted on here
    Will get one on ebay if the problem keep persisting.
    This happens in drive mode with braking or parked mode. I didn't not test it in neutral.
    It's getting hot over here in Socal but it also happened at night(~65-70F)
    I turned off A/C, heater, and radio
    Coolant level is fine, radiator fan is not on.
    nothing under the car
    I just cleaned out the battery vent today, didn't touch it for 5 years. Will report back to see if it helped or not.
    I noticed while my engine kept running during idle, my gas mileage went down little a bit.
    #6 Mikej, Jul 23, 2019
    dubit and bisco like this.
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    If the AC is running, the radiator fans should be ON.
    The radiator is not "under" the car; it is in front behind the grill.
    Then, not sure how that one is laid out but sometimes the coolant in the plastic bottle can be fine but still be low in the actual radiator. Just a wild guess. That is often referred to as an "air bubble" in the cooling system.
  8. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    Yea my bad, I meant nothing under the car near the radiator fan or behind the grill.
    Update:
    So far so good with the battery cooling vent cleaned. My mpg actually went up a little, not sure how that little vent can really mess with the engine. So remember guys, always clean your vent. #ventsmatter
    Will update again if the problem still persist. Thank you to all who replied.
  9. bisco
    52,854
    if the battery overheats, it goes into protection mode. the engine is used more, and may not shut off because of it, but i'm not sure
  10. Travis Solomon
    Travis Solomon New Member
    It is unable to run if the battery gets overheated or uncharge.
  11. Mikej
    Mikej Junior Member
    28
    2014 Prius c
    I'm guessing the traction battery was at a point where they don't trigger the overheating sensor since the fan was not broken.
    So far my mpg actually went up ~5mpg, no issue of engine running continuously. I'm also going to add this to my cleaning routine and I encourage everyone to do so as well.
    #11 Mikej, Jul 25, 2019
  12. Travis Solomon
    Actually, I must say this is really a vital part to make sure about the cleaning process. One can make it habit of doing this.
