Engine knock @ 119,820 miles on a 2013
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tekken, Feb 6, 2024.
  1. Mendel Leisk
    42,351
    They’re pretty close?
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,115
    6,974
    Texas Hill Country
  3. Tekken
    Tekken Member
    260
    77
    Los Angeles, California
    Slightly less oil moisture sticking than spark plug #3. Turn out clean them all up and adjust the gap to O.41.
    Coolant temperature 195 F @ rpm 1400- 1900 on highway drive ok? Out temp 60f in socal.
  4. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    They shouldn't need gaping. It's set at the factory, .044
  5. Tekken
    Tekken Member
    260
    77
    I have 2 set of 4 plugs. They all factory set @ less 0.41. aprox 0.39 when i measured
  6. ASRDogman
    8,066
    4,089
    Perhaps I got the numbers wrong...
  7. Mendel Leisk
    42,351
    You shouldn’t need to adjust gap on modern plugs. They’re designed for one gap, gapped thus at the factory. And they don’t wear to speak of. If the gap is off they’re defective, maybe dropped or something.
  8. Tekken
    Tekken Member
    260
    77
    There are alot fake plugs out there. Even some auto part can't tell. Always measure the correct gap according to the Toyota factory.
    A
  9. rjparker
    11,115
    6,974
    Texas Hill Country
    A bad plug causing a misfire code won’t go away in 25 seconds and won’t throw codes on a different cylinder from time to time.
  10. Tekken
    Tekken Member
    260
    77
    May have to find an authentic plugs from Toyota dealer this today.. too may counterfeit out there. Bad plug can cause misfire and can't imagine how many misfired when driving between EV to (ICE)
