Engine Knock even after cleaning EGR pipe cooler
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Radiospank, Feb 28, 2021.
  1. rjparker
    rjparker Tu Humilde Sirviente
    11,024
    6,915
    Texas Hill Country
    I agree Toyota has let us down on gen3s and most of the customer support programs are expiring for the early years. Used car prices are high right now and gas prices are rising, both good signs for clean Prius sellers.
    Interesting gen2 vs gen3 resale perspective:
    Which Toyota Prius Generation Has The Best Resale Value? | Torque News
  2. rjparker
    11,024
    6,915
    Texas Hill Country
    Most likely its pinging especially when the hv battery is low. The knock sensor will adjust the timing within a few seconds. Generally pinging is caused by too much carbon buildup in the cylinders and lower octane regular gas. Fill up with premium when the tank is close to empty and see if the pinging goes away.
  3. Mendel Leisk
    42,288
    And they were pretty toothless when in effect. What bothers me is the blatant mercenary (don’t hold back Mendel...) motive: their bottom line, and frayed reputation.
    Short version, I’ve lost respect and trust for the company.
    Merkey likes this.
  4. Radiospank
    Radiospank Member
    169
    82
    So an update, after cleaning the IM I was able to drive it that day and it was fine, runs smooth and pulls nice. However, this morning I started the car and let it idle to warm up as I usually do in the mornings and that dam rattle was showing its face again. Ok, so then while still in idle I got a check engine light, the code is P0301 Cylinder 1 misfire.
    Could this be because I cleaned the IM and when I was cleaning the ports on the engine where the Fuel Injector is that maybe I got some oil or contaminants on the Injector ? Or is it simply an ignition coil that is going bad? Car runs great btw otherwise, smooth and strong
  5. Mendel Leisk
    42,288
    Try leak down test, and horoscope inspection of the combustion chambers (looking for coolant). Head gaskets are usually failing at cylinder 1 first.
    pjksr02 and Radiospank like this.
  6. Willy Toast
    Willy Toast Member
    51
    25
    Brossard, Quebec
    My battery may be low I do not do much mileage. I will give the premium gas a try thanks.
    Does anyone know if Toyota changed the EGR valve at all after 2012? The sticky valve warranty does not cover later years.
    Just curious if you removed the black cap on the EGR valve, spun off the rotor and pulled on the stem to be sure it does not stick?
    Can't clean it this way but easy to test if it sticks. Can also grease from above resulting in a grease and carbon stem coating that's better than just carbon.
    #26 Willy Toast, Mar 5, 2021
  7. rjparker
    11,024
    6,915
    Texas Hill Country
    The EGR system was totally redesigned for the gen4s starting in 2016 with the hatchbacks.
    The shake rattle and roll many discuss here is caused by misfires on start up which rapidly clears, unlike a typical sparkplug, coil or injector misfire.
    Traditional engine ping or knock is caused by preignition which is often carbon and octane-based.
    "Shakes or Rattles" on a gen3 is most often cold start coolant leaking by a head gasket, which momentarily causes a cylinder misfire and slippage of the engine to transaxle damper. This creates a more violent result in a Prius with a serious metal on metal sound.
    #27 rjparker, Mar 5, 2021
    pjksr02 likes this.
  8. Radiospank
    Radiospank Member
    169
    82
    I didn’t know to check that piece, I took it off and cleaned it but never checked it for being stuck lol.
  9. Mendel Leisk
    42,288
    I recall yes. Query a site like mcgeorge Toyota parts you might be able to see a part no change. Just the valve portion; it’s not a big difference, but side-by-side pics something is noticeably changed. I’d guess something is tweaked internally.
  10. Willy Toast
    Willy Toast Member
    51
    25
    Brossard, Quebec
    I guess they fixed the sticking problem. Thanks for the info.
  11. Willy Toast
    Willy Toast Member
    51
    25
    Brossard, Quebec
    Here is a picture for the 2012 Prius V type EGR Where is it.JPG valve
    icyrius, Merkey and Mendel Leisk like this.
  12. Mendel Leisk
    42,288
    No kidding, fantastic picture. Thanks!
  13. Willy Toast
    Willy Toast Member
    51
    25
    Brossard, Quebec
    There appear to be two very different crazy shakes you can get.
    I experienced the head gasket hydro lock shake once in 2012 the second time I started my new Prius. I think somehow condensation from the new vehicle storage got into a cylinder. I shut the car off immediately. When I restarted it was gone and it never reappeared.
    I experienced the missing timing heavy shake with loud tinny rattle in the transaxle area most recently. The EGR valve greasing fixed this.
    I still have a weak acceleration rumble. At 59,000 miles will a scanner help me figure out what it is. It is a weird sound like loose parts rattling when I give gas or when the ICU turns on. Oil fills by the experts do seem on the high side sometimes, right on the high mark. I would assume best filling practice on a young vehicle would be exactly in the middle between high and low marks right? Maybe an old car that looses oil would be at the high mark. But somehow I doubt this damaged my head gasket. Will a scanner help me pinpoint the rattle? Is transaxle damper damage something that would show up only in low speed acceleration and go away at highway speed?
  14. Mendel Leisk
    42,288
  15. Radiospank
    Radiospank Member
    169
    82
    what kind of grease goes on the egr valve stem? I may try to clean it soon and test if it sticks.
  16. Mendel Leisk
    42,288
    I don’t think Toyota recommends any grease. If I was going to I might try Permatex Anti-seize, apply and then wipe till it’s almost gone, just a very thin residue.
    Willy Toast likes this.
  17. Mendel Leisk
    42,288
    Was thinking about those pesky M5x16 screws on the EGR valve cap. Amazon to the rescue, 50 pack of socket head cap screw style, about $12 CDN. :)
  18. Willy Toast
    Willy Toast Member
    51
    25
    Brossard, Quebec
    I agree with Mendel. You are mostly trying to remove carbon deposit if you find the valve sticking. I was putting white lithium grease through the small spring moving the stem and scaping the stem where the angle pipe bolts on. At the end it may be best to wipe it all off including any carbon picked up in the grease.
  19. ChapmanF
    18,966
    I'd think an extremely high-temperature grease, lest it turn directly to carbon itself and gum up the works.
    Maybe just dry graphite? It's already carbon. :) And slippery.
    Willy Toast and Mendel Leisk like this.
  20. ASRDogman
    ASRDogman Senior Member
    8,050
    4,082
    It didn't come with any type of lubricant, so why would it need any?
    It's not like it's opening and closing a few thousand times a minute like the engine
    valve, that don't have any lubricant.
    If itis sticking, then take it apart, run the stem on a wired wheel grinder and run a bore
    brush through the valve guide.
    That should be enough to clean it out and give it a chance to work again.
    And if not, you were going to have to replace it anyway so you've lost nothing except some time.
