Engine knock/ping and oil burning - Berryman B-12?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by oldtechaa, Jan 20, 2019.
  1. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    I've tried pouring a cup in each cylinder sock for about 12 hours (make sure you charge the hybrid battery by holding the brake and putting it in drive and pressing the gas Intel charged to full) and it will smoke like crazy. Do it before your neighbors are up or after they go to bed once the engines running keep it running pumpping gas the smoke will dissipate.
    Oli burn is about 50 percent better need to do it again.
    SFO likes this.
  2. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    Thanks. Do you think it's worth even doing anything at this point, or should I wait until the knocking is more than occasional and light and oil burning is closer to 1qt/600mi?
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Good question, as there is no smog requirement in Kentucky. Over the long term, oil consumption will clog up the catalytic converter, foul sensors, and generally add extra carbon deposits all around -none of which is cheap to fix or helps the vehicle run any better.
    Spend $20 now to save $$$$ down the road on parts, labor, or lower MPG might be worth the gamble. Unknown if it will harm the engine or emission components, but others here have used chemtool before and I haven't read a negative (though the product #, their method or application could've varied).
    If you're using 1qt per 2000 miles, there is the possibility that some of the piston oil control holes aren't completely plugged up and addressing the issue sooner might keep you from reaching 1qt per 600 miles, or potentially reverse some of the consumption issues all together. Others here claimed to have reversed some of their consumption after piston soaking with acetone, which is an ingredient mentioned in the chemtool data sheet.
    Will using the chemtool for a few tankfuls, an oil flush, or a piston soak be enough to fix the problem once and for all, doubtful.
    Approximately how fast do you generally drive on the open road? (increased speed can correlate to excess oil consumption)
    What brand/type/weight of oil are you using, and how often are you changing it?
    Raytheeagle likes this.
  4. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    A gallon should provide for quite a number of treatments, so it should help a significant amount over time.
    I typically drive 55 with nearly non-existent interstate miles, which would be at 70. I do a little city driving, but more highway with quite a few stops/starts (vehicle on/off, not motion).
    I've changed the oil once since purchase with NAPA Premium Performance 5W-30 at 5K ("Synthetic Blend", supposedly) which I anticipate I'll continue using.
    I generally weigh trade-offs from a purely financial TCO point-of-view, not including time, since money's tighter than time is.
    SFO likes this.
  5. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    Wow! That is insane – 30% more.
    The pricing structure here is around ~4.5% more for 91 AKI compared with 87 AKI. But given we are talking the equivalent of US$5.35 for 91 vs US$5.12 for 87 (as at today's prices and exchange rates), you guys are streets ahead of us in terms of affordability.
    In terms of miles, I get an extra 125 miles per tank (500 mi vs 625 per 11.88 gal) on 91 AKI vs 87 AKI. (Remember also, we do not have the fuel bladder tank, so it is relatively easy to use 11.88 gal (45 L) and refill 11.88 gal. No gas gauge worry either, it works reliably.
    By my calculations, using 91 AKI, it is ~5% more expensive to do the same miles in US, if indeed 91 AKI is 30% more expensive than 87 AKI. MPG will improve, though. You should be able to easily average 50 MPG, with a winter/summer range of 48 - 56 MPG.
    #25 dolj, Jan 23, 2019
  6. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    Right now, when regular is around $2.05/gallon, premium even at the cheapest stations is about $2.62. At the station I filled up at yesterday, it's $2.99.
    Your tank bladder situation is amusing because I don't fill past the shutoff and I can never get over about 7 gallons or 350 miles.
    Also, in regards to piston soaking, it looks like Berryman says only a few hours are needed for a piston soak. That's nice for having the car out of commission less time.
  7. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    My 4 runner sounded like it had a knock when I pressed on the gas. Wound up being the spark plugs. Old old are your spark plugs, and are they the right type?
  8. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    They were replaced at 129,962, so about 90,500 miles ago. I'll be replacing them in about 10k anyway.
    I'm thinking I may wait until my 30k service in about 10k when she gets a new air filter and spark plugs, and if my knocking gets worse over the summer consider doing something more. I'll report back on my results.
  9. Skibob
    2,912
    1,505
    Northern California
    They are old but I have seen much older. My other question still stands, are they the correct plugs for the car? I have seen people using cheap a$$ plugs causing problems so often...I could write a book.
  10. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    They were replaced by a dealer. I can only assume they were the correct ones. I haven't even looked at them. I might do that.
