Engine knocking at cold start, coolant drain.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Troels, Sep 26, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    I’d start at HP Motors in Rancho Cordova off of recycle road as they have tonnage:).
    And it’s local(y).
    Troels likes this.
  2. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
    Unfortunately there is no video of the flywheel install. It's nerve-racking. I probably couldn't have done it on film. You don't want the crank to turn backward because it drives the oil pump, then you loose your prime and your new engine, so a 19mm socket on the crank bolt, a breaker and a long cheater can hold it. Use red Lock-tite on the bolts, torque the bolts to 36 ft./lbs and then another 90 degrees. The flywheel/crank will turn a little so mark the heads of the bolts and the starting point on the flywheel before you do the 90 degree turn. Use a degree measuring device if you're concerned about accuracy. I remove the flywheel at the end of part 7. I will make a "how to" on my old engine flywheel at some point, or someone else may post one.
    Troels and Mendel Leisk like this.
  3. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    On my flywheel, I put red loctite and hit them with a Blue Point 1/2 drive impact. 15.6 scfm at 150psi. They ain’t comin out. LOL
  4. Troels
    Troels Junior Member
    29
    16
    Sacramento
    Thanks Ray, I did go with H* M***** after checking their yelp rating. Right now I have mixed feelings about that decision. Last Friday I went to their shop and inquired about an engine. The guy I talked to said they had a 40.000 mile engine I could buy for $1800 or pay an extra $ 400 and have them install it. I went with $2200 installed. We shook hands on it and I set up an appointment for the swap Monday morning.
    Monday morning the 40000 mile engine was no longer available, not even after a lengthy discussion in Russian between the guy I had made the deal with and the owner of the shop. At that point I should probably have walked away. But, impressed as I were with their 5 star yelp rating, I agreed to have a 70.000 mile engine installed instead. I found it odd that the price didn't drop some with the higher mileage engine, but let it go. They called Tuesday and recommended also replacing the water pump, $150, and the catalytic converter, $250, and I agreed to both. Picked up the car on Wednesday, the total was $2,740 with tax.
    Uber'ed in the car all day Friday and discovered a few things: At low RPM's like in back to back traffic, the engine is noisier than the original engine. The idle sounds and feels a bit rough. When starting after a stop up a steep San Francisco street, the car stalled a couple of times, nothing happened when I floored the accelerator, had to do it repeatedly. This started happening with the old engine towards the end of its life. The mpg was 2-3 miles below where the original engine was in its hey day. Thought I noticed a slight smell of coolant towards the end of the day, but it may have come from the outside or from my imagination, I was tired.
    Today I noticed that there was too much engine oil in the engine. Decided to dump it and refill to correct level. Doing this I discovered that the oil drain plug was way over torqued, had to use a breaker bar. Dumped the oil into a clean tub, it looked sort of dirty to me and I replaced it with new oil. The dumped engine oil was full of small black particles, see attached photo, I dont understand why the oil filter has not removed them.
    Going over the engine I noticed that it was very corroded on the outside (flooded or life in a much wetter/ colder climate?) and that some of the connectors in the back were caked in oil. I have not been able to locate the VIN tag, which may help me to cast light on the history of the engine. Some excess sealant is sticking out here and there, never seen that on an original engine, making me suspect the engine is rebuilt at some point. I'm going to keep driving the car and monitor its performance, coolant level, oil level, but I'm a little uneasy about all this.
    Any advise appreciated, I did get a 6 month warranty.
    Thanks, Troels
      File size:
      55.8 KB
    #24 Troels, Oct 6, 2018
  5. Troels
    29
    16
    Sacramento
    Update: 5 months and 20,000 miles later, I have had no problems with the rebuild engine. Getting good gas milage, very low oil consumption, lots of power, it's a good engine, corroded on the outside and vin removed or not.
    HP Motors in Rancho Cordova hereby recommended.
    Robert Holt, RMB, Ragingfit and 2 others like this.
  6. eunique
    eunique Member
    66
    89
    US
    thanks for updating this. I was originally scared for you as the bug oart of the story was not looking good initially. I'm glad it is good with good power and good gas mileage for you.
    A lot of times we don't get the update and get a incomplete story.
    Thanks again
    Note 9 ?
    Ragingfit likes this.
