Engine knocking at start up... Did not complete warmup cycle the previous night
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Roger T, Dec 30, 2014.
  1. hlunde
    hlunde Member
    419
    75
    Yes, it's normal, because:
    1. Prius is just a Scion with an advanced drive train. After investing in the drive train, there's not a lot left in the cost and weight budgets to install sound deadening.
    2. Driver has no control over engine speed and load. When accelerating, the HSD tends to run the engine under heavy load (near open-throttle to minimize pumping losses) and at moderate rpm to reduce frictional losses.
    Enjoy what the vehicle provides -- superb fuel economy, a spacious interior and high reliability.
    #41 hlunde, Jan 15, 2015
  2. Roger T
    Roger T Member
    198
    48
    MA
    No i am not the one who is driving it
  3. Mendel Leisk
    42,347
    If you've driven two different years, and the newer one's distinctly quieter, it could be the engineers have recognized some deficit, and made some change. Could also be machining tolerances: both cars are within tolerance limits, but the newer car is just closer. Or some misaligned or loose fasteners peripheral to the engine, say in the intake or exhaust.
    Or due to more miles on the older car: something starting to "go south", like build-up in the Exhaust Gas Recirculation circuit, or exhaust circuit starting to rust?
  4. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    OK. Let's see if we can get to the heart of the matter.
    Your engine MIGHT be loud if:
    • Your battery state of charge (SoC) is low at the time. This is because the engine will be working to propel the car and recharge the battery, both at the same time.
    • You just started the car and within one minute are driving at speeds greater than ~30 mph. For example, leaving work in the evening. This is because during the warm-up cycle, the Prius is being propelled primarily by battery power and the engine can run hard to complete the warm-up cycle. Consequently, if you run the battery low during this time, you will transition into the first bullet.
    • It's very cold outside and you have the heater running.
    • There is physically something wrong with your car.
    Because of the continuously variable transmission (CVT) the engine can run loud at times. This, in and of itself, it not a bad thing; it's just how it goes. Unfortunately, you are the only one here who has actually heard the sound so we can't judge whether it's a normal loud sound or an abnormal loud sound.
  5. bisco
    52,855
    perhaps there is a hole in the exhaust system?
  6. butchbs1985
    butchbs1985 Taking things apart is fun!
    245
    23
    ChicagoLand
    2013 Prius v wagon
    So obviously the knock issue hasn't been corrected since release of the TSB. Has anyone with a newer Prius gotten anywhere with a dealer? I can pretty much make my 2013 Prius V do it any time I wish. It sounds absolutely horrible. I'm to the point that if I move the vehicle out of the garage to the driveway or shuffle it around to clear snow, I leave it running so it warms up. I'd rather waste the fuel than have another episode of whatever horrific thing is going on under the hood happen.
    I'd love to take it to the dealer and have them look at it but am nearly certain it'd be time wasted.
  7. bisco
    52,855
    don't bother.:sick:
  8. Tande
    Tande Active Member
    556
    339
    Mich.
    It's ONLY a TOYOTA FGS!.......:giggle:
