Engine knocking, CEL, fouled plug, and lost coolant
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sammy B, Jan 29, 2017.
  1. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Have you cleaned the entire EGR system and the intake manifold?
    Pixel XL ?
    Raytheeagle likes this.
  2. Hypemasta
    Hypemasta Junior Member
    Los Angeles
    No, I haven't done that. Now I'm getting a cylinder 2 and 4 misfire but the check engine light randomly goes off and the car runs better and then it will go back to check engine light and rattling at startup. Coolant level drops more often now and I refill it. Most likely need to replace engine but mechanic said he will insert camera in cylinder to see if coolant is getting in the engine then he wants to replace engine for $3500. Not to mention the hybrid battery hasn't been replaced yet so just waiting for that to happen. Trying to get the most mileage out it before I spend more money.
  3. Hypemasta
    Los Angeles
    Not sure but I will ask next time I change my oil. Unless there's a way for me to check. I check my oil weekly and it doesn't seem watery. It reads on the dipstick and gets darker as I put more miles on it
  4. Hypemasta
    Los Angeles
    I had to fill the coolant a couple times until I put some head gasket sealant in the coolant which seems to temporarily help. Put a camera down the cylinders and there appears to be liquid getting in there which explains the the cylinder 2 and r misfire. The odd thing is that one week the check engine light goes off and the car runs fine and the next I'm misfiring. Has been going on for months now. Anyone else experiencing this?
    amos and bisco like this.
  5. Hypemasta
    Los Angeles
    Strange thing is that one week the engine light goes off and car runs fine and the other its misfiring. It's been going on for mi months now. Anyone else experiencing this?
    amos likes this.
  6. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    With coolant leaking inside the cylinder, you will get the misfires. It depends on how you are driving
    and how much pressure you're putting on the weak head gasket. You "might" also have a loose wire
    that could be giving you a misfire.
  7. bisco
    52,855
    very common with 2010's around 100k, and creeping into 2011and 12. the problem is the egr circuit gets clogged with sludge.
    amos likes this.
