Engine Knocking/Shaking During Startup on 2012 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sa177, Sep 4, 2012.
  1. Tande
    Tande Active Member
    543
    326
    Mich.
    Yes...I do....
  2. El Dobro
    El Dobro A Member
    7,088
    3,270
    I'm wondering if the problem has something to do with that. It's been said that the engine runs at a lower temperature in ECO mode and maybe it's not getting hot enough to burn off condensation. Just throwing that out there.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    My wild guess (I'm not an expert on engines or the Atkinson cycle) but what I recall from a hybrid seminar given at my Toyota from some Toyota rep (who seemed pretty knowledgeable) in 06 and from random Google searches for atkinson cycle push mixture intake like below,
    Today's Technician Classroom Manual: Automotive Engine Repair & Rebuilding - Chris Hadfield - Google Books
    I recall the rep when showing his animation mentioning "guys" (as in air/fuel mixture) being pushed back out. Perhaps that air/fuel mix is detonating inside the intake manifold because it was at the right temperature, mixture and compression for it occur?
    If so, that would make some sense as many of us know what diesel engines and dieseling sounds like...
  4. El Dobro
    El Dobro A Member
    7,088
    3,270
    The manual mentions the Camry having an Atkinson cycle engine. Are they having the same problem?
  5. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Don't know but Toyota hybrids have always been using Atkinson cycle engines, AFAIK, well before Gen 3 Prius.
    But, Camry Hybrids don't share engines w/Priuses and Gen 3 Prius went to a totally different engine from Gen 2. I doubt the intake manifold is the same. Gen 3 Prius also added stuff like an exhaust gas heat recovery system. I believe that's used to help heat the intake air (someone correct me on this, if I'm wrong).
  6. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Yes. Camry's have the problem.
    One example from Edmunds.
    Toyota Camry Hybrid Rattles, Bumps, & Squeaks
    The Camry folks call it the "Welcome Shake".
  7. Tande
    Tande Active Member
    543
    326
    Mich.
    I have no idea if running in the ECO mode has anything to contribute......I do think you are on the right track; the IM does not run at a temperature high enough to prevent this "Water/Puddle" from forming......the IM is constructed from a type of composite & (apparently) does not transfer/conduct engine heat well......anyone know if the Gen. II used a composite IM? ....
  8. txl146
    txl146 Member
    301
    NY
    Looks like I have the same symptom.
    My car was towed to Wappingers Toyota today after car experienced vibration/clunking noise from engine, which occurred immediately after engine turned on after being parked in the garage for 2 days.
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Did you get a Check Engine Light (CEL)?
  10. txl146
    txl146 Member
    301
    NY
    Yes, car threw CEL, but never pulled the code.
  11. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Hopefully the dealer can retrieve the code and tell you what it is. It'd be interesting to know the outcome.
    Why did you have it towed? Did the clunking noise and symptoms not got away after a power off and restart or you didn't try?
  12. txl146
    txl146 Member
    301
    NY
    I tried to restart, but was unable to. With check engine light on, I just didn't feel safe to keep trying. I have towing service through insurance company by the way.
  13. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Interesting that you were unable to... what do you mean by that? The car wouldn't go into READY mode when pushing on the brake w/power?
  14. txl146
    txl146 Member
    301
    NY
    Yes, that's correct.
  15. El Dobro
    El Dobro A Member
    7,088
    3,270
    Hmmm, I wonder if that's something different.
  16. txl146
    txl146 Member
    301
    NY
    Got a call from Toyota dealer. They are replacing intake manifold.
  17. txl146
    txl146 Member
    301
    NY
    Does anyone know if replacing manifold is a permanent fix?
  18. Tande
    Tande Active Member
    543
    326
    Mich.
    Yes, I know..........It's not
  19. txl146
    txl146 Member
    301
    NY
    Why do they have to replace the manifold if it's not a permanent fix? Did anyone have to pay out of their own pocket? if so, how much did it cost?
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    We were told that they were on the fourth or fifth iteration of the IM. They are obviously trying to get a fix by trail and error. We are their Ginny pigs.
