Engine light 2005 Prius, new to forum
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Over100k, Sep 9, 2015.
  1. Over100k
    Over100k Junior Member
    22
    Huntsville, Al
    I have never posted and may be in the wrong area. My engine light is on and also began smoking. I turned the AC off and the smoking stopped but the light stayed on. I am reading about a code sensor. Where do you get that and how do you use it. I also read that there are authorized dealers other than Toyota. How do you find that list? I am taking it to the dealer this morning and need to understand whether I am getting the best solution for a diagnosis. I read too to get the codes before letting anyone do the repairs. Help would be greatly appreciated. I have about 132k miles. I just moved to a new town.
  2. JC91006
    16,939
    8,647
    Smoking from the tailpipe or engine? When was the last time you checked car fluid levels? Oil level?
  3. Over100k
    22
    Huntsville, Al
    From the engine- and the fluid levels were check at the last oil change - about 4 mos ago. :(
  4. JC91006
    16,939
    8,647
    If it's smoking, you might want to bring it to the dealer to check it. If anything, it could be coolant getting on the hot engine.
    You should make it a habit to check the oil since your car is older with higher mileage
  5. Over100k
    22
    Huntsville, Al
    Ok. I am waiting at the dealer now. I asked for an oil change,and to check why the light is on. I have been here 2 hours- but they did have to take lunch. Thanks for the hint to check oil now that the car is older. I used to do that on the previous car, and it did not come to mind that I am now driving an older car. I hope that these folk are competent and honest.
  6. mikefocke
    4,083
    1,865
    Sanford, NC
    And you are right, you are in the wrong section. Priuschat is divided into sections based on the model and year of the car to more closely align a person's interests with owners of similar cars.
    This is the v section, for wagons from 2012 on.
    There aren't a lot of independent mechanics with Prius experience. But Prius Battery Repair - Home offers a code reading service free of charge.
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
  8. Over100k
    22
    Huntsville, Al
    Oops! Thank you. Let me see if I can repost over there. And thanks for the link.
  9. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    No, don't repost please, it's moved. Just report a post when posted in error and we move it, don't repost it elsewhere because it leaves behind an open thread in the wrong forum.
  10. Over100k
    22
    Huntsville, Al
    Thanks. I am learning the site and have not reposted.
    Ok, they completed the diagnosis. Costing about $400 to replace the ?cooling sensor - part is $88 and labor $99/hr. They think it will take about 3 hours due to the location of the part.
  11. JC91006
    16,939
    8,647
    Thermostat?
    I question this dealer's honesty about a cooling sensor
    #11 JC91006, Sep 9, 2015
  12. Over100k
    22
    Huntsville, Al
    I need to use their language and report back tomorrow. I hope they are competent and honest. I did not write down the code because when he went back to get that I recognized it as the one discussed in the forum related to the malfunction warning light.
  13. JC91006
    16,939
    8,647
    Was the code P1121? If that's the code, not sure how that would make your engine smoke.
  14. Over100k
    22
    Huntsville, Al
    Yes, that's it! Oh, my--
