Engine lights and codes and more lights!
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Fedari, May 4, 2017.
  1. Fedari
    Fedari New Member
    Costa Mesa, CA
    Hi everyone, thanks for checking this post out and for any feedback or help you can offer. I'll try to organize this neatly. I'm a student hoping to save some money and crossing my fingers that I can try some things out myself before taking it to the dealer.
    Timeline of events:
    4/22/17: 50k service at Toyota dealership
    4/26/17: Tires replaced at Costco (we noticed they left tools inside and had opened the rear to access either the 12 V battery and/or spare tire - no idea why)
    5/3/17: Warning lights came on the dashboard and stayed on, the hybrid system doesn't seem to be engaging
    I removed the positive lead on the 12 V battery, waited 20 minutes, and replaced it - no change. Tightened the fuel cap - no change.
    5/4/17: Took it to Midas to get computer codes and posted to this awesome forum
    Dashboard lights staying on:
    • Check Engine
    • Hybrid System
    • Slip Indicator
    • Brake System
    Codes obtained from Midas:
    • DTC No.: P0A94 and INF code 127, "Boost converter overvoltage signal detection (overvoltage due to system malfunction)"
    • DTC No.: C1310/51 and no given INF code, "The internal malfunction signal is input for at least 0.072 seconds when IG2 terminal voltage is 10.5 V or more for at least 2 seconds and communication with power management control ECU is valid."
    • DTC No.: C1259/58 and no given INF code, "The regeneration malfunction signal is input for at least 0.036 seconds when IG2 terminal voltage is 9.5 V or more for at least 2 seconds and communication with power management control ECU is valid."
    Thanks!
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,527
    6,608
    Texas Hill Country
    So, does the car run? You said the hybrid system doesn't seem to be engaging. If it runs enough to go to Midas, the hybrid system would have to be engaging. Often many codes mean nothing because of some initial problem. Don't be afraid to take it to the dealer, reasonably speaking they are equipped to understand the fault. In any case your car is probably still in hybrid warranty. There is a known problem with the hybrid inverter that had a software recall and potential replacement if necessary. So go to the dealer.
    "Hybrid-Related Component Coverage [1] Hybrid-related components, including the HV battery, battery control module, hybrid control module and inverter with converter, are covered for 8 years/100,000 miles. The HV battery may have longer coverage under emissions warranty."
    "Powertrain Coverage[1] 60 months/60,000 miles (engine, transmission/transaxle, front-wheel-drive system, rear-wheel drive, seatbelts and airbags)."
    Andyprius1, Mendel Leisk and Fedari like this.
    52,396
    welcome!
    couple things, test the 12 volt, and take it to toyota for a proper scan.
    Mendel Leisk and drysider like this.
  4. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    See above. If the battery is original, change it. 5 years gets you your money's worth.
  5. mikefocke
    4,043
    1,839
    Sanford, NC
    What does the dealer have that Midas doesn't to help diagnose problems? I'd presume (based on other manufacturers) they have a computer that hooks up to your OBD2 port and the cloud and a display that gives a list of probable causes in the order of probability and gives explicit instructions to the mechanic on how to troubleshoot by following a flow chart which gives "use this tool, do these tests, look at this result and based on the result do this next" flow charts.
    Shotgunning (just throwing parts at the problem) isn't the most economical approach unless you get very lucky. Often one fault will be the cause of multiple faults.
  6. Fedari
    Fedari New Member
    Costa Mesa, CA
    Thanks everyone! I'll be taking it to the dealer soon. It didn't occur to me about the warranty since we bought it used.
    The 12 V was replaced within the last 12 months, but I'll check it all the same.
  7. bisco
    52,396
    idk what midas has, but tech stream is the only prius specific software.
  8. RavMan
    RavMan New Member
    Australia
    I would get your LV 12v battery load tested. I know you said it was replaced 12 months ago. But if it was let to run down flat it may be damaged. Also if your charging circuit DC to DC converter, which steps down the high voltage to that of the 12V battery ok?
    I have seen 12v lv battery's give up a whole range of codes if the battery is failing.
    This is due to the voltage going low when a load is applied.
  9. Tiffany Melendez
    Tiffany Melendez New Member
    US
    2012 Prius+ MPV
    Good information.
  10. autorun
    autorun New Member
    SC
    During normal driving last night, I was stopped at a red light, the moment I hit gas,
    4 Dashboard lights come on and staying on:
    • Check Engine
    • Hybrid System
    • Slip Indicator
    • Brake System
    Any idea what could be the problem?
    I will try to get the codes later and post here.
  11. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    What could be the problem? Check engine light could be a fault code registered on the power train(engine or emissions related).
    Hybrid system. Any problem with any of the hybrid Conponents, would trigger the check hybrid system.
    Slip indicator,fight mean, one or all the tires not properly inflated, or there isn't grip between the surface and the ground.
    Brake light, could be a sign of low brake fluid, or the brake level sensor is malfunctioning.
    Sometime, a held down parking brake might trigger that.
    Dxta
  12. Mendel Leisk
    41,912
    That will help a lot. Take it to the dealership and they will for sure get all the codes, and propose a course of action.
    What's the miles; could be under warranty.
  13. autorun
    autorun New Member
    SC
    2012 Prius v level 3, 110,000 miles. Bought new in Nov 2011. My friend have mini-vci cable and tech stream software that come with it from ebay. What is way to get the codes (or clear them). My friend will be here in couple hours, but he never used the cable or software himself.
  14. Mendel Leisk
    41,912
    Hybrid warranty expired at 100K miles it looks like.
  15. autorun
    autorun New Member
    SC
    Using techstream from my friend, I got 2 codes for the Hybrid system. P0A94 DC/DC converter performance and P324E MG-ECU Power relay intermittent circuit. Any one got any suggestion what could be wrong? Thanks.
  16. mikefocke
    4,043
    1,839
    Sanford, NC
  17. autorun
    autorun New Member
    SC
    Thanks for the quick reply, I will read it in detail, but I have already exceeded 100K by close to 10K. Here are some more details I got, is this something I can order parts and work on myself?
  18. autorun
    autorun New Member
    SC
    Detail screen shot on error codes.
    Raytheeagle likes this.
  19. autorun
    autorun New Member
    SC
    Here is an update for anyone that is interested. I cleared DTC, only P0A94 came back, I have inverter type B. sub code 553 and 557. According to TSB, IPM needs replacement. I found this info, seems I should be covered, but I never got notification from Toyota.
    Sorry link won't post
  20. autorun
    autorun New Member
    SC
    My question now is "Will it be safe to drive it to Toyota dealer now?" I know IPM is bad and needs replacement, so car will not go into hybrid mode, but gas engine starts just fine, so can I drive it in gas only mode to dealer. (about 10 miles)
