Engine Lights came out
Discussion in 'Newbie Forum' started by Triparadox, Mar 12, 2019.
  1. Triparadox
    Triparadox Active Member
    201
    108
    The pipe was not clogged. Only carbon build up in the wall. The intake manifold is the one that has goo puddle.
  2. Triparadox
    201
    108
    Just cleaned the fuel injector. The injectors look pretty fine.
  3. Triparadox
    201
    108
    Update: Now every problem that previously appear has... Reappear. Goddammit. I'm out of idea. Honestly. Might just bring it to a local mechanics.
  4. padroo
    padroo Senior Member
    2,763
    2,253
    How about vacuum leaks and compression?
  5. Greenteapri
    Greenteapri Active Member
    330
    388
    Cypress
    Raytheeagle, Skibob and Mendel Leisk like this.
  6. Triparadox
    201
    108
    Got both no experience and tools required.
  7. Greenteapri
    330
    388
    Cypress
  8. Triparadox
    201
    108
    Update: in a auto repair service. Let's see where the exact problem is...
  9. Triparadox
    201
    108
    Update: They say it's likely to be the head gasket. Goddammit.
  10. Mendel Leisk
    42,343
    Is this an independent shop? Any quote, for head gasket replacement?
  11. bisco
    52,847
  12. bisco
    52,847
    I wonder if the seller tossed in some gasket sealer
  13. Triparadox
    201
    108
    Individual auto repair
  14. Triparadox
    201
    108
    they asked for $3000 for cylinder gasket and compression or $5000 for used engine with 64K in it.
  15. Triparadox
    201
    108
    I'm thinking of using sealer like Blue Devil or Steel Seal. Any video to show me how to do it properly since I don't know where the thermostats and radiator cap on Prius 2010.
  16. bisco
    52,847
    that seems like a lot of money
  17. Triparadox
    201
    108
    I'm gonna just buy 32oz Blue Devil, drain the coolant reservoir for the engine, make sure the engine is cool, plug out the top coolant hose, put it slowly there while having the engine run.
  18. bisco
    52,847
    hey, it's worth a shot, all the best!(y)
  19. Mendel Leisk
    42,343
    I would never used that sealant stuff, gum up the entire cooling system, and engine as well since it's leaking. I would replace the head gasket, if it's for sure the issue. Did they do a leak-down test to confirm??
    $3000 grand is steep. These guys are kinda cutting corners, not the cleanliest, but I heard they're around $860:
    Just foood for thought, what the job entails. They basically replace JUST the head gasket, which is around $140.
  20. Triparadox
    201
    108
    They said they spotted coolant leaking into cyl 1.
