Engine Lights came out
Discussion in 'Newbie Forum' started by Triparadox, Mar 12, 2019.
  1. Triparadox
    Triparadox Active Member
    201
    108
    Thank you..
  2. Triparadox
    201
    108
    If anyone knows where to pour the Blue Devil, please let me know. I cannot find the upper radiator hose.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Mendel Leisk, bisco and Raytheeagle like this.
  4. Kuang
    Kuang Member
    37
    38
    US
    I do not know about Blue Devil. I used Bar's leaks that helped the HG lasted 10K more, then blown again. I poured it into the coolant reservoir, make sure the coolant is clean to bring the chemicals to where it is broken.
  5. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    When I used the Blue Devil on mine, since the tank was already empty, I pulled the hose off the bottom and poured it in there. Then I put it back on, refilled the system, and ran the car in maintenance mode for 45 minutes.
  6. Triparadox
    201
    108
    Can I pour it into the upper one? The upper one connected to the reservoir?
  7. bisco
    52,847
  8. The Critic
    3,193
    2,333
    CA
    Well, with the quality of the repair shown in that video, I would consider it to be a semi-permanent repair.
    Raytheeagle and bisco like this.
  9. bisco
    52,847
    never mind :oops:
  10. Mendel Leisk
    42,343
    It might be permanent. They replace JUST the head gasket, and reuse the head bolts. That's not completely foolhardy though. And they do check the head for flatness, valves for sealing.
    More importantly: the video is very empowering. You can watch it, and realize you could DIY this. There is a lot of stuff they rush through in the video, that in fact is tough and time consuming, but if you read up , get the relevant Repair Manual sections, and are careful, pretty much anyone can do this, with basic tools.
    And with a few concesions to caution: say replacing the head bolts, that's only an extra $70~80 dollars. The head gasket alone is around $45, but a kit with most of the gaskets and O-rings you'll encounter, is around $150~200. Still pretty cheap, all in. That could be the extent of $'s, if the head doesn't need machining and the valves are always sealing.
    #50 Mendel Leisk, Mar 21, 2019
    Greenteapri likes this.
  11. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    There’s not that much of a market here for Prius head gaskets, but I would do the head gasket for that labor. That’s roughly 56.50 an hour for a day of work. Just one a week would have me in more money then I make in a week.
  12. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I would use the lower, as it goes out to the engine. The upper ones come back in.
  13. Triparadox
    201
    108
    Yeah. Just poured it and let the engine idle for 40 to 50 mins on maintenance mode. Gonna have a tour tomorrow (around the residence) for couple mins or even hours.
  14. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Your result may vary, but I got 90 days out of using Blue Devil. Now is the time to start putting back for another engine.
  15. The Critic
    3,193
    2,333
    CA
    I suppose that asking these guys to perform the job to your specs is always an option. But if you allow them to do the job in the way shown in the video, well, you are almost guaranteed to develop oil seepage (or even leaks).
    Raytheeagle likes this.
  16. Mendel Leisk
    42,343
    Understood. Take the tips, but supplement with a gasket kit.
    And for chrisakes don't stand around jawing for 10 minutes while the form-in-place gasket on the valve cover hardens up, lol. That cover is supposed to be back on the block within 3 minutes of of FIP application commencement, and all bolts torqued within 15 minutes. That's maybe a tall order, but you don't want to dawdle.
  17. The Critic
    3,193
    2,333
    CA
    And RTV should NEVER be spread with a finger; it should always be applied in a bead in the specified pattern.
  18. Mendel Leisk
    42,343
    About 1:00 in :)
    Also, I think you see them doing the lateral beads at seams, just a few seconds in?
  19. The Critic
    3,193
    2,333
    CA
    Yup, but if you look at 0:07, that is where they apply the “extra” RTV to the 6 seams on the timing cover.
    Those seams are also where the timing cover likes to leak from.
    Raytheeagle and Mendel Leisk like this.
  20. Mendel Leisk
    42,343
    Overly dimensioned diagram in the attached:
