Engine lubrication before (auto)start?
Discussion in 'Gen 2 Prius Technical Discussion' started by pasadena_commut, Dec 22, 2024.
  1. pasadena_commut
    pasadena_commut Senior Member
    3,070
    956
    Southern California
    Does the Prius always/sometimes/never spin the ICE for a few seconds with the electric motor to drive the oil pump and get oil distributed in the motor before turning on fuel and spark on an ICE start or autostart?
    Obviously whatever it is doing seems to work OK, since the motors often go over 300K miles with who knows how many total engine (re)starts (millions, tens of millions?)
  2. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    Back in the day long ago with really big engines and weak oil pumps waiting 5-10 seconds or so for oil to be flowing at its best made sense. But in small modern engines, especially engines in hybrid cars that are designed to start and stop often, the lubrication system is close enough to instantaneous to not ever be an issue. However once you get more than 2 quarts low on oil in a Prius and slam on the brakes or driving around a corner, your oil pump will not have enough oil to pump and you'll get a red triangle flickering.
  3. ChapmanF
    19,047
    Yes, it does. Not for a few seconds, but for a little bit.
  4. PriusCamper
    13,472
    5,439
    Near as I can tell it seems like engine is always spinning at freeway speeds, even when you're going down a long steep grade. Is that true? And if so what's the reasoning?
  5. ChapmanF
    19,047
    If you look at a nomograph for the engine, MG1, and MG2 speeds determined by the gear tooth counts in the PSD, you see that when the engine is stopped, high car speeds require MG1 to spin quite fast (in the − direction). (Lay a ruler from a given "car speed" on the right, through zero "ICE" (engine) speed, and see where it hits the MG1 speed on the left.)
    MG1 has a maximum safe rev limit (in either direction). Above a certain car speed, the engine has to be allowed to spin; notice that when the ruler passes through the same car speed but a nonzero engine speed (say 1000 RPM), MG1 does not end up spinning as fast.
    The magic number for the car speed differs between generations. That isn't because the tooth counts in the PSD have changed; whether surprisingly or unsurprisingly, Toyota has kept the same tooth counts there through all the generations I know about. But they keep improving the maximum safe MG1 revs, so they keep increasing the car speed you can hit before the engine has to turn. (Also, the final drive ratios have been changed between generations and models.) Back in gen 1 it was as low as 42 MPH.
    PriusCamper likes this.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    I may be wrong, but I seem to recall learning in a hybrid class that the Gen3 transmission had a second "fixed" planetary gearset that reduced MG1 speeds.
    I tried one time to see what happens to a Gen2 MG1 at 10,000 RPM but couldn't get there. The normal "software limit" is about 6500 RPM (about 40mph). Above that the ecu spins the ICE at around 1000 RPM (as you know).
    IF you shift to neutral while the ICE is off (below 40) the accelerate (coast down a steep hill), then ICE will stay off and MG1 goes faster. I ran out of hill at 66mph, math says I need about 70.
    Shift to neutral anytime the ICE is spinning, and it will (start and) stay running indefinitely - but not charge the HV battery.
  7. ChapmanF
    19,047
    The second planetary in gen 3 lies between MG2 and the PSD ring, as a reduction gear. It allows a smaller lighter MG2 that makes its power at higher speed and lower torque.
    The final drive is still connected to the PSD ring, and the PSD tooth counts are still the same, so the relationship between road speed and engine/MG1 speeds stays pretty much the same (except for the differences in final drive ratio.)
    The biggest difference is that in gen 1 or gen 2, you could speak informally of either PSD ring RPM or of MG2 RPM because they were the same. In gen 3 and later, you have to be careful which one you mean.
    I remember "about 40mph" being the magic road speed in gen 1, corresponding to gen 1's 6,500 RPM limit for MG1.
    The gen 2 New Car Features manual, page TH-26 under "Main Changes from '03 Prius", mentions increasing MG1's safe rev limit from 6,500 to 10,000 RPM, which would correspond to a higher road speed than 40mph.
    I'm not sure the engine will stay off forever. The New Car Features manual again, on page TH-46 under "Shut Down Control", explains that the ECU can veto your selection of "neutral" in three special circumstances, and picking up speed beyond the safe range is one of them. So it can then decide "neutral" wasn't quite what you meant, at least long enough to crank up the engine and keep the speeds under control. I'm betting later generations do the same.
    If it hadn't done that by 66mph, my suspicion is that it would have shortly if you hadn't run out of hill. But it's not an experiment I've run myself.
  8. ColoradoBoo
    ColoradoBoo Senior Member
    1,356
    983
    Monument, Colorado USA
    An an engineer, I'm still fascinated at the hybrid vehicles and believe Toyota's are heads-and-shoulders better than anything else out there.
    When I learned the F1 Race cars are hybrid, I went down a very fun rabbit hole learning about them....
    The history of hybrid cars in Formula One (F1) includes the development of the first hybrid, the reintroduction of hybrid systems, and the evolution of hybrid technology:
    • McLaren's KERS
      In 1998, McLaren developed the first F1 hybrid car with a largely secret KERS system. However, the technology was quickly banned and only permitted to return in 2009.
    • Honda's RA109
      In 2008, Honda tested a hybrid system on a full track at Silverstone, the first time an F1 team had done so since McLaren a decade earlier. Honda's RA109 was designed to be fitted with a battery-electric hybrid system.
    • The 2009 Hungarian GP
      The first hybrid victory in F1 was at the 2009 Hungarian GP. However, the reintroduction of hybrid systems was not a huge success, and most teams struggled to get the technology to work properly.
    • Turbochargers return in 2014
      Hybrid engines that combine a turbocharged engine with energy recovery systems (ERS) were introduced in 2014. ERS includes kinetic recovery (ERS-K) and heat recovery (ERS-H).
    • F1 technology advancements
      F1 technology advancements have continued to rise, with the use of 3D printing, augmented reality (AR), and artificial intelligence (AI).
  9. mr_guy_mann
    4,120
    2,018
    NJ-USA
    From what I can see of data from scope captures, the ECM starts firing coils and injectors as soon as it "syncs" the cam and crank sensor signals. That takes 2 engine revolutions (about a 1/4 second).
    Most conventional cars do the "same thing" using the 12V starter motor, but they take about 3/4 second.
    vvillovv and PriusCamper like this.
  10. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Not F1, but racing racing and banning rules applied to a slot car I used to run as a we lad. A chaparral and I painted it deep purple. The one in particule that was banned because no other team to touch it at that time, had a set of fans that sucked air out from underneath the car.
    https://www.roadandtrack.com/motorsports/a32350/jim-hall-chaparral-2j-history/
    There's a museum of sorts on a ranch in TX where anyone? can still see the car Jim Hall built and raced over the years.
    Would love to hear more about the KERS system if you would like to share it.
  11. PriusCamper
    13,472
    5,439
    That was a great read, thanks... And doesn't seem that the Chaparral was banned until after it was already doomed. Not to mention that was the R&D that led to them realizing you could use a wing on the vehicle instead of fans to create the same downward force. The specs on both the engine and the car had, as well as fan blades had, was astonishing, especially because it was way back then.
    vvillovv likes this.
