Engine Maintenance Mode
Discussion in 'Prime Technical Discussion' started by Tideland Prius, Apr 16, 2019.
  1. Tideland Prius
    16,680
    500 miles / 800 km and counting. Day 20.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Here’s my one weeks worth of data:
    3x what I was doing in our 2010(y).
    Tideland Prius likes this.
  3. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Again, I don’t think I’ve ever used EV Auto, so clearly I’m not an expert on it. However, I get the impression that what you’re describing here is what EV Auto is intended to do automatically: It fires up the ICE when you need a burst of power, in order to keep from burning down the battery too quickly.
    I tend to look at it from the perspective of efficient use of gasoline: The ICE revving high at slow forward speeds is exactly the conditions to produce low MPG, and for the most part, where the engine doesn’t run at peak efficiency either. So, if I can’t drive my trip entirely in EV, I tend to accelerate in EV, and then run in HV when driving conditions are broadly “cruising.”
    kevin.c and Prius from Dad like this.
  4. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I’ve never pushed the accelerator pedal to the floor, and when in EV Auto, all I see is losing the charge faster on an incline. So I’m not sure it fires the engine or not:cool:.
    I do know that when I tell it to do so, it does;).
  5. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I would rather decide this for myself. Tonight 10 miles to a theater. 4 miles surface streets, 4 miles Interstate @65 mph, then 2 miles surface streets. There and back to home EV only, 32% battery left.
    If the logic were HV above 50 mph, that is 8 miles on ICE that could be done on battery.
    mr88cet, jerrymildred and Raytheeagle like this.
  6. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    What would be nice - the car using the GPS route to intelligently plan the EV/HV mix. Particularly if you could indicate that it is a round trip with no charging. If within EV range, leave in EV. If outside of EV, use EV where appropriate and shift to HV where appropriate, with the goal of arriving home with zero left in the traction battery. I'm already doing this in my head, so a computer should be able to do it faster and more accurately.
  7. mr88cet
    2,313
    1,335
    Austin, TX
    There might be “room” for more modes to extend battery charge, such as one to reduce battery expenditure even if not at ideal MPG when the ICE is on (I gather that’s what EV Auto is about), and another to do so at ideal MPG. That’s largely hypothetical though...
    Yeah, I’ve long thought that too, even back to our Gen-2 Prius changing driving style based upon how long you’ll be on the road.
    #27 mr88cet, Apr 22, 2019
  8. Tideland Prius
    16,680
    Put that in the Prime or Gen 5 wishlist thread. (they're both buried since no one has posted in them for a while)
  9. E-GINO
    E-GINO Active Member
    196
    206
    Rome, Italy
    In Europe, we do not have the "EV Auto" pushbutton. Instead, we have the "EV City" one. Lately, it has become my favourite, because in EV City I have an EV range increase of (roughly) 10% I think due to the use of only one motor instead than both in EV mode. So far ICE newer came up whe using EV City mode, but it happened previously a couple of times during brisk accelerations in EV mode
    Of course with one motor only the accelerator pedal is less responsive, but it is enough for the heavy traffic conditions that I have to deal with. The only downside, is that in EV city mode the cruise control does ot work.
  10. Tideland Prius
    16,680
    Almost there. If I can do all of the driving tomorrow without the engine coming on, it would be Day 30 without the engine running (and over 800 miles)
  11. Tideland Prius
    16,680
    Well it's been 30 days and 1,369 km (~855 miles) and the engine still hasn't come on, on its own.
  12. bisco
    52,854
    what do you mean by 'on its own'? have you turned it on?
  13. Tideland Prius
    16,680
    I have not turned it on manually (either via the defroster or engaging HV mode).
    I’m waiting to see when it will fire up the engine even in EV Mode to do its maintenance thing. 32 days and counting.
  14. bisco
    52,854
    mine came on this morning, 124 miles :(
    Salamander_King likes this.
  15. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Its 100 miles longer than mine. Mine comes on after 24 miles when EV range hit zero. EVERY DAY. :cry::cry::cry:
  16. Tideland Prius
    16,680
    Still? I hope summer temps come soon for you guys.
  17. Salamander_King
    11,024
    8,978
    New England
    Yeah, our morning temp is still around freezing mark. With the use of a heater in the morning commute, I am still not getting summer month optimal EV range.
  18. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Had 32.4 miles show up for the drive home:).
    Excellent weather here(y).
  19. DavidA
    2,349
    1,825
    Chicago western burbs
    I'm at almost 5 months from gassing up last December. Other than running out of EV a few times on 40 mile drives, EV hasn't turned itself off to run HV. Total gas used in all that time has been maybe a pint. As far as I can tell, there isn't a maintenance mode. In fact, in two years, I haven't experienced it.
    That said, if there is a maintenance mode, it might have coincided with brutally cold (<12 degrees F) winter temperatures where it started in HV, which is expected. Wouldn't have been able to tell if that happened.
  20. Tideland Prius
    16,680
    Yeah. This was my GOM this morning.
    35 miles.
